' _7 g% z. y/ r5 r- B4 U" N- ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;图层切换
- p* t4 Y7 _; l$ B - (defun lyh(mylsp / ss)1 t2 m) l) v. Z/ `4 v
- (setvar"cmdecho"0) ; 关闭命令响应
/ K+ E: _) m% ]! y n( M: R* a3 _' J$ B - (if(setq ss(ssget"i")) ; 将选择对象转到指定层9 \# D1 `, |4 x. ^$ o! {& ^9 B4 y- o
- (command"_.change"SS"""p""LA"mylsp"")
8 S2 }+ G! Z, s, F) e - (setvar"clayer"mylsp)) ; 转到指定层
. ^: l& j. J2 ^. x( `& ~ - (princ))
6 ?* w2 y2 y4 r4 u1 \ - (defun C:1 ()
. o9 m0 v3 U; `* l3 Q/ f2 Y - (lyh"0"))( j* f1 y: v8 z* {" ~, p B
- (defun C:2 ()
. x5 z& i+ l4 d6 e - (lyh"2虚线"))
! D+ E+ U, h7 b; X - (defun C:3 (). v! T$ x' f3 u2 p& b
- (lyh"3细线"))$ u& D2 T" ?* `( e3 [
- (defun C:4 ()1 V2 A: B7 J8 M* e( q
- (lyh"4中心线"))/ X7 g- D6 v1 o% F8 a3 ]+ q4 T
- (defun C:5 (). e: P) g% q% k) L
- (lyh"5文字")); G8 Y$ b$ }9 w9 ^. u
- (defun C:6 ()
7 E* `6 q8 {+ o6 \$ X! D$ Z - (lyh"6填充")); Y2 r/ ]* b5 y- O
- (defun C:7 ()8 O+ z* p& Y( [3 q# q
- (lyh"7点划线"))
) Q* E; ~! a# o - (defun C:8 ()
, p3 Q" S; R1 ~' x8 Y6 ?: H% M' v - (lyh"8不打印"))
# b, q) Z# l( F. K0 p - (defun C:9 ()4 p. e& }! W$ w2 J
- (lyh"9标注"))* r; R9 r+ f+ n' e: F# o
- (defun C:90 ()
0 V) T/ {8 T" A) E0 L) S - (lyh"90双点划线")). c$ @) j) H/ z, B9 M3 \, @
- (defun C:00 ()/ H1 J" |9 l- x& V7 ^0 H+ C
- (lyh"00图框"))) h& l V! T% i
+ i- z* @! V2 N. R+ N7 w6 _; t4 ~, ~6 a4 S: c- ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;标公差+ j* q, b9 ]3 t( F
- 0 j5 L' |9 z. K7 l v3 N1 t
- 0 H6 E% @ H9 T: U
- (DEFUN C:ede()3 S# B# J$ O% D. S0 v
- (setvar "cmdecho" 0)- }# w$ V, T' H( A8 q: V7 Z2 T
- (if (= xx nil) (setq xx 0 yy 0))' R' `9 O: l. q. ^3 }
- (prompt "\n+(")(princ xx )(princ ")")(setq n (getreal""))! N$ v& R! g8 R6 v' @; t) T4 u
- (prompt "\n-(")(princ yy )(princ ")")(setq m (getreal""))
4 @7 R3 r4 X- c$ v* H! s6 a3 j6 k6 I - (if (= m nil) (setq n xx))
: S9 ^/ H- O* N6 d - (if (= m nil) (setq m yy))1 y: h" j, g0 E# n& i
- (setq k 0)( w9 O/ C! _, k1 g
- (while (<= k 5)2 ^& o& f: f1 ^, G
- (setq a (fix (* (EXPT 10 (- 5 K)) n)))2 j! j B h! X* z7 A% h
- (setq b (* 10 (fix (* (expt 10 (- 4 k)) n))))- ~. `% h) |) ?: t( N
- (setq k1 (- 5 k))2 _4 g: G: J+ t8 M
- (IF (= a b) (SETQ K (+ K 1)) (setq K 6)))
2 z* I# |0 w) n( ] - (setq k 0)
. d M: M4 W9 Y# ^5 k# T$ q* V - (while (<= k 5)
- ^; M% C: r/ |1 X5 R# A - (setq a (fix (* (EXPT 10 (- 5 K)) M)))- m# F( Y( w$ T* W% v
- (setq b (* 10 (fix (* (expt 10 (- 4 K )) M))))2 T) J7 m& `6 [/ J4 M5 x
- (SETQ K2 (- 5 k))
, E5 F& h( l# }- x' w( B - (IF (= a b) (SETQ K (+ K 1)) (setq K 6)))1 k" M+ k) }+ U
- (setQ d2 (max K1 K2))5 q. w( o1 I& I4 E6 g
- (if (= n m) (setq c 1) (setq c 0.6))) Y* }6 A3 t$ Z- O; z- c4 l- T
- (if (and (= n 0) (= m 0)) (COMMAND "_DIMOVERRIDE" "dimtol" "off" "")
$ U7 H ]$ p0 t - (COMMAND "_DIMOVERRIDE" "DIMTP" n "DIMTM" M "DIMTOL" "ON" "DIMTFAC" c "DIMTDEC" D2 "")), a% C. z) H) n" i1 h; f
- (SETQ xx n yy m)) z7 S* {# h3 p# g
- (PRINC ))
6 Q! g$ L: c; U# i
1 r; F. @% S0 B0 i# v9 i- D1 k- ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
' v* ^2 w: Z4 |7 d+ v/ [7 _ - (defun c:qw()(command"close""y")
" \1 X' V6 I$ X, h) {. N - (princ))) \! Y b. r5 x/ M$ S2 Q5 D
- 不保存关闭当前窗口
5 w9 Q, F) h' m L2 X - (defun C:qr()(command"quit""y")
, D. u4 U2 @9 q2 p - (princ))
* M# [$ v! r4 I: }$ G" L - 不保存关闭CAD
* W7 ^- _7 o- G! k6 ^: _) j - (defun c:sd()- H4 |( {2 X; L5 W: W1 l+ `
- (princ"\n选择要保留对象:")9 t) h# ]+ u! m+ p+ Q+ ^+ ^
- (setq SS(ssget)- C! m5 {! A7 _) T
- ss1(ssget"X"))
$ n2 ]4 d' t! w( m/ Q3 Z5 d0 l% [ - (command"erase"ss1"r"ss""))1 K1 h! H4 H3 u6 M9 F& p
- 删除未选择对象
. e/ `5 j& U4 |' Z - : C" x- h( S$ @0 t
- cui——新建——宏(ai_selall 1 ai_selall copyclip qw)7 v9 W& S/ f' i: W; S0 P
- 全选+把所有转为0层+全选+复制+不保存关闭当前窗口
' J+ D/ W# w2 O S' q - * G* Q4 ?' F) `8 p6 y
- 请问大侠们,怎样才能把自定义的命令的快捷键设置为 字母+空格 ??. J* W. F+ w' l( l
- 2 Q7 l0 Q2 g2 \* g& N
- ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;CAD$ b( r8 m$ H& {& O4 x8 U( @( C& \6 ~. d
- (defun c:rec()(command"rectang"pause"d"))7 r3 d( d" C7 P
- 矩形默认选尺寸(d
复制代码 |
