楼主 |
发表于 2015-12-17 09:18:52
来自: 中国安徽合肥
& C' J9 p4 Y3 |! S& ~7 f" x' K# z9 m, g" J/ N' o* Q% Z3 j
/*对话框*/- c F9 [; L) {& Y; g: a* P
shizi:dialog{& W a& | G6 @0 o6 T9 N, E
label="十字光标参数化设置";7 ^" P% ]9 o: y: D
:row{
J4 H: k K* Z0 \:boxed_radio_column{) B/ ?& M3 C g
label="图像预览";1 r! F- u( Q6 r2 ]" D
:image_button{
2 ~8 |1 H/ f; {" C3 |0 Skey="Kimage";
" ]1 {3 d( M E% Scolor=-2;) p/ B( C8 K2 f0 q; u1 A
width=50;
) R& i; R' J9 N# U2 kaspect_ratio=0.66;
# c* i. L( ^" P3 _" I4 M/ K}}}& ]0 Z- ? ?5 r4 H$ T
:row{9 k( d+ B7 @9 N
:edit_box{label="角度";key="ang" ;}
8 d& q2 K; E! c0 l7 K& f8 D" }8 o9 j, ~1 w
}: }5 k0 N4 ^0 ^0 o& `1 E( g5 e
spacer_1;; q. P! S' a" c# K: r
ok_cancel;
5 r8 e* @# V' D1 a$ W* ]}/ p. E$ o4 `) B# @
1 x( y' Q" }9 z U4 f2 C9 g" ?
/*说明此程序仅供学习之用,将附页源程序拷贝到CAD安装目录下的SUPPORT文件内,加载后命令行输入szg。*/
1 `7 p; r' V6 k. ^ ~8 Q(defun C:szg ()- U2 I$ d6 M& l% i
(setvar "cmdecho" 0)
4 c- X- d: T( R: B# q1 p3 n (dcl_tuxiang)0 p2 `0 O5 o. g s
(princ)
9 K5 d7 d# c4 c# P" E; o, A)
9 K& @/ X6 j' ^* ] Q(prompt "\n<命令szg> 程序设计 作者 yinchuan99001 2015-12-15");END
: R5 G; m. w H9 G, C;调用对话框子程序
7 K2 s! N9 e" \2 {6 m& A% {(defun dcl_tuxiang ()
8 e/ W8 R# R# ]% r+ ]& ^ (setq dcl_id (load_dialog "十字光标.DCL"))
7 C3 N% U0 v; M+ `- I$ f (new_dialog "shizi" dcl_id)
) x1 i+ {1 }* r& O V: d, ]& A (show_sld "Kimage" "十字");图像位置在AutoCAD安装目录support
: b" c x3 A' v3 d k (set_tile "ang" "0")9 k- X: w: H w$ N, W9 H9 u: y
(action_tile "Kimage" "(tu_xiang)")% Y) a! }: E1 G. Y
(action_tile "accept" "(ok_ang)(done_dialog 1)"): K5 h( T) e$ u% j" R6 S
(setq dd (start_dialog))
. n0 g! B, F1 b' R' T0 x( c (if (= dd 1)
! V, {* p# C9 o. q/ x! b: s$ r (nap) ; 调用子程序(nap)
, n2 m6 Y) e' X* c )
" ]( o! N: U; X1 q" K)
2 X T. O4 \; U% d* ~4 };图像显示
5 p; `0 B% F; l' P) B: R6 n2 g(defun tu_xiang ()
4 d5 v1 I8 a+ s* _0 } (show_sld "Kimage" "十字");图像位置在AutoCAD安装目录support
D, `$ z& k& a 7 Q8 M, ]: k0 N5 q' Q$ x, F5 G
), }, ~' X8 y+ q! B6 @
;子程序ok_ang
* p0 |, m# E7 `7 i6 c# k V(defun ok_ang ()" M" S1 C6 ?. y/ C e' a: H
(setq ang (atof (get_tile "ang")))
1 \9 W/ D, G9 h) s: Y1 m+ f5 ^
1 I* B/ b* b9 u)3 s( ]; x5 L( x7 Y
0 h' ]$ [2 M. T! A/ \4 x
;两个自变量图像处理" b4 n+ p! q" h/ }9 k
(defun show_sld (key sld)
: {2 ^0 f% \& J+ J6 D0 p! F (setq x (dimx_tile key))! w0 Z+ Y; B' b$ t
(setq y (dimy_tile key))1 T$ k# M& l' ~, M) V; k' e7 ^! U7 z
(start_image key)) ~7 } V9 I2 _0 N. m" U
(fill_image 0 0 x y -2)
- ^: A) N4 f9 N: {" r9 p4 ~9 |$ R (slide_image 0 0 x y sld)
* m9 _# g. w2 m) _. e, f6 b (end_image)0 E' D% Z! b! ^+ F4 I: W+ b. k
- m# i" Z# M% H M6 [/ K;子程序nap% y2 J5 b5 k6 R. v
(defun nap ()* S) B8 q$ y! M+ [* y3 O+ p0 A
9 a8 |& ]4 {& Y; V, @- D (setvar "blipmode" 0)6 v5 G& @- t3 M- F) w/ [
(if (= 0 ang)
: N, t, J2 K$ B' h: e2 ] (progn
# Q M; _2 o+ O/ C2 U (setvar "snapang" 0)
$ p2 {. D! [9 g6 ^: y )
* j' |7 K: |2 R, f* a (setvar "snapang" (* pi (/ ang 180)))1 n& [# D) K+ h4 Q
7 t5 f8 x2 t" w `) q. })/ d9 F2 |2 W3 `, m1 g: q# o
' C9 y' L: p* T0 j8 c5 h
6 l1 \+ J# y) c
% g- i/ B. D7 T0 L
解铃还须系铃人,上述lisp仅供学习LISP语言的同仁们参考,有不足或不对的地方请大家指正。 (若有引用,请注明引用地址和作者)
9 d7 {# ]' f- |
& w; Y8 h5 |; i9 v% L# z) E$ U3 J ^8 y
' F/ q& h* N6 [7 _& ]. ^5 k) Z$ z8 j( w( ~
