楼主 |
发表于 2013-9-24 13:17:04
来自: 中国浙江宁波
改成这样会有上面的问题6 H" k; w5 t: g- `8 l
FORMAT (USER_2) Fla ;
6 `8 n3 w7 d. Q( E' m) ?% z0 {& S' U* x
*------------------------------------------------------------------------------------------------ W* C1 ~, S4 p1 O1 T# |) W6 C
: X% D! ~+ V" R# n# y# Z ]8 Z! [
INTERACTION (USER_1) "3ìDòoÅ Main Program Number" PNum = 100 ;/ x4 q. ~! G( h- K3 T/ `
INTERACTION (CHARACTER) "êÇ·ñêä3öDDoÅ?Use Sequencing?(Y/N)" SeqFlag = "N" ; 0 G+ P5 R, S8 i5 H1 k3 ^ f
( P: d5 U' g, @
*-----------------------------------------------------------------------------------------------! z9 i9 u% V0 V8 g# F6 S; w& D9 y
) m( a# H; C3 ^0 c+ N6 I; P
MODAL X_CURPOS Y_CURPOS Z_CURPOS MOTION_CODE MCH_FEED ;) g6 i) p, U! N8 k7 l2 A P
MODAL CYC_RETR CYC_PECK CYC_DWELL CYC_XSHFT CYC_YSHFT CYC_RETR Z_CYC_DEPTH Z_CYC_CLEAR ;% B$ z, I/ e( C- y6 p- B6 Y+ _
MODAL SPIN_DIR SPIN_SPEED ;) k3 m5 @. X2 Q$ c$ N: Q8 }; Z
( ]3 `; c1 `+ [# {: U# O: ~- I" `& y3 d*-----------------------------------------------------------------------------------------------
" s5 y; P# [$ O- j7 O
3 ~& p, t( Y# ]+ V! C# v1 C2 a6 SNEW_LINE_IS $;* o+ n2 C# |" B* U# P4 B8 _
1 b. W: ~9 \6 n, K: l8 I. D
IF(SeqFlag == "Y") 8 b& `* Y0 y! Y v9 ~
OUTPUT \J "N" SEQ_NUM ; ! e4 e2 J0 A) h$ k9 \8 Z
END_IF ;
5 \7 Q- B) e- M IF (seqflag =="N")
1 E' X5 X3 h. J OUTPUT \J ;
! o$ y3 t5 A, Q- `) n- H1 E5 t7 | END_IF;
! u2 h& Y; d# J# G U + A4 T2 ]2 H' p& Z
IF(SeqFlag != "Y")
, S7 c& q2 ]; k/ q0 l IF(SeqFlag == "y") ( A/ u0 [' \8 f- h8 ^: s5 H9 o
+ b1 o* X+ o5 f5 e$ O1 s END_IF ;/ B; e. U( {8 K! e
END_IF ;( k. D3 K. ~7 Y3 L; _
. r) j3 b, D, p4 T IF (seqflag !="N")' P' A7 _) _: _% F
IF (seqflag =="n")
# }+ ~9 H7 ]. [: t2 V' {0 D2 } OUTPUT \J ;; C' a5 L8 R5 y; S; Y* o+ j! ^
END_IF ;) u, G; e2 ^# s4 a
END_IF ;! ~8 v. t* U/ b: b) ~
3 R, g6 N0 ~# Z f) e
+ {1 |) @3 T) r
: p U8 q7 }4 c0 U" ^2 uSTARTUP: P. d2 S1 J! W3 u' n3 B
6 D2 @$ ^+ j% A* B1 i: N
*-----------------------------------------------------------------------------------------------2 `: ?, `3 a; N
5 s4 s3 }) F- I# t l9 P
BEGINNING OF TAPE: 1 e( E# Y5 L" B1 S' y
* D) r2 N2 q+ w3 u x6 y0 c*-----------------------------------------------------------------------------------------------# a. O3 P8 H) Z+ l
" Z3 Y& }8 |% ?3 s* H
BEGINNING OF TAPE: aftercut:
\# k& F, N0 z) N4 ]. {3 }
4 \, |& L- O$ R, uFla = FALSE_ ;
2 q. B1 ]& p) `& G; v; Z0 A" n
5 z* @1 L0 b* Z. S/ i9 e*-----------------------------------------------------------------------------------------------) G7 a: [& _1 x6 N' K: n
4 O2 ]! t! I) a; B$ WBEGINNING OF PROC:- `" k# d9 Q$ i/ a6 Q4 b
! O- j; c( f# J% m! R
# |2 N# F7 Z# \: o- L$ j5 J, k; ]* V
TOOL CHANGE:8 N& I) k8 e; @% S+ J$ o
6 m! u2 h' L( g) }. `: ~ IF (QUALIFIER_NAME != "first" )/ _% p' `0 d, p% H) @
OUTPUT $ " M05" ;! D' R B+ y: j9 P {, I" S" D/ k
OUTPUT $ " G91 G28 Z0" ;3 g3 M) I7 h/ F- o6 {8 I
OUTPUT $ " M30" ;
! a+ {# J" g9 }; l! U& a; P! _; a$ k OUTPUT \J "%" ; ' n7 [) K' |- K, G0 M" `' |
CUT_FILE = TRUE_ ;
( _8 p$ W, O1 V. t S# j# E7 {( u END_IF;
# G) J; D5 i5 {' r2 \ 1 W5 k& b+ C7 D% Y% Q" C& b* }
# b7 F+ h! k( j" K! s1 a$ r: g$ T+ _6 F4 u' v' T
START PROC: & l# P( H, X3 I9 p5 U7 q; ~( K2 n2 J
! y8 o) t& G2 ^5 _ IF ( PROC_COMMENT != "No Text" ) ' w# V T, }5 l! S, C3 x
OUTPUT $ " M05" ;
7 A8 U* h' v1 K! b OUTPUT $ " G91 G28 Z0" ;
^& n7 o2 l3 t) ^ OUTPUT $ " M30" ; w/ X; S- i" x
OUTPUT \J "%" ; 4 A8 v7 M- }- H8 j7 f1 _1 C0 ?: o0 Z
CUT_FILE = TRUE_ ;3 L- {' c! u+ t: ~& s% L- x
END_IF ; 1 i; q Q2 G/ H! b8 C0 ]$ t+ {
" ?& m! w% y& [3 L# U# w
*----------------------------------------------------------------------------------------------- - c( w9 V# Z, p2 v5 M; r
5 U+ c0 D) t0 _+ q. U- nPROC FIRST POINT:
0 V' q5 p. t2 v7 {, n8 b0 y% ?; D0 F/ v! b8 j$ g# v
*-----------------------------------------------------------------------------------------------# x) ?6 j+ g9 l3 `% I, q
7 E! T( K2 F8 a) W- o' I7 \! q# q9 y
LINEAR MOTION: fast:: k, y; {9 P3 [( Z) }; z+ b/ X, ]
& `9 [" t( r4 F+ L, W IF ( Fla == FALSE_ )/ C5 @8 y! b: n; Z, R D
OUTPUT \J "%" ;
# h+ _2 G" f& A( i" `* OUTPUT \J " O" PNum ;
. F, e" a$ Y" m6 R2 z/ m/ t; \ OUTPUT $ " ( TOOL=" TOOL_NAME " D=" DIAMETER_ " R=" TOOL_RAD " )";% g" S+ ?$ W. a" y C5 t1 Z
OUTPUT $ " G90 G54 G17 G80 G40 G49" ;. a4 i( S) e* s V+ p' b
OUTPUT $ " G00 Z" Z_HOME " S" SPIN_SPEED " " SPIN_DIR ;
% u" V$ Y( h* X Fla = TRUE_ ;
5 r% @9 t% K# h END_IF ;
0 _* w/ ]8 `6 @) j
' v7 T# B6 d( z6 z" _# B. Z2 T OUTPUT $ ;
# J; Z- r/ L3 x9 q) f/ i% |' l- y IF_SET (MOTION_CODE) OUTPUT " " MOTION_CODE ; END_IF ;
- K6 b# @! `+ O- N8 C/ a" S IF_SET (X_CURPOS) OUTPUT " X" X_CURPOS ; END_IF ;
) o$ ]- j2 f* ]; V% D2 Y) v IF_SET (Y_CURPOS) OUTPUT " Y" Y_CURPOS ; END_IF ;
6 N- l6 g n& d IF_SET (Z_CURPOS) OUTPUT " Z" Z_CURPOS ; END_IF ;) G5 i0 X; {5 P
& |! P& z$ c! ?$ H
( B- Z5 y2 C: Q! s1 \/ L; b % e6 K0 I4 o2 C! W
LINEAR MOTION: fastlencomp:
8 A( z! i( j/ C0 Z
6 e, Q4 n' l" {0 ?*-----------------------------------------------------------------------------------------------4 i* D/ O0 }% V3 e
& G+ ]5 H0 D3 {7 b, A2 ^
LINEAR MOTION:
5 p1 m( F- N5 V2 U* J& S( w& U
* a1 w' o3 L# ^. R& y: U7 Z OUTPUT $;
* \5 i7 ?9 U5 V# \6 G IF_SET (MOTION_CODE) OUTPUT " " MOTION_CODE ; END_IF ;1 y2 a, Y5 W+ J8 k) o5 q& V
IF_SET (X_CURPOS) OUTPUT " X" X_CURPOS ; END_IF ;8 z/ M0 k2 P- W! t- v
IF_SET (Y_CURPOS) OUTPUT " Y" Y_CURPOS ; END_IF ;, f Q; |2 f5 @; ~6 {7 Q
IF_SET (Z_CURPOS) OUTPUT " Z" Z_CURPOS ; END_IF ;) B' { |0 U6 z( o7 o: I( h+ L
IF_SET (MCH_FEED) OUTPUT " F" MCH_FEED ; END_IF ;
8 f1 ] D6 [) e' M! X! f; F* ^2 V) B2 w; o7 a' B
$ ~& y* ?, a* n% x8 f* T
2 f& M3 r4 S, E0 s; [CIRCULAR MOTION:
& _8 R! n+ A" F; O8 S [" a4 g' Y) ~4 ]7 x
OUTPUT $;
1 h$ k: }) i4 \- G) N7 H IF_SET (MOTION_CODE) OUTPUT " " MOTION_CODE ; END_IF ;
" s5 d% x7 k# A5 M" L* @- d IF_SET (X_CURPOS) OUTPUT " X" X_CURPOS ; END_IF ;
2 z: m# f( g" B, G; E5 a5 ~, } IF_SET (Y_CURPOS) OUTPUT " Y" Y_CURPOS ; END_IF ; k7 v2 K! Q0 g
IF_SET (Z_CURPOS) OUTPUT " Z" Z_CURPOS ; END_IF ;. f4 b8 ]" B/ }& E# d6 s" Z
OUTPUT " I" X_CENTER ;4 b6 O; V4 M0 t/ S- ~
OUTPUT " J" Y_CENTER ;. C; |4 Q1 S* ]) X9 y
. l% W& p4 n' F/ m g8 k
% g& S# X W* J0 D! m*-----------------------------------------------------------------------------------------------" n p8 J+ ?, G
; H2 d6 o# v) Q& zCYCLE:
5 z6 s$ C. ~2 r O* Z5 ]) r' l" ^
( G' P Q0 l v& P3 {+ h2 H+ [% r( \ IF (QUALIFIER_NAME == "on" || QUALIFIER_NAME == "toinit")& o: F7 P) E( z$ ?' P
SET_ON X_CURPOS Y_CURPOS Z_CYC_DEPTH Z_CYC_CLEAR MCH_FEED ;
7 t& z; U( v7 U0 u0 k: x END_IF ; & B. }4 N- d+ h& z/ U5 Q9 ^2 A
$ K/ {' g* g1 X& p- W5 ^4 \2 ?
OUTPUT $ ;$ ~, d d8 ] V |" B7 E0 ]( E+ I
IF_SET (CYC_RETR) OUTPUT " " CYC_RETR ; END_IF ;- ~, f& I3 V& }( ]
IF_SET (MOTION_CODE) OUTPUT " " MOTION_CODE ; END_IF ;* V& p& _. Z% V2 C
% r; a8 k$ z& u5 ~3 u X2 V IF_SET (Y_CURPOS) OUTPUT " Y" Y_CURPOS ; END_IF ;
4 x* g3 ?4 H7 V, n IF_SET (Z_CYC_DEPTH) OUTPUT " Z" Z_CYC_DEPTH ; END_IF ; : C3 c8 r% t+ t! G% a
IF_SET (Z_CYC_CLEAR) OUTPUT " R" Z_CYC_CLEAR ; END_IF ;
9 O8 [$ `& f$ n. W; f# j IF_SET (CYC_PECK) OUTPUT " Q" CYC_PECK ; END_IF ;
( `4 |& [7 O* B IF_SET (CYC_DWELL) OUTPUT " P" CYC_DWELL ; END_IF ;
4 q; m7 P w0 P7 ]1 Z& ]% R. U1 | IF_SET (CYC_XSHFT) OUTPUT " I" CYC_XSHFT ; END_IF ;. O0 ~) C1 G' b$ p9 E
IF_SET (CYC_YSHFT) OUTPUT " J" CYC_YSHFT ; END_IF ;1 h- ]' }- [; L9 w
6 O( X( Q3 r% a- [ ! x5 l% _* S, A. h Q
, D& T! i& p# w, b$ {9 N/ W, l. J' J. l T; C6 O! y6 t& l
CYCLE: off: ( I* A2 Q; j$ b2 S% V9 C4 g8 Y# _
7 C( I- a6 f3 W/ A8 ?
OUTPUT \J " G80" ;
, t. R) {& {, l: ~: U9 x) N: R; ~2 W9 E3 P
& ~+ a: b& j1 i* t: g % @' x7 a% S3 q+ U
END OF PROC:' ?& X1 [' m) m8 e. K' x
4 Q7 r4 D; `+ G6 P) }*-----------------------------------------------------------------------------------------------
4 f) C# K1 D% G ]* ]9 Y% h
2 D, p# T1 m$ J; {% K' v5 F% t* v$ zEND OF TAPE:
, X, d. K2 j1 o9 W5 e# N0 t. C$ F' }2 i# z
OUTPUT $ " M05" ;
1 {2 _: w# \- Y4 Z OUTPUT $ " G91 G28 Z0" ;% m7 ^8 J% i8 y7 C' w% p4 Q
OUTPUT $ " M30" ;
+ v. [/ C4 _, A q- Z: D OUTPUT \J "%" ;
7 z& w9 I8 M# Q+ S; V7 P
* e( X( ]6 V" _*-----------------------------------------------------------------------------------------------4 O; d3 ?9 y5 O4 a
3 m9 s" B+ a* q# d5 O1 t9 z
END OF TAPE: beforecut:; T5 w- \: [/ D; A# x
0 q6 C( O/ _6 u1 H# z( n7 I4 N
*----------------------------------------------------------------------------------------------- 4 `) R W) v5 q: J$ B
# y# {- V* y: E. v. [
