楼主 |
发表于 2011-1-23 20:45:38
来自: 中国辽宁大连
我这里面的贴子都看了,都没有找到,可以帮帮小弟吗?我能找到所有的刀,就是找不到激活的刀具,不能只显示激活的刀具,发上来让小弟学学好吗?谢谢大哥。+ \3 |5 U7 l: i/ c3 Z
! A8 L" s( X- }$ ^
PowerMILL31.Connect
; g- u( M4 T V6 Z7 \ Dim result As String '变量定义
7 \- T2 [4 C. f8 l" S0 h# V P N Dim SplitResult() As String '数组定义6 u J# {/ t" d4 q0 t2 x
Combo1.Clear- F! p$ W6 ^+ u: ^
result = PowerMILL31.ExecuteEx("Print ENTITY TOOL")
8 C, q) k8 W/ P! K. _8 R) NSplitResult = Split(result, " '")
: u: t/ w, P/ b" VFor i = 1 To UBound(SplitResult)
5 O- S- g. O. n0 B* e SplitResult(i) = Replace(SplitResult(i), " ", "")/ e0 |# E* p' n, r2 E* M
SplitResult(i) = Replace(SplitResult(i), "'", "")
4 d( y4 {$ e5 T- @4 H4 ] SplitResult(i) = Replace(SplitResult(i), "*", "")
8 k' n& F# `7 x' a/ I SplitResult(i) = Trim(SplitResult(i))
. M2 A$ C4 R+ ^5 h3 v6 F If SplitResult(i) <> "" Then Combo1.AddItem SplitResult(i)
+ u1 \( ^) @' Q& Q0 l: cNext i6 X4 y f% b/ D. d# i0 @8 C" y
7 n/ c' v. B ]0 M( q
6 @0 Q( o2 T" H4 }0 s( }/ ?) F 3# hh749 |
