发表于 2011-6-7 18:09:37
来自: 中国浙江杭州
Important Note: Files created or saved in Mastercam X5 are not downward compatible with Mastercam X4. They can be saved to Mastercam X4 by using the Save As function with the version on the options page set to X4. When saving an X5 file to Mastercam X4 format, all toolpath information is lost, only geometry will be saved. The same holds true for all Tool, Defaults, and Operations libraries and all Machine Definitions. Please read the What's New carefully to know how to update Mastercam X4 files to Mastercam X5 and make sure you have backups of you important files saved.
4 B! z; J' d3 ?这是官网下载页文件右边的“info”,相信你看的懂,X的各个版本文件不向下兼容。 |
