发表于 2011-10-25 19:00:56
来自: 中国江苏苏州
Mastercam X2-X4 NetHASP crack without patching mastercam.exe
0 n2 E3 v \; J' Z----------------------------------------------------------------------------------------------
' v4 W, t7 s' g1 d0 h" k; ~& o7 B4 y
Why MC X3-X4 does not work with Emulator only without patching of mastercam.exe?
6 d" P1 p, r, [/ k+ M
# q2 ?, u6 A3 I u0 fCouse it checks computer for some "blacklisted" Emulator's installed. You can read what "blacklisted" Emulators mastercam search in Windows Registry in file 'who is who .txt'- a+ _0 v. C- `' I6 _
So if you will delete "blacklisted" emulators, clear a Windows Registry and install "not blacklisted" HASP Emulator you will be able to run MC X2-X4 without patching of mastercam.exe
2 t2 q: C5 a2 s7 e t
, L( u) h1 F- {1 r1 t9 FSo what you need to run MC X2-X4 with original (not patched) mastercam.exe) W9 `2 j! e; H3 m0 b/ W
* V4 A0 X8 b7 F/ H$ R
1) Unpack a folders "emul" and "remove_old_emuls" to your computer- l D0 Y/ W$ p, s7 Y
0 A0 ~* ^& @: p
2) Run "remove_old_emuls\delete_old_emuls.bat" to CLEAR a Windows Registry from "blacklisted" Emulators
* v& A3 @6 |- {& N$ J
: b* W# ]# K) Y9 [3) Register a corresponding dump (mastercamX2MR2SP1-dealer-unlim.reg or mastercamX2MR2SP1-industrial-unlim.reg).2 Y( a x6 E( n- y! y
1 K1 \+ R5 D4 H4 f7 W9 K/ ~$ a
4) Install a edited USB-HASP emulator (actualy it's the same USB-Emulator as befor, but it's service is renamed from "vusbbus.sys" to "mcamvusb.sys" couse "vusbbus.sys" is blacklisted in X3-X4)
- I0 _4 D- o3 H2 R) f5 Y5 m7 p9 w2 {6 K6 ?: m1 B# O& _
5) Install MC X3-X4 as NetHASP sim type. If MC X3-X4 was installed as HASP sim type run "NHaspX.exe" select SIM type > NetHASP, Mode > Local > OK
) M/ ^0 I* U9 C' a2 q4 A- W) Y8 a( y/ L
; X9 ^6 d6 T# y2 M7 ]6 A e: [& f( {) q- W
# d# s0 i- g! `' a( p
That's all |
