查看: 2276|回复: 6
[分享] 教你如何修改後處理來正確使用M14M15指令
发表于 2013-7-1 14:18:59 | 显示全部楼层 |阅读模式 来自: 中国台湾
+ T7 R' {* s. |& y9 J& x7 }
/ }5 Q. A/ \3 A- x- |8 y' [' C9 U這是適用於MASTERCAM 9 版的
4 O+ n2 z  R( l1.先開啟後處理文件MPFAN.pst或你自己正在用的後處理0 j: V, A9 f# U* p) c) [! ^
2.向下搜尋 sm09( Z" i1 ]5 ?" T2 Y2 s
( {- L, O& ~; [& H- f* \! S
sm09    M9      #Coolant Off2 _% I5 q/ P! h7 W# |8 b
sm08    M8      #Coolant Flood . Q& ?7 W9 j, }& z* ?2 ?; n% A5 k
sm08_1  M14     #Coolant Mist' C% [) x  U1 b! a% o& r
sm08_2  M8      #Coolant Tool6 _" `; g, Z2 o8 l' X
scoolant        #Target for string" M% y7 q% D, @" \" S/ \  ]+ m- e# k
: ]+ V9 ]% b% {2 M. @! M
替換成
- G  }; S' r5 w" S) c5 {sm09    M9      #Coolant Off
# v& d8 v4 R5 k% e" @- qsm08    M8      #Coolant Flood
+ y1 X6 T5 d5 u. `7 @, D8 ]  C8 W1 ~$ Zsm08_1  M14     #Coolant Mist5 d9 r, m+ ]' J' k4 n, m/ A- _
sm08_2  M8      #Coolant Tool  N/ _# D6 g# e& v& j6 O+ O$ S
sm09_0  M9     #Coolant Flood Off
2 w. g% ]# G7 e$ I; x% [sm09_1  M15     #Coolant Mist Off
# I0 [9 h1 f' J9 G5 i9 @/ Tsm09_2  M9     #Coolant Tool Off
" K, a, J8 a$ c* I3 A/ }; Bscoolant        #Target for string/ ]& b9 C! I: B. D' K# g
$ j4 }0 }. `# K
3.搜尋+ ~2 \% A0 g# h$ x
pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool, e* c& }' ~7 \& P3 |9 X. M% b
      , ~5 Z$ p. F6 C% ^* J9 X
共有兩處.............
! K  l+ c( k! j3 A/ V) \0 S在下面加入% i& r3 z$ D( t+ v0 H: d9 S  R
           sav_coolant = coolant
0 y: a- V- t1 q7 s           if coolant = 1, sm09 = sm09_0
3 V$ y( Y' [) c% x1 O# A) {           if coolant = 2, sm09 = sm09_1
! g  X# u) g1 H9 q           if coolant = 3, sm09 = sm09_2
: V/ _+ x. B  j" ?5 j! t- i) `3 P0 N" e' I  o: @  g
希望各位使用愉快.......
 楼主| 发表于 2013-7-1 14:52:54 | 显示全部楼层 来自: 中国台湾
這是適用於MASTERCAM X 版的
! O4 J- H3 W+ d- ?9 I1.先開啟後處理文件MPFAN.pst或你自己正在用的後處理
6 v8 N+ p3 `2 p9 z/ G2.向下搜尋 sm09
& [6 N! v4 o* I* t7 |2 L
0 Q, R, l) D6 D8 t$ I& j1 n; asm09    : "M9"       #Coolant Off
% r7 {; i2 i' w/ Gsm08    : "M8"       #Coolant Flood
; H0 o, N8 V: L5 o/ ^2 b3 osm08_1  : "M14"       #Coolant Mist/ ]* ~3 j1 y' [" v! M
sm08_2  : "M8"       #Coolant Tool
# m# v; z1 e% d* \7 i9 \+ tscoolant : ""        #Target string' n% p' ^% f: `  ?
% Y- w, ~0 M2 z2 }4 ]
fstrsel sm09 coolant$ scoolant 4 -1
. }* w$ }3 ~0 C8 s
/ K. `0 U# ~' h! {替換成; d9 P; F. H- u7 _& T! J
sm09    : "M9"       #Coolant Off, Q: a  _5 L  n2 Q8 l8 g% q: Q* ~% B5 ^
/ C- W7 m" L7 A& U$ @+ Lsm08_1  : "M14"       #Coolant Mist/ ]8 z& k. \: w( m( ~( j* t
- ]1 u" M+ A4 s/ \4 Ysm09_0  : "M9"       #Coolant Flood Off8 W& p  \' `) |5 [! W1 w
sm09_1  : "M15"       #Coolant Mist Off
7 P# K. T4 x3 I+ \0 D3 t3 Msm09_2  : "M9"       #Coolant Tool Off1 [# H; Z, f, G" [
" L3 `4 n9 x' R/ J% A% l' q+ B/ y6 f8 P- v- p
fstrsel sm09 coolant$ scoolant 7 -1: J$ `) P5 e7 s% g8 E
9 N- {. s& n7 ^) M8 j1 p3.搜尋$ P" ~! k7 S$ H" v3 L
      pbld, n$, sg43, *tlngno$, pfzout, pcoolant, pstagetool, e$# Q& p/ u( f( Y
% X# J7 o4 `  d: }8 M共有兩處.............$ S1 x$ g  {) C" J( Z! r5 h1 W
在下面加入
: D" z6 f8 a& R( T0 R           sav_coolant = coolant$. J6 P8 |* K2 M2 p
           if coolant$ = 1, sm09 = sm09_0
8 L) g( {2 S# L6 C, E           if coolant$ = 2, sm09 = sm09_1- E& w- s3 Z' J9 s7 g' ~7 I0 w. F
           if coolant$ = 3, sm09 = sm09_2
, H/ Z; I- w, H' {6 {
. R6 y4 U# q! t: ?希望各位使用愉快.......
路过不买 + 5 好资料,感谢您对论坛的支持!
发表于 2013-7-3 08:36:31 | 显示全部楼层 来自: 中国四川成都
gopc 发表于 2013-7-1 14:52 static/image/common/back.gif
( W5 T, N/ G/ d, |  y這是適用於MASTERCAM X 版的
; _  X+ B/ U, |+ g3 o; V1.先開啟後處理文件MPFAN.pst或你自己正在用的後處理
2 s  }" h) T# G8 |2.向下搜尋 sm09
# t- M, ]( F0 x; o* a' D# o# R* c谢谢,我想改成M10和M11,用这个方法是否合适?一直在修改旋转轴锁紧松开,没有实现
 楼主| 发表于 2013-7-3 11:23:31 | 显示全部楼层 来自: 中国台湾
有仙则名-数控编 发表于 2013-7-3 08:36 static/image/common/back.gif' @+ z8 W& u8 D. ~' S
' {* v3 R9 Q9 x2 \6 I. B
這我沒試過...你可以自己試看看囉...
发表于 2013-7-3 11:39:31 | 显示全部楼层 来自: 中国四川成都
gopc 发表于 2013-7-3 11:23 static/image/common/back.gif5 s4 E: I% T4 |! o# J6 |
0 t/ W; t5 U0 G3 T) j3 g
谢谢,今下午抽时间试试
发表于 2013-7-7 16:23:52 | 显示全部楼层 来自: 中国台湾
有圖嗎,新手不敢亂用
 楼主| 发表于 2013-7-7 23:13:49 | 显示全部楼层 来自: 中国台湾
yaolong 发表于 2013-7-7 16:23 static/image/common/back.gif, p7 ~% o# l/ T6 ]  |& ^
有圖嗎,新手不敢亂用
* C4 G, z4 ]0 c6 M: F" ]改好後處理轉出nc檔就知道可不可以....
9 K  E: _: ?! [" t6 l  v& W: D/ e& e" F9 K/ q
怕就用你原來的方式...
