查看: 3624|回复: 2
[分享] Solid Edge ST6的最新补丁已上传
发表于 2014-4-18 09:45:09 | 显示全部楼层 |阅读模式 来自: 中国北京
. E2 x% }& z- K/ v0 _3 s帖子内容转发自:- o6 j. y! d. J# A" `3 A
http://secenter.blog.163.com/blog/static/172494030201431872347536/( e1 q5 A! J$ l' O% n0 ~
% I8 R7 w& C8 w/ {
/ i* N, I! p% y( ^" r
正版用户下载地址4 ~* T/ A1 f; B- D7 w: {
https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
* @. \9 E' a; v
* M2 `; s( D& sDear Solid Edge Customer:
We are pleased to inform you that Maintenance Pack 6 (MP6) for Solid Edge ST6 is now available for download on the GTAC FTP server.
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
Sincerely,
The Solid Edge Team
) f  s$ D7 I' h6 s
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
    Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
This Maintenance Pack addresses the following PRs:
===API===
PR 6979806: Problem enumerating multiple cutting planes on a drawing view
PR 6991814: Crash on calling ConstructionModel GetParent() SolidEdge APIs on Surface Body
PR 1958186: PartsList.Pages.Count always returns 1
PR 6987955: Issue related to PropertyTableAttached Attribute after CopySurface in SE
PR 6988146: get_NumAttachedObjects() returning a positive number of attachments in cases for which AttachedTo() method would throw an exception
===Assembly===
PR 1957429: 'edit material' does not work from Simulation Edgebar
PR 1964029: cannot add a part to mirror components feature
PR 1968265: part moves when un-suppressing or placing new feature in other part
PR 1970822: Conflicting relationships when replacing an assembly by another member of FOA
PR 1971357: Poor Quality Mesh indicating for healthy surface
PR 1971878: Mid surface thickness not recognized for ordered parts
PR 6980581: Cannot save if unload hidden parts switch is turned on
PR 6999775: KeyShot update did not work when using KeyShot with a floating license
PR 1957948: 'edit thickness' does not work visually (override property works visually)
PR 1973819: Bad Performance when deleting Asm features
PR 6998585: parts being placed in assembly not being sectioned properly
PR 1954945: Assembly patterns did not support fill region patterns
PR 1970770: No disk space is available for undo support
PR 6991938: SE crashing when deleting components
PR 7107706: Assembly configurations Save button disabled with large buttons min ribbon
PR 1969051: Not all occurrences of the target part in the top and subassembly are replaced
PR 7114497: Edge crashes if we delete the sketch and edit tube properties
PR 1977985: SE Simulation crashes at Mesh
PR 7103561: Assembly-driven part features can't be edited after breaking the link
PR 7111795: Fix for multiple crashlog aborts when deleting an assembly relationship
===Draft===
PR 1968075: Callouts within a 2D-Model view exported with wrong positions to ACAD model space
PR 1969622: Wrong dimension tolerance text size for imported DXF
PR 1972708: reproducible Crashlog when moving dimensions while ALT-key is pressed
PR 1972860: Distance between creates wrong dimension, if Type is "Feature Callout"
PR 6974211: Line and dimension moving to the other side of group origin
PR 6974447: Secondary units incorrect for Fit Hole/Shaft with tolerance dimension
PR 6999229: Orphaned angular dimension causes abort when view is updated
PR 7105469: Unable to change element gap on feature control frame
PR 7105564: lead to an abort on open during ST6 conversion of drawing views in some cases
PR 1963978: Solid Edge ST6 doesn't export a Callout without leader line to AutoCAD 12 dwg
PR 2235646: a Draft file failing to open in ST6
PR 7110481: PMI in 3D PDF is reversed
PR 1976521: Callout text disappears
PR 1976769: Abort when deleting table group header
PR 6992744: Prop text is missing after file save as to DWG
PR 7105609: crash on exit after Text Box edit - then undo
PR 2234561: Part file corrupts when saved in ST6
PR 6937070: Sheet metal file aborts deleting holes
PR 6973754: drawing view disappears when renaming the active sheet
===Part/Profile/Sheet Metal===
PR 6965638: Extrude command Selection Type hot keys not working in ST6
PR 1950721: Request to reopen issue - Etch identify with API on the flatten model
PR 1955734: Revolved cutout gives error
PR 6997136: Solid Edge Abort when using face relate to try to modify read-only Insight part
PR 1967000: a thread feature couldn't be create via the automation API .
PR 1971912: Wrong stress analysis result in ST6 Simulation Express.
PR 1975596: revolved construction surface not visible until sharpen change
PR 6952052: synchronous bead failing in some workflows.
PR 1973850: Problem with save as image
===Insight===
PR 1958674: Insight can't open files with umlauts via the search result list
PR 1961457: Insight Performance Regression: First Open and First Search are very slow
PR 1965985: English SE Client doesn't handle German SEStatus correclty - "Latest Released"
PR 1957847: Search Server Express 2010 French: Where Used doesn't find all documents
PR 1966014: Error message when defining SE Options group names for DocControl and EngChange
PR 1950953: "Replace Part with Copy" copies also unselected parts when using Insight
PR 6902051: Create Unmanaged Copy command is not picking up draft files for assembly components
PR 6970943: Slow Operation during the opening of larger assemblies
PR 1976592: RevMan: Insight allows an "Update" action on a released assembly
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 1969284: Modified timestamp on Item Revision is not correctly updated
PR 6959718: Where Used do not work after Revise action
PR 6970167: File load failure observed as user tries to open assembly which other user is saving
PR 2211862: Add to Teamcenter failed when ST4 and TCX have attribute map
PR 1957335: Cannot release part revisions with IXT_DocControllers have Full Control
PR 6997728: SESE crashing
PR 7101577: Endpoint connection error seen in client log when upload this modified assembly
PR 1976390: 'Create Package' of 50+ parts causes SESP web client to hang and doesn't complete
===Solid Edge Embedded Client===
PR 1923448: Cannot Save As or IPA edit released part w/ ProAsm dataset in assembly
PR 1955870: Cannot add .dft dataset under existing Design item when Document Number defined
PR 1960251: SEEC incorrectly changing manually defined dataset name in model draft pair
PR 6930882: showing an bad error message when FCC fails to start
PR 6935000: need better error message to troubleshoot solution to MultiCAD issues
PR 6990612: Incorrect document name formula is displayed after Assign All in RHS
PR 6992440: Part file Item ID is not assigned to its DFT for this workflow
PR 6998598: Property is duplicated saving a new document.
PR 7100894: CPD loses information during save as and revise operations for this work.
PR 1915659: Unable to place more than one FOP member into an assembly without error
PR 6889431: RNR showing description and changing on the CPD after selection
PR 6921664: Column Fit too narrow when cell has image and list
PR 6963346: Checkout of Embedded Client License does not show up in debug.log
PR 6997698: problems when saving files from Solid Edge ST6 to Teamcenter 10.1.0
PR 6901072: BOM mismatch error shown when saving this FOA
PR 6977867: Frequent crashes after query in SEEC ST6
PR 7110419: Copy and Paste of RNR in SESE paste the wrong value for BOM lines with drafts
PR 7110739: Time to check-in or saving too long
PR 6962123: Geometry tab in Teamcenter Vis is not displaying imperial units per SE part file
PR 1972151: Crash occurs while running the utility
PR 1957618: Incorrect behavior when TC Revision Naming Rules applied only to SE Part
PR 1972725: Save As creates a new first Revision if first Revision does not exist
PR 1976728: Save As of Part & Draft w/ linked image file creates 2 SE Interpart Draft Links
PR 6774107: Opening aa assembly is returning a Runtime exception error
PR 6943914: Save As All results are incorrect for assembly having empty item
PR 6992555: Save AS; Adding the same ItemRev at a child level as the parent Item crashes
PR 1974516: ST6 w/Tc10.1 poor performance during first "Save" comparing to ST2 w/Tc8.1
PR 1976946: Attributes with Russian localization are displayed as garbage in SEEC
PR 6901822: Save AS is linking source model to draft instead on the newly created model
PR 6979703: Item ID Pattern property does not display while working on leftover transaction
PR 7113920: Problem in SEEC ST6MP5 searching for Tc numeric attributes
PR 7118818: LOV values in the CPD do not sync when part and draft in the same upload window
7 j) }; c9 s; V0 o9 @( _) E
发表于 2014-4-18 10:09:43 | 显示全部楼层 来自: 中国山东泰安
等着大神的破解版出来啊。
发表于 2014-4-18 12:46:19 | 显示全部楼层 来自: 中国北京
还以为传到论坛了。。
