KeyShot 3 升级更新 - 3.0.99 PJ发布(2012-01-31 12:00:19)$ D3 V8 o+ u9 }
3 t7 W( X/ v" W5 c$ N; u
一个新的KeyShot 3更新版本已发布. 它修复了以下错误问题:! i, ]3 E5 Z6 Z& j
+ V! [; b% \, S) I
" L4 q" h* ^# A; ?4 b$ P3 U5 W) e- Improved reflections on rough materials
- Copy and paste of inclination animation type
- Fixed movie compilation error when rendering out animations in individual chunks
安装包下载更新 ) l9 ^/ r& ~5 Y3 E
完整安装包:- w' B' v+ O+ N3 u2 x
Windows 32 bit: http://download.keyshot.com/keyshot_w32_3.0.99.exe- N. o7 W& d7 ]" |' ]3 g
Windows 64 bit: http://download.keyshot.com/keyshot_w64_3.0.99.exe9 G3 v' i3 Q, I; A$ l( y# e
MAC OS X: http://download.keyshot.com/keyshot_mac64_3.0.99.pkg8 ^$ G% p3 _5 m% {! ^* O: z8 L
" ]% Q" y7 g2 ]! y
升级安装包:: ~* J# g( b0 _# Z8 N6 l+ [, j
Windows 32 bit: http://download.keyshot.com/keyshot_w32_3.0.99_update.exe5 g3 m% h1 d! c3 w$ N
Windows 64 bit: http://download.keyshot.com/keyshot_w64_3.0.99_update.exe
6 G1 p# m) g6 t& x3 lMAC OS X: http://download.keyshot.com/keyshot_mac64_3.0.99_update.pkg) g0 J" j3 Y* v e( f8 n3 I8 }
7 R, X1 Q7 ]' ^$ I {
: r9 t1 W4 h! j6 n9 D. `8 GPJ文件下载:http://115.com/file/be8gl2po# (仅PJ补丁文件)
1 G |! m5 l) S( r
+ g+ L5 H; I/ Y( H; S/ H如果你是首次试用用户, 请继续阅读. _! Z8 V9 }1 p9 w+ R: s
4 v* `" N2 s, Q试用版本限制:
( O- v5 c3 D0 Q: B' K' @/ |1 |The trial version you are about to install is a fully functional version of KeyShot except for the following:
; z3 k l! {' U% Q- Your saved images will be watermarked.
- You cannot save any of the scenes you set up.
- You trial is limited to 15 days per release (e.g. 3.0, 3.1, etc.) per machine
5 B, d S. Z% i y, e% h如何开始:5 q- @2 K3 a) [2 c! D. t* n6 v
- After installing KeyShot, the software will start automatically.
- Please select "Try".
- Fill in the information, and select "Activate".
- KeyShot will connect to the server and automatically receive a license. Skip steps 5-7.
- If a server connection can't be established, save the "license-request.txt" file.
- Send this file to license@luxion.com.
- You will receive a license file shortly.
1 A, ]: h# I$ `9 b你的首次渲染:
- [, t7 V2 w' K# hFollow the 6 steps outlined in the quick start guide found under the "Help" menu. We also have a getting started video you can view here.
: t1 D2 f# R! A& E" k
. }3 {% B3 X. Z' aKeyShot supports the following file types on both Mac and PC: - ALIAS 2012 and prior
- AutoCAD (DWG/DXF)
- CATIA v5
- Creo
- Creo Elements/Pro (Pro/ENGINEER)
- Inventor 2011 and prior
- Rhinoceros 4 and prior
- SketchUp 8 and prior
- Solid Edge ST4 and prior
- SolidWorks 2012 and prior
- NX
- IGES
- STEP AP203/214
- Parasolid
- OBJ
- FBX
- Collada
- 3DS
- JT
In addition we provide direct plugins for Creo, Pro/E, Rhino, SolidWorks and SketchUp. Please goto www.keyshot.com/keyshot/pluginsto download and learn more.% H c5 H+ k j2 B5 n. I
) K6 t8 ]4 J" W6 Z6 G
PC 机配置:
0 k; n6 m; Y8 P- Windows XP 32/64 bit
- Windows Vista 32/64 bit
- Windows 7 32/64 bit
- AMD or Pentium 4 processor or better
+ S) U3 ]8 v2 u
Mac 机配置:- @/ \+ Z* S8 {1 A2 ?; l/ o9 o
- INTEL-based Mac, Core2Duo processor or higher
- Mac OS X 10.5 or later
- 3 button mouse, incl. Magic Mouse plus MagicPrefs
3 A( k- v5 n) n, j+ R一般系统配置:
* w! y; i# p# {- Minimum 1 GB of RAM
- Minimum 500MB hard disk space
- 3 button mouse
- Monitor resolution of 1024 X 768 or greater
- Any graphics card (nothing special required)
- Internet connection for product activation
Enjoy!
) |" V: B9 \( s$ J/ L" p9 Y: N- S# b p8 [4 s" t* U, P% |
Your KeyShot Team
# o9 f6 L% u: q2 [For your records, here is a copy of the information you submitted to us... |
