发表于 2012-4-25 22:11:59
来自: 中国江苏苏州
这是最详细的安装I-DEAS 6.2 m0 说明
. t. S5 \" k, h- j( u仅供参考+ _4 @8 ^* @# d5 A4 _# b. ]( M, l
NX I-DEAS V6.2 M0 INSTALLATION, Y0 k" x. N; k; Z, \3 e7 G
1, in control panel delete all of these selected items:
) N- p0 s0 I$ O. k' za, I-DEAS NX series
+ j7 G8 Z" m% \2 I" W9 qb,I-DEAS Resource locking service/ p# ?" B; F9 Z p( {
c,I-DEAS SFAM component
8 \- Z0 w, J% l& L4 l2 ]& ed,Java 2 SDK,SE V1.4.2_05
3 @9 X: @: {+ W! xe,orbix
& a8 c4 R& _6 t, Y2,restart your computer
8 I; O- O, _: R) {6 f8 m8 ~3,Nothing related I-DEAS and java left& W, y: B3 U% i( F4 {+ B1 M5 R
4,delete I-DEAS related files in windows registry, use run “regedit”" L# @ j9 b9 d, ~& i8 N
5,begin to install I-DEAS V6.2 M05 x' w9 H# u3 Q' |$ j, Y
6,Do not install UGS license server! M$ R# S4 G) _+ j
7,install i-deas nx prerquisites1 b9 ~/ E8 L! G* [( s* i
Notice:1),change the path to what you want,remember ,Chinese path not permitted.(you”d better choose the default).
0 B5 o! s6 K: W3 e+ z% Y) r* U, u2),if you can not install this step, you maybe reset the windows system.if your OS is the Windows 7 (64bit&32bit),you must hold the right mouse, you required the administrator permissions before you run the programs.. $ x, o! ^/ _) _* A2 L# L
8,we continue to install environment after computer is restarted.
' _ m6 D& j: \* ?5 t7 v _9,install the i-deas nx serices setup.
6 e1 o% l& l: f+ j. p9.1 install shield wizard’s dialog box comes out in design product group select this 4 items(A004 Assembly set,you can choose the all if you need)..
# W+ R/ b' E5 d4 [7 |Select the language your OS used,if you are using an English OS,don”t need to seletct anything.(you can select the Chinese simplified and Chinese traditional.
/ g/ i- h$ k; z- ~9.2 in license server’s dialog you need change the local host to your computer name.; \3 y' P, i( N- o/ j5 a. Y
10, accept all the default items and finish the installment.
' U' `; A6 ]/ H5 v11,install help if you need it
0 V- t6 L3 S! x2 E# l, w; y12,exit setup$ J$ J, P7 `- y t+ \$ B
13, replace orginal …\lic\nxlic.dll with cracked one. Copy “nxlic.dll” to folder I-DEAS 6.2 prog dir\lic (by default c:\siemens\nxi62\lic)and overwrite orginal one.
9 a* [ `2 ~; Y: T9 R14,before running i-deas run”TDI Wizard” and install i-deas resource locking service.(continue to configure the team date.)
7 P3 n1 ^, B1 J% B5 gOpen TDI for mainmeau:1 }7 x0 ^% K5 A: F
Create and publish a teamdate installation
! k. o, Z! p/ h# G' O: Z$ x" |Set the team master ID:1/2/3/4 more than 1$ `5 w1 Z2 v6 F; u
Next you can default set,finish all the default option,5 u( x0 b! Q% w* z. p
15,enjoy.( f# l9 r# V! M2 O) l
Notice:that’all. No flexlm server or license are need.$ Z" o4 t3 @$ b
( Z6 }: q0 b1 z0 E( A" n$ w6 p
安装中最容易出现问题,建议重装系统后再安装。
, y' V$ M4 a- T1 z& A0 L无法开启界面,最主要的是NX I-DEAS resource locking service 没有开启,可以在控制面板 管理工具 服务中查看,可以手动开启
. b8 n" a+ z+ f% T9 n; J安装前确保磁盘文件中不包含中文。
+ F7 k4 I/ G. |; h启动时可以右键通过管理员权限设置i-deas在起始位置中指定默认存放文件夹,默认为空白。! q- r0 M- m4 F' G
新建文件名不能包括中文及数字。 |
