楼主 |
发表于 2012-4-10 20:20:54
来自: 中国天津
本帖最后由 86843173 于 2012-4-10 20:24 编辑 , Y6 m% L- V! X% q
( A& \% ]; E" O3 U我说的是车床4 P; e! W! {" Z9 ?# e" `- J, ]
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta$ W* ^7 R9 X3 A4 ~& [
# --------------------------------------------------------------------------3 g. O: I; f8 I7 x& x6 _) j
#Default english/metric position format statements' v6 y8 n8 m0 y1 F |% t2 w
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
$ E/ a- ?) I9 c# J( ufs2 2 0.4 1.3l #Decimal, absolute, 4/3 place
0 D5 S+ O8 p# y; g% ^. wfs2 3 0.4 1.3ld #Decimal, delta, 4/3 place
! W2 G$ o1 T6 Z& H" O#Common format statements
+ W5 [1 T5 R) c u9 H0 B) zfs2 4 1 0 1 0 #Integer, not leading1 C3 a0 @7 I: |; _
fs2 5 2 0 2 0l #Integer, force two leading
! g5 K6 V X8 L9 O3 Ufs2 6 3 0 3 0l #Integer, force three leading
6 h6 ^4 d: v2 d! X& b, o q+ cfs2 7 4 0 4 0l #Integer, force four leading
5 q% _, N* ] a" pfs2 9 0.1 0.1 #Decimal, absolute, 1 place
/ D/ n: D N# w& r- x4 o" yfs2 10 0.2 0.2 #Decimal, absolute, 2 place4 i) Z% ~8 q! Q% W7 @- V/ j
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
Q- _8 t) B9 Z2 Y! @1 X dfs2 12 0.4 0.4 #Decimal, absolute, 4 place$ z7 T( Y4 \- B
fs2 13 0.5 0.5 #Decimal, absolute, 5 place s3 M( X/ b3 e: N# [) o" ]
fs2 14 0.3 0.3d #Decimal, delta, 3 place9 J# h% u. C7 d+ y2 ?% E1 i
fs2 15 0.2 1.1l #Decimal, absolute, 2/1 place (feedrate) 就是这里
8 L) ^2 P9 H4 q: tfs2 16 0 4 0 4t #No decimal, absolute, 4 trailing' Q" h* _* h! |. }: ]; ?/ i I
#Default english/metric feed format statements- L9 i% j% O7 [: G. `0 _
fs2 17 0.2 0.1 #Decimal, absolute, 2/1 place
5 Y+ @5 D+ v$ Lfs2 18 0.4 0.3 #Decimal, absolute, 4/3 place
; I. D2 k0 x2 X; }% a* _' L- qfs2 19 0.5 0.4 #Decimal, absolute, 5/4 place8 X1 H2 n; r% w
fs2 20 1 0 1 0n #Integer, forced output7 o& b) q% B1 G s
# These formats used for 'Date' & 'Time'3 Q& D! }7 |8 n) O3 @# t6 J
fs2 21 2.2 2.2lt #Decimal, force two leading & two trailing (time2)
4 W- e0 W1 ?! f# G8 Pfs2 22 2 0 2 0t #Integer, force trailing (hour)( R9 N3 J. I: c o' l
fs2 23 0 2 0 2lt #Integer, force leading & trailing (min)8 V* `9 b- e6 J1 x' H
# This format statement is used for sequence number output
2 m8 k9 w; I0 p# Number of places output is determined by value for "Increment Sequence Number" in CD
) B! V2 D) i$ p/ B# Max depth to the right of the decimal point is set in the fs statement below
; Q. y% w4 r8 w8 [+ n/ lfs2 24 0^7 0^7 #Decimal, 7 place, omit decimal if integer value |
