楼主 |
发表于 2014-4-13 22:05:36
来自: 中国广东肇庆
& x% u" U. a( r! H不是这个意思,我是在组件里点选一个零件,然后打开(暂停),然后调整好方向,然后再点恢复...................5 T# `0 s1 N1 n% U0 i( N
我是想在调整好方向后,在按一下某个快捷键(如 ` ),就自动恢复了,就不用鼠标点“恢复”按钮$ c3 s9 _2 x% ^4 f- Y: ~5 b
% G* x" D$ y2 F9 N& M1 b7 S
; }( M) O* \" g5 ]+ ~mapkey 2+ @MAPKEY_LABEL打开元件新建绘图;\
& p1 q1 Q6 L# L$ ~# I, v: N: S, Kmapkey(continued) ~ Activate `main_dlg_cur` `OpenModel`;\6 A8 p7 H |, u2 V+ P* `2 Y. D
mapkey(continued) ~ Activate `UI Message Dialog` `ok`;@MANUAL_PAUSE;%1+;
0 `$ k0 U& |7 n, g5 q6 x1 u- K; S3 h2 a7 t& C) T3 R
mapkey 1+ @MAPKEY_LABEL新建绘图;~ Command `ProCmdViewOrient`;\5 f) y; o7 ]) T9 C$ z2 y8 V) x5 V2 }
mapkey(continued) ~ Activate `orient` `NmViewCheckBtn` 1;\+ U! E2 D3 p) F9 Z) H @
mapkey(continued) ~ Select `orient` `namedviewPH.NameVw_List` 1 `Default`;\
) d q0 u8 V9 L) t) w& E6 T: s5 d2 Kmapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_Save`;是;\) A. v% s; P# w
mapkey(continued) ~ Command `user_new_drw_cmd` ;~ FocusOut `new_drw` `InputText`;\
4 u t2 O6 r8 q% O3 `mapkey(continued) ~ Select `new_drw` `SelectType` 1 `a4_frm`;\
, r! T5 o) g2 O& b' lmapkey(continued) ~ Activate `new_drw` `Ok`;%1/;~ Command `ProCmdDwgPageSetup` ;\
1 R3 K. O: |5 r+ ~mapkey(continued) ~ Activate `pagesetup` `ChkShowFmt` 0;~ Activate `pagesetup` `OK`;\
8 b1 u' M, C8 E. W% k3 A% D( E1 c: ?mapkey(continued) ;%.0;%.0;@PAUSE_FOR_SCREEN_PICK;\9 r- R& z/ ? q4 ^( s1 r* m
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
! s" \- Q! V4 A5 T: P$ ]6 Jmapkey(continued) ~ Close `rmb_popup` `PopupMenu`;~ Command `ProCmdEditProperties` ;\
, Z1 ^; Y, h% D& ^ K( Kmapkey(continued) ~ Select `drawing_view` `orient_method_op` 1 `geometry_ref`;\( f8 L" w' l% _& g
mapkey(continued) @PAUSE_FOR_SCREEN_PICK;~ Open `drawing_view` `OrientRef2`;\1 b. t& z8 p( P3 M& i. e
mapkey(continued) ~ Close `drawing_view` `OrientRef2`;\
* @8 c" \6 R) G0 Lmapkey(continued) ~ Select `drawing_view` `OrientRef2` 1 `Left`;@PAUSE_FOR_SCREEN_PICK;\
( a* W" g1 D1 k: s- @ Emapkey(continued) ~ Select `drawing_view` `options_list` 1 `ViewDisp`;\
2 n" `4 O2 |5 H4 l. d* C+ ]5 M! D% ]mapkey(continued) ~ Select `drawing_view` `disp_style_rad` 1 `hidden`;\, M9 ^/ Y0 y0 R1 c
mapkey(continued) ~ Activate `drawing_view` `psh_apply`;~ Activate `drawing_view` `psh_close`;\$ t) U' _3 ?9 t2 p6 @! S8 M, K
mapkey(continued) ~ Select `main_dlg_cur` `DrwAssyTree` 1 `node0:view_2 92 0 -1 -1 -1`;\$ S& \$ ^. I% a2 s6 U; B; N+ ~+ M+ r
mapkey(continued) -1`;%77;\+ P' D: [1 Z g7 p0 m/ `
mapkey(continued) @PAUSE_FOR_SCREEN_PICK;\
, R2 y Y! N, z8 Y( e; t* o/ Gmapkey(continued) ~ Select `main_dlg_cur` `DrwAssyTree` 1 `node0:view_2 92 0 -1 -1 -1`;\( g5 B$ g* h, Z* Z+ K0 ~
mapkey(continued) -1`;%77; |
