楼主: laj
[已解决] 这个标注怎样完成?
发表于 2006-9-25 17:28:35 | 显示全部楼层 来自: 中国江苏苏州
清华天河有这样的功能吧,或者有编程也可以,不过我只会标公差
发表于 2006-9-25 20:44:02 | 显示全部楼层 来自: 中国江苏苏州
(defun c:pz ( / pt1 pt2 pt3 PT4 PT5 inpt pangle txt1 txt2 oldent leng leng1 leng2 newent )
, l  q) J& v+ q: ^" s. b8 G; n  (setvar "cmdecho" 0)+ j% I% B0 K2 t
  (setq pt1 nil pt2 nil pt3 nil inpt nil pangle nil TXT1 NIL TXT2 NIL txt nil pt4 NIL PT5 nil LENG NIL LENG1 NIL LENG2 NIL OLDENT NIL NEWENT NIL)
: c7 b" v- d" _; M5 U  (setq pt1 (upoint 1 "" "标注起点" nil nil)
' i* Q& y. ]9 p/ w1 q/ p        pt2 (upoint 1 "" "标注终点" nil pt1)
; O. ~0 Q3 m" L: D- W1 P        pangle (upoint 1 "" "旁注书写方向" nil pt2)- L9 i# g6 B% j
        txt1 (ustr 1 "旁注文本第一行" nil t)# n5 t1 @- \4 ^) h* n0 k! i
        txt2 (ustr 0 "旁注文本第二行" nil t); ^# P" Y: E: r  ]
1 c# d( S* F; K1 j  (if (= pangle pt2)
; {* S  q$ S7 H8 u" ?    (setq pangle 0.0)" o" ^; f& [8 ~8 X1 y
    (setq pangle (angle pt2 pangle))1 i* h( z  ~  |/ I: k/ p. @
0 v2 e# e3 c6 ~/ k3 S8 I5 N; o  (if (OR (<= pangle (angtof "45" 0)) (>= pangle (angtof "315" 0)))$ U& _. `7 F  E# V/ p5 _( V
    (setq pangle 0.0 pt3 (polar pt2 0.0 (getvar "dimgap")))
4 S  r: a0 @: y# I. [    (if (AND (<= pangle (angtof "135" 0)) (>= pangle (angtof "45" 0))), v/ m0 O' y# [% B; a, x8 n
      (setq pangle (angtof "90" 0) pt3 (polar pt2 0.0 (getvar "dimgap")))' E3 U$ f2 k7 ?# O+ ^% k" ^
      (if (AND (<= pangle (angtof "225" 0)) (>= pangle (angtof "135" 0)))" @, T" }+ E5 p5 i" T
        (setq pangle (angtof "180" 0) pt3 (polar pt2 (angtof "180" 0) (getvar "dimgap")))  t5 j3 x4 `$ Z) T+ i
        (setq pangle (angtof "270" 0) pt3 (polar pt2 (angtof "180" 0) (getvar "dimgap"))); B0 X- ?/ M. O- v
# \# B3 ]' N7 v5 r! u( z  N      )
) `2 ~" h, c7 B3 z/ i- }    );规范书写角度为0、90、180、270;# t5 ~1 k$ H& @" {8 z
  (setq leng1 (textbox (list (cons 1 txt1) (cons 7 (getvar "dimtxsty")) (cons 40 (getvar "dimtxt")) (cons 50 0.0)))8 |6 q9 {4 P6 p2 i5 k
        leng1 (- (caadr leng1) (caar leng1)))3 W8 Z- x' l9 f- m( ~' e' @& y
  (if (/= txt2 "")
: h8 L6 d! }$ _: L& c8 W/ B    (setq leng2 (textbox (list (cons 1 txt2) (cons 7 (getvar "dimtxsty")) (cons 40 (getvar "dimtxt")) (cons 50 0.0)))
9 ~1 p! j' V: B3 L$ [          leng2 (- (caadr leng2) (caar leng2)))
& e& N2 o" w. ]- u# q" k& E3 e1 l    (setq leng2 0)9 H* Z; O- ?. A' ?
    )6 u; p' I* B( J5 G
  (setq leng (if (>= leng1 leng2) leng1 leng2)), S6 w# L' [( c  B+ ~% J
  (command "undo" "BE")
2 i. }6 E7 Q: a  (IF (= (GETVAR "CLAYER") "标注")
/ |2 U1 j* ^1 w# n- [3 l    NIL. s& z! N' a+ j3 ^7 ]' t
    (IF (AND (TBLSEARCH "LAYER" "标注") (/= (GETVAR "CLAYER") "标注"))% M9 [/ C3 ?8 c- y
    (PROGN (SETQ CLAYER (GETVAR "CLAYER")) (SETVAR "CLAYER" "标注"))) n6 L8 v+ r/ n4 L
      NIL& f$ z2 }  n- z: L
      )4 \1 O9 l/ f& |$ I) G, I( r( T
7 l& c5 z% n- a! _3 t$ E  (if (/= txt2 "")  N& L5 _' \, M( d( A
    (command "_.leader" pt1 pt2 pt3 "F" "N" "" txt1 txt2 ""): b- i/ ^/ @" N
    (command "_.leader" pt1 pt2 pt3 "F" "N" "" txt1 "")
* K6 M: p% Z. |! |! s& P8 K    )
! ~! e4 {6 D7 s4 s: A) u6 O  (setq oldent (entget (entlast)))$ T% {) Z7 z5 |( l( K
  (if (/= txt2 "")' s" d' Z/ m- d. C( a5 G
    (if (or (= pangle 0.0) (= pangle (angtof "90" 0)))
2 }9 j$ I5 W6 D% f      (setq inpt (list (+ (car (dxf 10 oldent)) (/ leng 2)) (- (cadr (dxf 10 oldent)) (getvar "dimgap")) 0.0))
( z$ B* f% T# r9 ^1 J      (setq inpt (list (- (car (dxf 10 oldent)) (/ leng 2)) (- (cadr (dxf 10 oldent)) (getvar "dimgap")) 0.0))
" {0 ], n0 V7 M' j1 v      )  p8 [- _6 A1 X+ x% V# E" g
    (setq inpt (dxf 10 oldent))6 C& C+ m/ Y8 g4 j! L6 l
! n% K4 |$ c+ k1 W% r  (if (/= txt2 "")
$ j& v" k3 j  f2 N    (progn2 s) V4 Z0 l6 ^; l$ j( ?
      (setq newent (subst (cons 71 5) (assoc 71 oldent) oldent))5 ^& @. t5 Z- F& P
      (setq newent (subst (cons 10 inpt) (assoc 10 newent) newent)): W& P: f: R; A' w
      (entmod newent)
+ {  y( `  i$ _" J" M      )2 H4 }: ]  Y! D. q1 Y
    (SETQ NEWENT OLDENT)3 h7 W1 l: X. a, A
    )/ L- a9 L/ H. x6 n* C1 J! ^' _$ y  t6 u
  (entupd (dxf -1 newent))! `; s) I) r$ P6 W: }8 H* ~
  (entupd (dxf 330 newent))* j. N3 R7 l. s
  (IF (or (= pangle 0.0) (= pangle (angtof "180" 0))), X5 g# s9 ?* [( L( `6 W% W
    NIL9 K- z0 i3 U  i$ m, w- e8 D
    (command "_.rotate" (list (dxf -1 newent) inpt) "" pt2 "90")" ]# j6 d: ?! d
9 w+ x' H4 M$ v. p' @  (SETQ OLDENT (ENTGET (dxf 330 newent)))
+ J4 `) {: r( ]4 k4 j5 l. ~$ r9 N  (setq newent (reverse OLDENT))
" L; A% }+ z' d' V0 V' W9 A  ;(SETQ newent (vl-remove  (CONS 10 (DXF 10 newent))  newent))
! V: U' ~' e" t" z8 W  F  ;(SETQ NEWENT (subst (cons 76 3) (assoc 76 newent) newent))* C9 W: R8 P4 F' l$ A
  (SETQ NEWENT (subst (cons 10 (POLAR PT2 PANGLE (* 3 (getvar "dimgap")))) (assoc 10 newent) newent))$ l# H- B. a& _- H7 l+ W
  (setq newent (reverse NEWENT))
) n+ N) {* S5 I; [  (entmod newent)) v# Y  j0 _! I- b) A$ j9 u
  (ENTUPD (DXF -1 NEWENT))6 }. a4 A! r2 l0 K
  (SETVAR "CLAYER" CLAYER)  M: K3 ~' t" Q, [
  (command "undo" "E")) W8 Y9 E4 ]0 {* F5 h8 d
  (setvar "cmdecho" 1)2 P! ^5 @" D5 b8 a
  )* C8 A: l: u9 Y' |, w! e
( Q6 W/ ^+ E* C. ~' G[ 本帖最后由 szguanbo19 于 2006-9-25 20:45 编辑 ]
发表于 2006-9-26 14:21:24 | 显示全部楼层 来自: 中国广西桂林
我是这样改的红线部分我做了改动,不知是否正确,大家来PP
发表于 2006-9-28 15:27:30 | 显示全部楼层 来自: 中国广东深圳
我还是先标尺寸   再写字在下边哦       这样也不怎么麻烦啊
发表于 2006-10-1 09:40:14 | 显示全部楼层 来自: 中国江苏苏州
24#! ]  g5 ?1 N5 }) l* t
试了可以用1 t- v8 {; k* G1 O+ K5 k
不过我喜欢用CAXA,和机械工程师& @+ @$ b* V3 z/ B, N% L2 o% A
用了就没有这些烦恼
发表于 2006-10-4 15:51:11 | 显示全部楼层 来自: 中国
我也是先标尺寸后写字,没必要用二次开发啊
发表于 2006-10-13 15:03:18 | 显示全部楼层 来自: 中国山东威海
回复 #24 anant1 的帖子
我是个新手。我试过了,的确可以标注。但就是太费事。重新设置标注格式后,标注别的又要设置,太麻烦了。
