查看: 4931|回复: 8
[分享] Solid Edge ST4 MP04 Update & crack (by SSQ)
发表于 2012-3-24 00:55:24 | 显示全部楼层 |阅读模式 来自: LAN
本帖最后由 solid_user 于 2012-3-24 03:01 编辑 1 }) J9 [% d2 n# d. J
' H, g# ]: Y0 w+ c. cIt's update only! To install it you need SE ST4 to be preinstalled!
- d; }4 e; R' \- v/ |1 A; _/ x( |/ |' S/ O& z4 D0 \: Q
u115
; [- P% f; n8 o32bit
' D& [9 a  R' `http://115.com/file/dp740ar1#' b3 Z% B+ G7 m4 l7 Z
64bit
/ o0 s3 i7 W/ s8 U3 Dhttp://115.com/file/c2pwtwq6#
( T; W, x; [5 }% e( G+ O1 Z" n
3 s6 m& X* E& k3 E& r' M3 iRapidShare
' d4 u. p5 P# b) x1 f8 k32bit
# r2 R1 n, y0 k8 sh-ttps://www.rapidshare.com/files/475979928/SE_ST4_MP4_32bit_Update_SSQ.rar' l# s8 E- w% Y& ?1 f, L6 u
64bit
; y) n1 V+ O  q5 N- A' ?# Nh-ttps://www.rapidshare.com/files/1955830271/SE_ST4_MP4_64bit_Update_SSQ.rar: D0 k# b9 b) l4 \0 T; X
5 f/ J" M5 H/ h4 GFileServe# O% Q* ~* B/ f' ~, P$ \9 o
32bit
# N, J% v/ e8 v5 vh-ttp://www.fileserve.com/file/9HvJMwV/SE_ST4_MP4_32bit_Update_SSQ.rar
' N8 @% H9 Z( @$ B4 ~64bit
# ^1 C& ]- K7 ~. s0 ^! ?! ah-ttp://www.fileserve.com/file/mrhKPw7/SE_ST4_MP4_64bit_Update_SSQ.rar
 楼主| 发表于 2012-3-24 00:56:41 | 显示全部楼层 来自: LAN
Release Notes:
0 \+ F; V( c7 O* S4 d2 \: A--------------  z6 t! J8 w5 f; ?/ f
! Y6 {7 C5 r2 e. Y5 {1 u* g
Product:        Solid Edge * y6 M* U; b/ a# S
Version:        104.00.04.05
% ^, H, t* t9 R: o) J) E/ d- F( ZDate:           29-Feb-2012
' Z+ R1 {8 C( s( T) j  ^. J, H$ }; o: ]# u+ n
Maintenance Packs are all inclusive and can be installed on top of the base
( \2 k$ S- q$ x' U' yrelease or any released Maintenance Pack.' s5 |& O, ]9 N- ^
# v2 k( u, A+ j& W: j# ]; c# F. a
This Maintenance Pack can be installed on top of Versions:
9 w7 n' O8 \% `! C9 Z* t" i104.00.00.82, 104.00.01.08, 104.00.02.05, or 104.00.03.05+ ?, Y: c* e& P9 d0 k. L
5 z4 c  z( ]6 l3 z. n) N0 A% l7 b) C5 m& Z  c7 Z
: U- u5 A3 B& `* \End of Release Notes
6 }0 _8 f% {" Q9 a$ A--------------------
' D" |5 H& p1 |4 y2 i" K: `2 Z" P! A. P% V/ Z
9 u% @8 P1 X+ K5 y1 JInstallation Notes:9 p( c+ j+ \9 O2 ]
-------------------. `+ }* j+ P5 s, w# v
) A8 `: ?3 p7 X9 xAfter downloading the Maintenance Pack to your machine, unbundle the zip file and 5 ]8 C2 Q; F8 \' Y. q  [' Y8 E2 x
then dbl click on exe to install the Maintenance Pack.) s2 n* B, m0 N% f
" x3 H, D( a. m/ d% h+ T% q' A# YWindows 7 Installation tips: In addition to turning off UAC, right click on the exe
3 P/ g( A* K4 u! L" Land select "run as administrator" to complete the installation.
6 F" n5 H0 I$ y! g) f# ]8 Q! |* \3 H  z
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing 7 m$ R) ~$ s6 E1 G5 }2 }7 U
Solid Edge somewhere other than the default “Program Files” folder. Install in a location 7 q7 z* N* q0 f  \4 m% `' B
like c:\SolidEdge\ that the user has full permission to write to.
2 V/ x) V3 i, A& g* y, A( i, C: i1 I% u
# O: O, ?) y& T! ]' QEnd of Installation
5 t1 g9 H* d. |-------------------
/ `  M6 G3 t6 `; E$ [/ e
$ P. U3 D: x7 I$ S. A( c7 l--------------------------------------------------
+ V* Z# R# S' ~/ Z# T* `& JThis Maintenance Pack addresses the following PRs:
! K# _0 H, b. I3 [* N--------------------------------------------------; G/ O: l! X: k* j3 Q
, g8 D8 b0 o2 v! y$ M
===API===
: ]% g( n+ o: W/ Y: Y/ \' h% B% a/ J' n
PR 2186499: Added ArrangeWindows API to application automation object
/ E- k' E+ {$ V& o* l( _8 VPR 1880652: Regression in ModelNode.IncludeInPartsList API
* `) e9 \2 z6 _( VPR 1870918: Error if use API function Feature->Item()9 Q/ j: A5 q/ [4 Z. h. I
PR 1866671: Skip the Query of non-need Parameter in API SaveAsFlatDXFEx
; f. Z" [6 E  _: W7 g' dPR 2185290: ReBend api fails  t' e7 m9 ]: B' ]  ~5 K) Q
3 H% y: U) }* ~. H" l===Assembly===
3 h4 G) F, f% m6 u/ v* h8 q7 e6 G6 s, d) [& H/ I
PR 1878230: Performance problem caused by a loop in the associated graph
  V" o" X# B# h. XPR 2177784: Memory usage goes up when you put the cursor over a Simplified Assembly
) X7 x8 a  C! L5 z1 D" qPR 2184189: Wrong fittings presented after modifying a pipe route
, W- [/ ?+ a+ PPR 6637551: pathfinder locate is not working in ERA manual explode command
  f( r% t8 \& VPR 1871721: Pipe route being offset after changing an indirect parent
9 o8 ]) f9 B8 {PR 6644521: SW Translator fails to translate Muti-Body files
2 c7 p3 @& ?7 X( X8 VPR 1873964: Web Publisher not working on a 32-bit installation
! K: ^: |1 d+ l* F  ^PR 1875446: Inconsistent item numbers in Draft due to replace
% B( d+ g' w* w+ S  f$ KPR 1884297: cannot reorder copied sketches in part pathfinder) E9 \3 M2 a2 Z3 c% B+ C5 O
PR 2180814: Editing this part file causes Solid Edge to crash
% y# a# o% T+ v) z! i- Q+ WPR 2183520: Resolved random aborts in draft 4 A7 R" b& p1 S! U. H. x  ~
PR 6587167: When transferring renamed components, they take on new names* C0 h* L! a: x' p6 V
PR 6621873: Weld bead leaks under part6 ]2 z9 U8 U1 p4 `
PR 1884912: Display clipping does not work correctly when assembly features are present1 Q- e; Z# n, X: |  K
PR 1682348: Assembly features not working on frames and normal features in subassemblies8 E/ z7 {& @  M( s, f! T, }. D
PR 1874030: assembly features missing in subassemblies of FOA members
" q" C2 L" K- [9 f# v( G+ vPR 6421755: Failed Constraints after Replacing Sub-Assembly in Assembly- j+ a& k4 b4 `" |2 G8 o0 F0 a
PR 6612747: Abort after using Animation Editor
1 k( E( ]# v* o; |/ m8 l
+ Z4 ]' G& V; S1 R===Draft=== % m! Y& f! y2 j8 J5 W# I" l
  q. V$ O" j2 A% H. p, S! y7 |/ xPR 1878737: Layer is lost when Parts List is opened in ST2 or later( D9 m% _4 e( G. J
PR 1879397: Empty callout symbol is visible on created pdf and print
9 G" y" @7 z, mPR 1882031: Scale moves position when legacy file is opened
4 K* N+ M9 I  x7 E" Z6 i: hPR 6607642: resolved random crashes& j; q  ~( h/ n: F) w3 O+ ]
PR 6629915: Length of Weld Not Displaying Correctly, and Draft Crashing9 K5 S$ [. c0 @$ d) A
PR 1878851: Property text doesn't update after change to parts list& Y& Q- m2 \+ ^! L6 o
PR 2186167: updating a broken view with broken out section caused dimensions to detach
; Z. s' N9 n5 q1 n7 n1 TPR 2188107: User painted edges are appearing in file open in ST3) f9 R# X+ N3 [4 k4 R# j) J( `
PR 1882594: Solid Edge is crashing when you rename an opened block
& Z6 g/ o; q, C$ l$ ?6 x- S! pPR 1884347: Format codes to modify property text output cause reference to change
8 t( R5 r  T. I' k: \& ]1 T5 @PR 2174995: some lines not displaying when the V15 draft file is opened
  b3 t9 ], \- TPR 6630591: Resolved a performance problem when locating callouts; ?* g, ?' j3 M# T0 v4 y8 F
PR 1883798: Unable to save assembly file to a 3D PDF with a D&D License
; h, o. i2 r+ YPR 1886005: measure area result varies in this file  }6 ~1 s2 l0 z6 W0 }2 S' z
PR 2174959: Unnecessary hatching is displayed in this draft file
* C9 r, f# r0 g! l* ^) x  w! a  WPR 6646879: Point added to leader can only be moved below the horizontal line
! d5 k& ^- a3 i# @4 p, M8 KPR 1883256: Multiline textbox from ST3 changes justification when opened in ST4
! n0 d; |' ?+ ]PR 6640013: Stretching Connectors locks Solid Edge
0 g6 u( l! u5 _8 MPR 6669348: DV layer override capability erroneously displays hidden layers% _1 ]6 W3 V0 M( D' ~8 E8 w" [- i
8 i  W: Y! H+ V. f( W" u6 J
===Part/Profile/Sheet Metal===
( C1 J$ t0 ]  r+ R  _; @
- ?; m1 |0 l! ]2 r+ gPR 1869930: Conflicting relationship message is missing * c5 Q* O# E" P/ G# Z8 e% V
PR 6645209: Cannot view unprocessed plots for buckling study$ V- F0 ~! |( M( Y
PR 6645361: Unexpected result trying to move a part face
6 F* h6 z7 h9 J- C, P) R/ h9 JPR 1880039: hole diameter does not match variable/ part/ draft7 k& c' W: n; I* R
PR 1884859: abort issue from add draft command
) E# j' x7 q: D; y$ R& z+ Z$ }+ uPR 6619201: Components not locating in boreline order from Assembly9 j- c8 k4 C1 A! T- W; W& K
PR 1880722: Mounting boss problems after modification
( [" c; U5 s* j' J' PPR 2187904: Abort when placing a coplanar face relate in Assembly" q  j; ?0 Z, ]' T2 P1 V
PR 6664590: Crash on Copy/Paste of dimension with class fit tolerance, e9 i3 M$ A, V; T! G5 W5 z
PR 6645336: Edge crashes on app close after going into FOP and AA table" R% \/ F& a# Q' o2 }# R" [
PR 1876381: Adding a cutout to the pattern will delete holes
, i7 ^* {0 z" C8 B/ dPR 6659724: Crash editing profile Dimple, Drawn cutout, Bead etc8 ?! ~! \  t, s% b
PR 6664695: c-bore does not update with transition to a sync part" |: p0 |0 X- v; O  X& r
PR 6669152: Cannot select nodes with Probe on one side of bolted connection# g5 O" H# e9 V/ U4 F
7 U) k2 |( K6 x7 h1 m6 {' b===Insight===( o6 y/ W- u* h% F
/ N* F. w- ^/ b* ]3 v5 BPR 6619831: ST3 is slower than V20 after OK 'Select Documents and Folders' dialog
7 I$ C5 g. ]$ v9 I6 Y) V
0 o- }& ?; C4 }5 D. J===Solid Edge Embedded Client===
) M7 e: i7 ^0 x5 @' v, o' {5 u$ V9 {
PR 6637263: Teamcenter error shown on saving a part file without assigning values to mapped prop
' h: L/ O* `7 i8 g1 n8 J/ w; tPR 6575712: Desc: SEEC Diagnostic tool in ST4 gives strange results
  \6 h# [. J+ D1 G# m- K' D1 tPR 6653508: SEEC Save As not working after upgrading to TC 8.3.3  ~: j% r% K) T* b
PR 1883259: Saving a Draft file into a Teamcenter with more than 32 characters crashes ) ]) G  C2 s7 m  N) _
# C$ V2 |1 g' o$ r0 H6 S  S% Q
% Z: }. l9 Y. i; I2 W  P: d0 q---
! d% O5 U9 R9 {+ YEnd
; J0 O3 ^1 Z8 v2 V---
发表于 2012-3-24 10:27:04 | 显示全部楼层 来自: 中国浙江丽水
下载并分享出去啦。
发表于 2012-3-24 11:19:20 | 显示全部楼层 来自: 中国江苏宿迁
多谢solid_user  " q; i) Z: ?: b2 k! U
不知道这次又更新什么了
发表于 2012-3-24 21:12:16 | 显示全部楼层 来自: 中国北京
thanks soliduser
发表于 2012-3-25 11:12:36 | 显示全部楼层 来自: 中国广西桂林
多谢楼主。! M  Z/ v; z3 N$ g) e% O
SE的补丁做得实在好,SW的动辄就上G不到SP5我都不敢下:bad
发表于 2012-3-25 22:20:04 | 显示全部楼层 来自: 中国吉林辽源
谢了!昨天下的 今天回复。
发表于 2012-4-5 11:18:03 | 显示全部楼层 来自: 中国广东广州
谢谢啦!好东西
发表于 2012-4-18 12:31:18 | 显示全部楼层 来自: 中国广东佛山
这个是简体中文吗?
