发表于 2011-4-29 08:23:38
来自: 中国广东佛山
1,写一个宏.
, _ @% W) s- r' F2,把草图名称改为"草图n".
9 |5 W" w$ P% k6 g+ T9 B2 j- Y% a$ z1 U" f, Q0 }, i
. ?2 {1 J$ b% S0 |" q, k" jSub main()
6 ^) b+ Y6 ]2 x. p% _ Dim swApp As SldWorks.SldWorks8 B* N0 P$ e1 m6 {; _% {4 H
Dim swModel As SldWorks.ModelDoc2
- _% D, |. L5 q- L7 O Dim swPart As SldWorks.PartDoc
: v1 Y# Z0 |% m; b9 ` Dim swSelMgr As SldWorks.SelectionMgr& n" Y+ s6 D5 G) U! C \
Dim swFeat As SldWorks.Feature
" |+ C N# f8 X U$ U5 h+ K* e0 A Dim swSketch As SldWorks.Sketch
- |8 O9 P& W. b1 o0 r$ i Dim mySelectData As SldWorks.SelectData
7 J) m. K1 ?" r& K# @3 {: ^6 t9 P Dim skContour As SketchContour
% ^0 ~- E6 Q9 a' I) ^5 I6 W1 y Dim vEdges As Variant, myEdge As SldWorks.Edge
+ a+ V& b- o: w+ `/ H! G4 t Dim NumArcs, uuu As Long
- y1 y$ g' V3 y' r& D Dim vArcs As Variant4 y. x) M0 n$ m2 O4 Z/ r, d0 V; p
Dim vSkContours As Variant
0 _; J J. n4 h% A% o) w! P Dim vSkSeg As Variant& D5 e" m1 q) Z N& S
Dim i As Integer
9 z, K6 B" z3 j k. A9 M Dim boolstatus As Boolean
2 O0 ^! w% g1 M# B. q# K4 c Dim swSkArc As SldWorks.SketchArc
3 a( K/ B0 k7 o6 |5 {% \& C Dim swCurve As SldWorks.Curve
$ R) q/ u, M2 @- x5 ~ Dim skPoint As Object- x0 ^& Y( }! E. J
Set swApp = Application.SldWorks
- c6 ~5 ?$ _9 p6 I b/ H Set swModel = swApp.ActiveDoc
: E& c$ E" P9 Z9 F( [" Z Set swPart = swModel+ J* X8 o# h0 B2 z! x" P- Y
Set swSelMgr = swModel.SelectionManager1 A6 `9 {) B/ e1 [9 n/ _
Set mySelectData = swSelMgr.CreateSelectData4 k4 v! n4 v$ d
Set swFeat = swPart.FeatureByName("草图n")
" B% @1 t; T- s: w Set swSketch = swFeat.GetSpecificFeature
% X5 W* y5 N* J' G' M i swModel.Extension.SelectByID2 "草图n", "SKETCH", 0, 0, 0, False, 0, Nothing, 08 R5 @) |% v3 e2 F5 j4 p
swModel.EditSketch9 [% s) z* @6 R+ d3 U
If Not swSketch Is Nothing Then
) }; l9 q- s- y8 i* l" Z- S NumArcs = swSketch.GetArcCount* z: _6 r9 m* @7 Y/ v) `3 {
vSkContours = swSketch.GetSketchContours()( i; }. {, e7 G9 H& T# }
For i = 0 To UBound(vSkContours)
, q1 L! ]5 `$ o% h9 e6 p vArcs = swSketch.GetArcs28 ?+ s% ?$ P; l; [' M/ @( z5 W
If IsEmpty(vArcs) Then Exit Sub
) N# s) f3 U) o6 R- g. L Set skContour = vSkContours(i)2 N) w* \/ M5 c+ b4 q% H* K
If Not skContour Is Nothing Then Q3 N5 W9 U+ x( n1 J
If skContour.IsClosed = 1 Then
' q4 z# b( t; D3 c t uuu = skContour.GetEdgesCount
' m5 |3 u. O6 [7 n& V* s8 I. h If uuu = 1 Then5 w/ t4 ~/ ^' D! } _; I+ d
vEdges = skContour.GetEdges
+ l$ e0 b" g+ [4 s2 e$ L, k Set myEdge = vEdges(0)
; _: E; i8 ^- ^0 ^% k q Set swCurve = myEdge.GetCurve
7 }# \% h; U1 f) T' q3 c* d7 [) ? vSkSeg = swCurve.CircleParams
6 V" B- o1 C, m4 ~& H boolstatus = skContour.Select2(False, mySelectData)
; I) C! h" @! {' L3 L swModel.EditDelete k7 W+ p; A+ E0 A9 z N) s7 x5 i
Set skPoint = swModel.SketchManager.CreatePoint(vSkSeg(0), vSkSeg(1), 0) S5 S4 s! ~6 a+ ]3 Z
End If
" z' j5 n# A5 J) K End If' I8 x. ~2 s3 b3 t: s
End If3 {2 ]6 X# V7 g
Next i' |4 ^) \# x) m( W1 I0 \: R, p
swModel.SketchManager.InsertSketch True
+ p: B, m9 `8 M/ T# c# k End If% s1 ?- X. W' [1 F
End Sub |
