查看: 4326|回复: 7
[分享] Solid Edge ST3发布补丁MP6
发表于 2011-6-18 18:45:05 | 显示全部楼层 |阅读模式 来自: 中国浙江丽水
Solid Edge ST3发布补丁MP6' ^+ _4 k+ s: B- r7 I, V
% N0 l6 }$ `1 q9 [) y
Dear Solid Edge Customer:
' d* k: |% c% L6 G! T
We are pleased to inform you that Maintenance Pack 6 (MP6) for Solid Edge ST3 is now available for download on the GTAC FTP server.
! N# e# s0 i0 _: R6 F# d
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
' ]0 n8 g6 p) F; N% ^
Sincerely,
7 g  ^" n& L3 j) F6 z& i3 ~' f
The Solid Edge Team
3 V8 {; H7 R4 B6 Z' |* l" H
* T6 Q. `. a7 F: Y
Download Location:
; N  n4 K* o/ u
  g- B3 w; P" I6 v9 |* I+ k
Solid Edge (Maintenance Pack)
) f2 V$ W) J' T2 W
) J& q# g/ C4 r4 F# |
Solid Edge Insight Connect (Maintenance Pack)
) {- h0 ]: i: h! g2 z4 n  J
; k) k9 R' @/ u- q8 m, d5 ^
Solid Edge Viewer (Maintenance Pack)
+ i! U2 W: s* [$ P3 C, n7 u; ~% j& P+ I8 h1 z
Solid Edge Mold Tooling (Maintenance Pack)
# a9 [+ G+ C- D& F7 C- p
" M5 \+ J: X* M  X% Q) Y4 p
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
" D7 I& ^4 D4 o4 n. N0 ^( k" I  t
Solid Edge Insight Server SharePoint Foundation 2010 (Maintenance Pack), R/ u* J% t, ^
http://ftp.ugs.com/solid_edge/ST3/InsightServerSharePointFoundation2010/
5 i' N2 Q8 Y$ g0 s1 H
Solid Edge Embedded Client (Maintenance Pack)
9 M: e) Y& v& B7 w9 }3 a4 Y, k+ W% w. W- U  f
Solid Edge Embedded Client Structure Editor (Maintenance Pack)
9 S7 X, w. S. w4 R* l2 V+ M
( {3 ?" V/ q; }
Solid Edge Embedded Client Administrator (full install)
- G% h' L: c7 u2 f/ ]' q/ d5 q" A  B
  a: {. X+ z' R' l, T, D0 ]
1 t3 j6 \& B& e( k
Installation:
5 S4 C6 r6 }8 {# T3 _4 S
; Z2 n+ q1 Z6 ?  q# d, _' F! w
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
# @4 q4 S, b" t8 u9 Y
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
( V/ V% V0 ~2 L
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
  b! O& Y% ]  D# r" w) E& q
; i& V( a( a: z' ?5 T
E-mail Notification:
+ u. D( i8 l* I2 G- b3 Z+ H; G
9 F7 s2 g9 i" D7 {  K2 Z& T$ l
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
( h% w1 Q$ _6 J8 T
4 f$ ~. b6 s/ i% r  I& o) N+ b) d* _
This Maintenance Pack addresses the following PRs:
1 N: v1 q2 ?2 T* v
& ~4 s/ p+ O7 z
===API===
; I( Q- B! o1 `* c# i# M7 p6 R8 Y
PR 6525375: BalloonDisplayedText showing symbols instead of display values
6 n1 m2 D% _1 t+ }% U: p
PR 1845612: API method SeekWriteAccess doesn't work properly in ST3
8 ?/ }! E, G; B) R9 N
===Assembly===
7 z) w4 T) L' k: r9 F
PR 1819823: Cannot import STEP files
6 v1 g& b3 V( y9 ^5 i
PR 6482973: Assembly relation tree in ST3 obscuring selected parts
9 Y! P4 K3 O3 ~' L( I5 F# U5 l
PR 6524547: SESysInfo reporting negative memory value for graphic cards w/2GB or more onboard memory
8 c7 v) f+ i4 W% D) I7 {" {; n
PR 6530354: crash after editing connect relation
  A  V, }( `4 b$ O5 S; ?! o
PR 6530975: Check interference doesn't consider weld features when selecting subassembly
% ^# h6 q- `8 P9 c  z! n
PR 6532294: Relation Tree not showing document icon
5 N) j) h1 S; K; v
PR 1822686: JT file will open in Traditional but will not open in Synchronous
5 d1 I: y3 e) Q
PR 1828686: Missing parent for sketches in an assembly are not reported
6 j, H9 S3 I/ B' W4 ~
PR 6425708: Reference plane not hidden after exit of Assemble command
+ p, Y7 B7 G, E& U/ v- J9 L
PR 6468554: Missing files after import of a X_T file
" A; t8 I: ?6 _5 G" r
PR 6489805: When using Publish Virtual/Publish SE aborts
5 O6 |' s: L% j( Y
PR 6533309: Abort when adding assembly relationships
( w# D* B1 j: |- }+ w/ f1 `; {, R
PR 6534186: Rotating an assembly causes assigned textures to change color during rotation
% }) Z& p. X$ s. A
PR 1828736: Long beam is not cut to C channel profile (frame module)
4 F% ^. W/ S4 [' w& [
PR 1845357: seCatiaV5.exe crashes
+ B* P5 V" F/ o5 E7 Q# S
PR 1849144: Unable to finish tube placement on German OS
7 q/ Z4 p4 M7 l7 M! h; J8 L
PR 6443468: Batch translators are not generating output
8 k3 z6 B$ N; r- N/ S6 l
PR 6484486: Cannot export Solid Edge files to STEP
+ i7 j8 \; Z% W" Z$ O
PR 6534753: Application Display settings will now properly detect the new Intel HD Onboard driver
7 b1 h4 f. Z6 l2 u& j) U
PR 2169599: A fully constrained assembly becomes under-defined on flipping to rigid from adjustable
! |1 P9 E5 p" B3 P
PR 6471511: Unable to Translate Inventor Assemblies with Data Migration tool
* k( _* H  \2 S; X2 n8 A! D
PR 6535868: List Control tab options are enabled with 'use assembly item numbers' is on
& ^/ T2 f/ T2 r# H0 {
PR 6541886: Crash at: OccurrenceNode::GetSite
) Y9 p" r! e: ^7 x- Y9 p, H0 w( H; m/ l
PR 6550314: Crash when activating assembly parts via the pathfinder
; a" x3 G, W) m. m
===Draft===
$ P$ c  k+ X/ s  r
PR 1844982: "check config" on drawing view properties was not working
) U# I* d( f/ `3 S! }& |
PR 1846422: Parts list quantity is incorrect when using assembly item numbers
2 B. H2 X! j4 Z* w0 l, M# t
PR 6458478: SE crash occurred while inserting image in draft document (Workflow specific)
$ o+ i$ m. ]! L( v3 Z1 x* Y
PR 6484441: Reference dimensions have extra brackets when exported
  |# J# \" b& D8 b' _3 e, c) O* N5 `/ B
PR 6531106: Fixed crash identified by crashlog at: HGetQuantityOverrideFromOccurrence
* k# ], `3 m$ A' q
PR 1819327: dxf_Export is not including some crosshatching
7 \0 F; o3 n0 j) A6 p' p+ j3 C! l
PR 1822869: rotating the contents of a draft file causes Solid Edge to crash
7 b' f" \7 V( w- [* e  I
PR 1823915: Cutting plane lines are missing in exported AutoCAD DWG file
# |6 c! F3 e7 j1 n/ V
PR 1830725: Parts list has an asterisk next to the item number
( m$ |' c6 l* ^; s
PR 1833156: the drawing view "show fill" option not honored
9 k# X0 q* b) L, y
PR 1836348: It's necessary to click twice on Break Line option in the Callout command bar
) l0 m5 H6 E% t/ `: I  t
PR 1843290: Symbols not placing correctly when Inserted as Geometry
# V) f3 L0 n+ u3 _# ~
PR 1847031: Geometry in a 2D Model view cannot be moved/copied, huge file size
$ ?# @, E7 [; L  U. @& \
PR 2165599: Can't maintain separate grid settings when two draft documents are open
( A% y7 Q$ H- |$ U" ]* i3 f6 `5 Y3 C
PR 2165638: Existing Solid Edge draft template issue in windows 7
  n& H+ l& y. v! X  u
PR 2166696: Dimension tracker copy to clipboard is not working
$ k1 B# t7 s4 Y" G1 V% N6 E
PR 2168599: View not being refreshed after activating hidden layer
( h: T- {+ Z- d) |0 B, ^% Q6 T/ j
PR 6419394: Opening of 2000/2002 DWG file does translate any geometry
' V  l' i' e/ ~2 P
PR 6438019: Trim Corner selection is picking the wrong line
0 ?. a# B+ Q& W* f1 T1 W
PR 6487857: DV tracker update instructions were incorrect for part copy
1 A0 n, S, ]9 F- F0 w! D
PR 6529930: Detail View Caption can't be moved correctly if envelope is an ellipse
4 y3 |  _' I% Q6 Y( a
PR 1826475: Selection mode remains active after balloon number change
9 t8 m* a+ h) O: O" O
PR 1817696: Embedded Objects are exported to DXF in the wrong position
; a6 u8 R, [+ x8 g9 I9 {
PR 1824327: Fill Text with Background color rectangle position incorrect
8 d$ e; a9 _8 O: H/ U
PR 1832830: Seacad "template file" is empty if you don't go through seacad option steps
& W1 c; ~# ^/ y4 b& [" {' A
PR 1833975: Attempting to open a dgn file aborts if the look in button is selected
0 q% Y5 \1 j& \
PR 1840830: DV caption is exported to layer "0"
+ p+ U9 \5 C% Z. c% b3 F* _
PR 1842175: Cutting plane line cannot be selected with "Active Layer Only" option
0 q6 P: ^$ I0 R( i0 o# F
PR 1847435: Tab key function for upper and lower Tolerance needs to be sequential
1 t6 c; t& C( {2 ~8 P
PR 2167888: Right Justified callout text is scrambled in .dwg
; s* a8 K" `5 z4 C/ i+ X& o+ V
PR 2169063: Starting location of offset thread not displayed with solid line
: _5 F! q* s9 I, z" `: S# V  j
PR 6511394: Prefix copier doesn't copy the tolerance type correctly for Class tolerance
+ ], i9 X% D' u% S
PR 6535524: Parts list does not honor property text formatting codes
+ d2 Z/ R# K" \3 d, p. \/ Y- D
PR 6536661: Parts list reverses order each update if renumber and sort by item descending
& K0 N# v7 x, a
PR 1684703: Sketch in a section view was not sectioned properly
, n; h- H* r2 {
PR 1823726: Text placed in rotated drawing views is lost after SEtoAcad translation
4 W8 K" x& I* n$ l# m
PR 6541869: Crash at: JDimChainAngular:isconnect
- t$ Z9 x+ M0 m4 P5 V- a% X/ ]% s
===Insight/View & Markup===
8 S2 ^/ F: S: C0 n8 r+ Q
PR 1842460: Cache Manager does not work
8 a2 \3 }+ p+ o$ U' U: J/ \( M
PR 1846854: Assembly doesn't open - No error message
- I* |1 r+ @% `- t1 _/ ]
PR 6461727: Search not finding Custom Properties
: S. ^* @' e4 P' H4 F
PR 6332833: Insight Web parts: The Viewer MP's are not getting pushed to IE clients.
" v$ Q- D4 @$ R3 v3 h6 ?1 p
PR 6399126: Insight connect crash occurred while saving PCF file (Workflow specific)
/ t; @, U; L, R& d0 l2 D
PR 1845749: Calculated Columns will not sync anymore
7 C6 M% d' Q# I' A4 w$ s# G* X
PR 1835210: MP info not shown in View & Markup/Help About on 64bit computers
9 d' p+ {- _" S# M6 z+ L4 _  `3 \
PR 1835727: Incorrect characters in SEWebParts on Insight MP3
, F* Y$ \8 ^1 U: x0 V# [
PR 1840719: Error Message when copying Excel Docs within a Asm Structure in RevMan
: D7 _  P3 g& ~1 w* d6 E9 D
& h, ~) z# I# }' y' m
===Part/Profile/Sheet Metal===
% L! s1 l: e$ h- u  j1 l% T
PR 1783293: File open dialog is slow to show large folders
, }% a2 U; K7 y9 y1 @( x' Z: w: B3 N
PR 1844377: PartCopy from an assy will only work if the assembly is also opened
2 i8 A7 N5 r: K% ~4 k- l+ B9 ~/ j
PR 6522205: Abort at JUnitsOfMeasure::~JUnitsOfMeasure
+ e% W' |3 O0 c3 R6 L8 [
PR 6524170: tangent relate failing when the elements did not share an edge
9 N, T2 U# ~$ @, F6 ~3 ~
PR 1823155: changing the value of a round using all available memory which results in a crash
( P6 M! u6 G' \9 o1 V
PR 1843475: Flat pattern from mirror is different from original
, @7 {) I/ [) ]# D
PR 1845013: Hole Feature will not cut through the part
" g! _; V; D, D  f# j8 \. R
PR 1842597: Ribbon bar added by custom add-in is not customizable
; q8 z+ ?6 l3 x2 _+ g7 j9 _
PR 6534273: Sync threaded hole problem when using saved settings
) J) {2 D" v- }1 H4 V  ~2 ^2 y) y
PR 1847811: Ctrl+A (select all) in Profile environment also deletes synchronous body
, z2 N& E8 E6 Y* [
PR 2170648: Selecting User-Defined Sets causes an abort
2 @1 @& f$ _/ ^7 Z
PR 6441781: Binder names not all converted to Unicode, yielding garbled display
4 S6 L, I0 |3 K$ E- e: m
PR 6522975: Crash when performing an undo of a move to sync
2 @* {; j# Y9 ~5 U8 W1 _
PR 6532739: Crash at: JMostRecentFiles::Add is at top of the stack trace
1 `2 s% A  V* ]" M7 r% B1 t
PR 6537877: Sync Pattern does not create all occurrences
( O- x3 _% F9 P$ \* |, s
===Solid Edge Embedded Client===
, F7 w- \/ Q2 B+ P* n8 @5 t
PR 1800213: Smart Codes form is locking up when saving a new file
4 c( \, V5 Q* n2 U
PR 1834093: Wrong dataset name is used in ST2
* W/ t) C* q. w& l! b8 m# O4 l
PR 1837961: Automatic update of linked NX part does not work correctly
/ ~, p& V# q+ O
PR 1838542: Revise non-default dataset names are renamed to default.
) c9 s1 Q2 @. P: v5 M2 d
PR 6528853: Couple issues with assemblies and missing components in SE & replace part
- n, ?5 I: x" d7 O
PR 6495119: SaveAs of a FOP master and select no to copy links copies the links anyway
% K! `% w* _0 v0 _, }  x
PR 1844966: Time to drag and drop & open from the Edgebar takes too long
9 {, B: T; Y0 w. \
PR 1845018: SEEC Create in Place does not show default values of mapped properties in CPD
4 _5 Z& T# Z& h( a
PR 6482635: Unable to Save As FOP member in Structure Editor
& l' S% N' M% Z1 Y, Z
PR 6484834: CPD is not renaming the Item Revision properly for the Dataset Name
$ g9 P9 g; v5 T1 o
PR 6448444: Structure Editor is not displaying assigned LOV when creating New
) L# n8 p- Z( z
PR 6530136: AddToTeamcenter is clearing Document Number value during Dry Run
" J) I4 ]' J  H2 K
8 Y- ~; W! m. J
PR 1847283: NULL Attribute Values not honored
$ T1 P) {) x! R
PR 6492500: Save As behavior in SEEC behaves differently to Save As behavior in SESE
 楼主| 发表于 2011-6-18 19:05:03 | 显示全部楼层 来自: 中国浙江丽水
玩一下神秘。想看下载地址? 方法如下:
, D* z! e8 o# c  f  \4 x  ^. m
- D/ v) d# J7 Q/ Z/ B0 x4 l" x9 H3 G" m- r' G! J
# ?4 |8 \0 |; S
按键盘Ctrl+A
发表于 2011-6-18 19:40:35 | 显示全部楼层 来自: 中国北京
楼主玩花活,不方便啊
发表于 2011-6-18 23:45:15 | 显示全部楼层 来自: 中国江苏常州
说是要帐号和密码的...
发表于 2011-6-23 08:18:04 | 显示全部楼层 来自: 中国香港
115网盘下载:
2 C2 ]* c$ g( C1 ]: O4 w# s: u1 r+ l$ H" b- q, o7 X
http://u.115.com/file/dns25xdl#' e% y2 E- X8 \7 E7 V0 z# n6 {
SE32MP6.exe
; O' W( l$ K" m; F+ Y
: K# j# r6 z2 n8 \" yhttp://u.115.com/file/clvmxu6a#
1 X  @* G7 `5 ?& \  l3 ^! YSE64MP6.exe
发表于 2011-6-23 19:53:19 | 显示全部楼层 来自: 中国陕西西安
115网盘下载:
$ a6 R  s1 _  @2 Z) J7 n" G* D# N3 c3 f! y/ G/ j; u- P. p1 n
& ?7 u/ d0 p* P; WSE32MP6.exe+ F+ [2 |) l0 o
* k1 `, K8 ~; c. }http://u.115.com/file/clvmxu6a#
" J7 p7 }( T8 t( L; @SE64MP6.exe
6 C6 s' ]& |6 j) h8 L3 G% j: U. Mwxxwjl 发表于 2011-6-23 08:18 http://www.3dportal.cn/discuz/images/common/back.gif
谢…………………………………………
 楼主| 发表于 2011-6-23 21:38:14 | 显示全部楼层 来自: 中国浙江丽水
哈哈。把俺的网盘贴出来了。
发表于 2011-6-24 17:00:36 | 显示全部楼层 来自: 中国广东广州
谢谢楼上诸位,辛苦了。
