发表于 2011-9-25 20:28:09
来自: 中国山东烟台
% Q# `- I* K% M/ d当然可以,这是我写的G0G1钻孔后处理代码
8 f/ R! ]7 j# V% Z& a
: {) i+ ?6 E2 k) x8 h********************************************************
* i5 x$ i: v3 `8 eCYCLE: ON:
5 ~' d. M& Y- R, V*{{ GPP range check
; c, S, s) w0 l! e*}} GPP range check* j: |; E" {' b# c; Z
FlagSpin = NO ;
D+ ~, [$ @; ]. W+ [- G IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;" [7 v1 m) j$ A) i- c
IF_SET (SPIN_DIR) FlagSpin = YES ; END_IF ;
& _- d: ~- p9 W* j G) n0 r" A" i IF_SET (FlagSpin _EQ_ YES)
8 A: B" U8 W5 X. m$ ^) n0 C5 f+ P8 ] H: s4 V
SET_ON SPIN_SPEED SPIN_DIR ;; g+ \. B! f5 e3 x; f
END_IF ;
' E S6 y- [+ j1 f, q0 Q, G0 @: c2 l) I
SET_ON X_CURPOS Y_CURPOS Z_CURPOS ;( n, [' z6 `% a6 F5 p8 u! x' V0 w$ Z
SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED ;
, i G5 P: n2 t& l3 K SET_ON Zinit Depth Clear ;
5 v; ]" I J( w& ] Zinit = Z_CURPOS + CYC_DZINIT ;
0 U3 v" n' ~; h4 |1 Z& m) e; } Depth = Z_CURPOS - CYC_DEPTH ;2 a9 | h8 I! ^" Z- f
Clear = Z_CURPOS + CYC_CLEAR ;
5 O/ j E2 R2 |% Q0 Z IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00Z" Zinit ; END_IF ;( P# H' V& W, I' ^# t
6 \# N/ {& W, |& v0 w
OUTPUT $ ;
+ a# k0 W( H4 ~# K" e( R* l) J6 ?0 m4 w _$ z
OUTPUT "G00";& p* ]# l' p; ~8 K( q5 S
2 o4 a) U" t5 P; m. h OUTPUT "X" X_CURPOS ;5 V& g0 d- V( { b: z
$ P" p' Y, w& S- t. L5 a: h
OUTPUT "Y" Y_CURPOS ;
) ~ g- N) N4 I1 v" Y% F OUTPUT "Z" Zhome ;5 }% k: V% N% I9 a& J
OUTPUT $ ;6 g6 H& A$ a& G8 Y$ T2 ~3 n
# I; E5 U5 S- E- K, f! v- c. D8 `7 U7 J6 h" @1 L
) F* n- A/ l8 c! C
OUTPUT "Z" Clear ;
) x7 V7 n" f. n" @1 O+ e7 `4 u OUTPUT $ ;
* ^( C8 \# j! @+ ~6 [2 z" P. O9 X6 M
" ]$ D+ b/ z5 V1 j2 S' M$ }9 wIF_SET (LIN_MOV) OUTPUT LIN_MOV ; END_IF ; [4 C0 `0 x4 E4 u7 q0 U5 \
6 U0 _. e$ Y) E z2 q6 s- u
OUTPUT "X" X_CURPOS ;; [4 g3 w& C3 m/ n
5 a5 o3 D" h! B
OUTPUT "Y" Y_CURPOS ;; C1 ]1 i+ Q. ]& R8 V
/ v9 Z) O# p5 V' C" d
OUTPUT "Z" Depth ;, O9 c3 l* a& H( c0 W7 P
$ X. M9 n7 T. n# F' s9 ~
OUTPUT "F" MCH_FEED ;
& R; w8 ]0 m' l" l- {: l# ~5 G7 B4 \
SET_ON LIN_MOV CIRC_MOV ;
( m/ Y5 R8 J3 p4 y6 F3 u SET_OFF CYC_DEPTH CYC_CLEAR; ; @0 F0 T R3 q3 ]
Xold = X_CURPOS ;
' n# @! x; l/ {2 K7 d Yold = Y_CURPOS ;
5 `4 q# @3 b1 B) ?5 H, f6 I1 S Zold = Z_CURPOS ;4 U# n6 t( d2 v7 g
p4 X2 X" r8 f, I3 wCYCLE:' d( t8 G- e- G. k% S
*{{ GPP range check
! Z$ D1 A3 L& {# Z, P*}} GPP range check
1 X ~/ a0 r6 t SET_ON X_CURPOS Y_CURPOS Z_CURPOS ;/ C/ I. c$ I4 t( f4 p+ J
SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED ;- l+ D# P, n- d$ L. p
' f% b! |9 v8 X: W) x$ O' @7 t Zinit = Z_CURPOS + CYC_DZINIT ;
3 ]5 ^4 D% Z& Z8 S Depth = Z_CURPOS - CYC_DEPTH ;/ T- n% w: n% _7 G
Clear = Z_CURPOS + CYC_CLEAR ;; b0 y }) H/ ]8 ]! V3 ?
IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00Z" Zinit ; END_IF ;0 S8 J8 w" n- [6 [% m
OUTPUT $ ;8 G4 Q6 Q5 `3 x* [6 i4 q! R
* y% T2 Z7 i$ O1 D7 q1 C
; U$ m, ?+ R% G; |0 Z
) X; x& `0 s& I1 S; G' f; Q OUTPUT "X" X_CURPOS ;' E) s6 q$ O4 j7 p
" m" E" o- k: R0 Z3 w5 a9 A9 T
" Q" S) b! j0 |' W OUTPUT $ ;$ k/ i2 e! ^# [- `3 H
, F* P5 \, m; C% }
: w- |# q& j+ }* O- F
' z* N# R3 H: R& ~: P; ^( y/ U( X+ s OUTPUT "Z" Clear ; I$ _* P' x0 \
OUTPUT $ ;
6 l+ d1 M; z% K4 K I/ O1 ?6 M) r3 F. W9 J
% O: g7 Y! ~8 E0 D+ U7 w: T! `/ H, P0 V" b+ l. e
OUTPUT "X" X_CURPOS ;1 P! \$ I! z \! p2 e$ P$ F
3 v, O4 o- r7 F3 I2 s" g
OUTPUT "Y" Y_CURPOS ;! p3 f8 r* M" o! ~. F+ G4 L1 F3 I: X
- `2 n: c( c; H4 q5 {
OUTPUT "Z" Depth ;
8 ^1 `- {# b+ Z! F4 c IF_SET (MCH_FEED) OUTPUT "F" MCH_FEED ; END_IF ;
" ]2 K5 ~ |. r C2 w7 O6 o# X
( K. i1 l9 Q+ G* r& v SET_ON LIN_MOV CIRC_MOV ;+ K. X2 h$ |" ~* g* O4 T& D5 D
- d: [: w: K( }7 E Xold = X_CURPOS ;
% n ^/ A! h. U Yold = Y_CURPOS ;
* I# T3 x' }$ S" d" w Zold = Z_CURPOS ;
# m' S( d, v' o- z0 Y1 w' _0 |8 A) p2 o6 l4 G: h, v2 ~, P
CYCLE: OFF:% {1 o* s% @6 T+ h9 m6 e/ T S3 p
*{{ GPP range check
; h" \. w8 b; }% ]) M4 N( [*}} GPP range check
2 Q5 O* f- D5 N+ s. r OUTPUT $ ;4 k* \- D) e0 ?/ }$ r0 D. a6 [+ ?+ }! k
OUTPUT "G00Z" Zhome ;% U, S h5 W8 N" V9 e% T7 E
SET_ON CIRC_MOV ;& e; r7 `$ h/ {. w
Zold = Zinit ;
& E4 N" w& z0 \6 s' [; y2 p8 k7 P+ R) O$ y! [
