查看: 1587|回复: 2
[求助] autocad2008自定义菜单
发表于 2011-3-11 10:18:08 | 显示全部楼层 |阅读模式 来自: 中国湖北武汉
我用lisp语言编了一个程序,想将它放在菜单栏上,由于和04版的差别很大,不知道怎么做了,求高手赐教!谢谢!!+ C1 p6 w$ S0 c# |$ r& r3 K6 I$ b
程序如下:  J( f. K9 `1 N" r# i. T8 Z
(defun C:ring();' B% O; M$ m# B4 i0 o
  (setq pt (getpoint "输入圆心坐标:"));0 e. J. G; W5 L
  (setq r1 (getreal "输入内圆半径:"));$ J7 U0 p4 B( }4 q- R! E
  (setq r2 (getreal "输入小圆半径:"));
$ |2 @$ k! L4 |  (setq r3 (getreal "输入外圆半径:"));
$ ?; M* D1 m. O: s2 ~4 v4 z3 C  (setq n (getint "输入小圆个数:"));
6 l' I" z0 Z/ G. r( W  (setq pai 6.28318);1 i$ l6 h3 c- q1 H1 f6 \* Q/ q9 P( x
  (command "circle" pt r1);
# s1 J0 }: R9 a3 q; E: Q' K- Z5 s  (command "circle" pt r3);
% s7 e) K$ d$ T  (setq r (/ (+ r1 r3) 2));
- `' j4 I* b9 k  (command "layer" "M" "1" "C" "BLUE" "1" "L" "CENTER" "1" "S" "1");5 O0 b* ^* W9 N- Q$ Q
  (command);
* g& ]2 Q5 M' k6 U4 S" I  P  o  (command "circle" pt r);
+ _- ?  S% B/ w& D  (command "layer" "M" "2" "C" "RED" "2" "S" "2");+ d! M; R) _4 _0 H2 p
  (command);
9 N5 A4 W% v6 C  H4 O% j  (setq gle 0);8 @$ `6 m; c3 j( L
  (setq k 1);0 k; `/ F5 {& Z6 y8 P8 y5 Z
  (while (<= k n);# M. ~; @; o4 z1 f( k7 R
     (setq gle (+ gle (/ pai n)));
9 s3 `7 L8 [& P2 \# U/ W     (setq ptn (polar pt gle r));
$ n4 N/ E) o3 [9 y' b6 ?- V7 {     (command "circle" ptn r2);
& G+ k0 B+ R2 R/ b     (setq k (+ 1 k));; s4 g: O5 n* b7 _& s/ R: W4 I. d
  );9 i* y8 h6 q9 W* ?9 k
发表于 2011-3-11 18:30:35 | 显示全部楼层 来自: 中国广东佛山
楼上的兄弟都用汇编了
 楼主| 发表于 2011-3-11 19:47:14 | 显示全部楼层 来自: 中国湖北武汉
2# ywt880727 二次开发啊
