发表于 2013-3-21 08:44:29
来自: 中国广东广州
3 Y2 ~0 o8 I1 I* W7 X, N, c* m1 B4 W% E9 g! @9 e, V. p
一般用在加工中心里面的,看下图就是一种
% Y5 Y# k8 `8 i ^+ iContouring heads transform a horizontal boring mill’s W-axis quill motion into radial cutting edge motion, Inside each tool is an actuator shaft with an inclined key that precisely mates with a slot in a tool slide. Quill extension pushes the actuator shaft and causes the tool slide to move outward, increasing the diameter of the rotating cutting edge. Quill retraction decreases the cutting diameter.
% T7 l7 O2 T5 Y j$ w+ ?$ x |
