楼主 |
发表于 2011-6-21 13:31:20
来自: 中国台湾
Hi,
/ D, _: o3 F: A. Q; v
" {* f- ` ?3 K* X2 J" qI am playing around a little to find out if I can use highfeed.
& K3 p. E, w8 l. p' F! ^So far I am encountering the same problem again and again.( O% ]3 _9 m7 f
- \; P3 u: }4 g# V5 e
When I use highfeed on a simple contour the last part of the toolpath is missing.
+ S2 C- R1 { f' }. d7 N4 uWhen the contour has several cut depths, all contours are fine exept the last one at final depth. Here the last part of the toolpath is missing... * D5 h+ g! A) q) `) Y' _
- D* z5 |5 z; [) J. u% G
Can someone explain me why this is happening?
. z' H# H9 A1 Z% e# T
, o2 G2 d3 P; P9 {I am using X4 MU3. Its not mine, I have access to it.
, M) i/ \8 o8 i* K! F% VIt is still in default machine configuration.
/ {9 j" \' ^. C" M
3 e) J3 f3 G( {5 j) h' K: V& F* lThanks for helping!0 Q5 a3 N9 [4 ^8 }
. J @# g7 l! rRich & j! [6 n/ C$ r" S$ k
我的問題和這位仁兄一樣 |
