查看: 3318|回复: 6
[求助] cad输出钻孔文件小程式
发表于 2014-6-27 16:51:44 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
1.cad输出钻孔文件小程式,附件程式只能1-12,请高手改到1-20.
, Q- W0 T2 ?: z; N1 p3 {+ [谢谢!版主可以扣我三维币50,作为奖励高手。谢谢
- O: w/ U% R2 K高版本cad直接ap加载即可。( e; s2 }( r: q
2.求cad批量点变圆小程式。
CAD输出钻孔文件.zip
6.28 KB, 下载次数: 4
发表于 2014-6-27 17:22:21 | 显示全部楼层 来自: 中国台湾
;;;  原作者 模开放着
$ R0 ?# \+ R4 k  p2 A, Z& u
* A4 e8 ?5 E9 R  (princ "SCANNING LAYER 11")(terpri)6 A" Q1 l- w; X, h0 g; r, u6 k, B
  (setq entlist (ssget "X" (list (cons 0 "CIRCLE") (cons 8 "11"))))
9 |% f& G3 [3 U2 f  ( if (= (not  entlist) T )+ w; }' X5 X9 i! x5 g0 X
        (progn
" ^6 k" A& a0 _/ ?" x! P$ x        (princ "NO POINTS ON LAYER 11")(terpri)
5 s* s8 B. v9 N$ y* d+ u        )1 f& v4 T% V% A6 X4 g: k
        (progn
9 N8 X* t' L0 P3 V- {( T, i% H. J) h        (write-line "T11" f)
; M& {) R4 w6 Y        (princ "WRITTING TOOL LAYER 11")(terpri)
5 j* [2 F5 M1 N( }7 Z! l        (wrtstr)
" @1 p& R( a. n  \2 X        )
4 Z6 Q; x6 [5 z& i" ]
3 y7 L  u" e2 W/ H: o; x" ~   )
  L$ N: {( m: u& I# {: F5 X
) w/ o) }$ Q& U5 b2 l( U  (princ "SCANNING LAYER 12")(terpri), `. z; V$ i, ]9 A' F
  (setq entlist (ssget "X" (list (cons 0 "CIRCLE") (cons 8 "12"))))
/ ^$ o/ y% F  n9 e+ D* o4 `  ( if (= (not  entlist) T )
0 K4 S- ?7 Q0 N* W        (progn
' l* k# r9 c0 s" r        (princ "NO POINTS ON LAYER 12")(terpri)
0 v3 \! t7 {: V        )/ @! L- ^6 x' p+ a4 `( |) \
        (progn+ ~: A& N! X6 ?. Q' F7 K, z
        (write-line "T12" f)
1 \4 x& Y& G5 v: d        (princ "WRITTING TOOL LAYER 12")(terpri)  p; [/ B. g2 I6 y9 n6 }" q6 t- \
        (wrtstr)8 g# c) T7 g" z. v! \/ u
! _8 ~- `' R! b: q3 R: u* ?        / N8 C# r, y2 Y" H2 l
   )& Q/ u! }8 n& ?  M9 S3 r
; j2 r" }# h& W0 A# e2 X  ;;;=============================> 自行添加呗...
+ e" u* I2 }  `$ j  ;;; 13: u) T; b5 K8 e7 c  {
  (princ "SCANNING LAYER 13")(terpri)
* G  k- [+ Y( D: J  (setq entlist (ssget "X" (list (cons 0 "CIRCLE") (cons 8 "13"))))/ {: j. E- Z7 d! ~
  ( if (= (not  entlist) T )( |  j  |' \7 ~/ [) Q) b
        (progn% @/ E7 S5 d) D/ n  G- e6 P* U9 ]( u
        (princ "NO POINTS ON LAYER 13")(terpri). f4 X8 ^$ }+ i/ |: \
        )) @2 V2 o5 W" W* z3 D
        (progn# j$ k  F6 c, G. _& P
        (write-line "T13" f)0 F. _/ H; t* g1 L1 T0 j, T( B
        (princ "WRITTING TOOL LAYER 13")(terpri)
" {2 M7 e5 G6 x% {  F0 `        (wrtstr)
8 k/ o7 G: ?' V* h        )+ _: K; B, l8 S: R
        9 M& T" B4 p) U% h/ u* l; F1 e1 T
( z; a5 t& {- a3 S! W
' Y1 A$ H5 F; S: v  ;;; 14
8 r( r& y; t) i9 z2 a7 c3 N  (princ "SCANNING LAYER 14")(terpri), J0 T9 H* m" @! a
  (setq entlist (ssget "X" (list (cons 0 "CIRCLE") (cons 8 "14"))))
  X' G6 D6 w  \* O" Q& P1 P, `  ( if (= (not  entlist) T ). q$ Z. j- W- O. u; c; z- N. L
        (progn: G. |# ]$ ^) L4 v
        (princ "NO POINTS ON LAYER 14")(terpri)3 G3 `* P& k' @  g8 i5 E
6 g4 z4 ?1 \3 @. J$ }' @5 z        (progn
- O- C/ s% h. p2 }; d" }( h( `        (write-line "T14" f)& \# s6 D0 C( N& N
        (princ "WRITTING TOOL LAYER 14")(terpri)
8 a6 q9 t: J4 |/ c: k- F        (wrtstr)
2 `: Q8 s& H3 j& i2 {        )
( e$ H% E2 h  _! O# h
/ @( j$ V5 p, \6 i   )' \# H% F) u: \( A0 `$ Z6 @
* m1 R2 S$ y4 e- I9 T& Z* r   ;;; .... 15 16 17 18.....
2 W" M) b* ]. s8 e& k/ J! f! c- W+ o2 a/ i, I2 y
...点变圆小程式...
7 Q9 V0 k9 j. z& U/ x) ^- I2 L  I% V0 X6 Y
1.点从何而来! \% L9 |3 y$ F3 e% v! m
2.圆有许多属性, Layer / Radius ......
! ?3 t* ]) x" ^! {
8 m0 a/ ?" r# ?+ U9 ~上个示例文件(*.Dwg)较好
参与人数 1三维币 +10 收起 理由
woaishuijia + 10 应助
 楼主| 发表于 2014-6-28 11:56:31 | 显示全部楼层 来自: 中国江苏苏州
楼上的高手,1.我还想请教一下,还有2处类似的文字如图片,也要改吗?那2处是干什么的?谢谢!5 ]2 f7 F2 f& T( G( z6 N7 E8 M
            2.我从记事本中复制好的点的坐标(如10,20  ) e/ K4 a4 F. q" v% B
        50,30 等等平面坐标)在cad中用po点,粘贴输入这些坐标点。/ I2 X* r2 b/ X) w! L2 {. r+ x
然后生成圆。谢谢
发表于 2014-6-28 13:05:38 | 显示全部楼层 来自: 中国台湾
您的贴图 用 Maxthon & Chrome 皆见不着...
. c6 v6 L# d! ]: p+ m+ s# \+ x( ^- z9 _
先网上搜 "展点程序" 试试手气
  {$ Q4 ]* p+ J; w: r+ J2 N/ ?另 程序相关 建议改贴 http://www.3dportal.cn/discuz/fo ... display&fid=333
 楼主| 发表于 2014-7-3 16:20:34 | 显示全部楼层 来自: 中国江苏苏州
SunVei 发表于 2014-6-28 13:05 http://www.3dportal.cn/discuz/static/image/common/back.gif) y4 J& R# ], C( ]/ h" `7 ^
您的贴图 用 Maxthon & Chrome 皆见不着... 0 @) {0 N7 H& V
6 R  }& m8 w7 @* r: o! r先网上搜 "展点程序" 试试手气
5 X7 d- K& j8 Z* k4 Z4 |, e+ S" R1 ~. V% J' b4 q7 C
另外处类似文字是
, Y) _: Q7 U7 T0 l3 }' s$ U. {(princ "SCANNING LAYER 11")(terpri)4 [, ~* x( z( o) h* y7 o; D6 E
% S' z* b; Y  }2 n+ [$ w  ( if (= (not  entlist) T )
) a( [7 u3 W9 i, x+ F        (progn
& B1 N6 S6 D2 H8 f        (princ "NO POINTS ON LAYER 08")(terpri)4 i: g# ]6 d7 @1 z7 U0 x
        )2 r7 M% q& Y# v0 m- P$ m2 h' @
        (progn& U/ O* @, y& M4 v6 u6 }: {4 ~
        (write-line "T11" f)/ b5 L, R$ Q4 O3 v  u+ k
0 _1 o* ?/ v; e  E        (bncwrtstr): w+ B* }$ `0 H
* W2 W* U( v  C1 y8 P        9 A% o' c8 p2 r) |3 l% a
6 E8 l8 o8 [8 v" o. z* E) q
/ {7 b9 k3 p# d2 [& q$ d(princ "SCANNING LAYER 12")(terpri)8 i- r( |- Z6 Z  G( I$ w  [
1 o- ~# W0 d/ m/ m- |0 h. t$ \  u- K  ( if (= (not  entlist) T )
* `! B  Y' K( M- H2 E        (progn
# v- V7 a. [6 v2 @        (princ "NO POINTS ON LAYER 12")(terpri)
( @; L5 P6 x8 e4 V( B+ p4 L        )
  {' h- k. e, o  Y  F: H. F4 e8 H& S        (progn& Y) E6 ]+ h' \# s( _) Q# P, R
        (write-line "T12" f)2 |1 b  I" r6 x
: Q* `% E: H3 }3 [/ p- ?1 O        (bncwrtstr), a" [) x0 k" Q( |* H( \8 z& U/ s
        )3 W$ k5 R7 Y0 s- j) ^) q1 Y3 k# b% Q
  u2 s  J& u7 @) i8 i/ |(princ "SCANNING LAYER 11")(terpri)
+ p& E* L; N4 Y) s  (setq entlist (ssget "X" (list (cons 0 "CIRCLE") (cons 8 "11"))))
* \+ J4 o6 l9 ]- J) m  V  ( if (= (not  entlist) T )
  B/ Z/ {/ N4 Z+ B) r( W/ G        (progn9 K; r* n* h0 S2 x) u7 e8 j$ ^' x
        (princ "NO POINTS ON LAYER 11")(terpri)! N& r" L, b6 D- g2 |
! n& B8 X1 N% }- [6 x) M        (progn
0 }. {4 {$ u8 T8 n        (write-line "T11" f)
3 m! F" ]) a9 ]. `' m3 C+ Y3 r        (princ "WRITTING TOOL LAYER 11")(terpri); i- m' C; _- w2 S3 X$ x5 S
        (shafferwrtstr)) l9 i5 Y# i3 t
        )4 \/ Q# q/ ^0 V6 e( h
        8 s% a4 h6 U- z0 V8 X
& a8 C1 p* h6 _4 a0 X* f  3 A8 p1 u" Z! U& O/ Q5 I! p
   (princ "SCANNING LAYER 12")(terpri)" T: ]( z/ D  ?5 I* s
6 ?6 l( U5 t+ O9 J; Z; ?! g7 I  ( if (= (not  entlist) T )
0 F3 Z' T6 n$ f" q7 B        (progn
' ~0 l  }* U0 K$ B; Q$ M4 [        (princ "NO POINTS ON LAYER 12")(terpri)/ M$ H/ G1 Z. {& S
+ ]+ E  f/ U* b/ s, q* r; z% n        (progn1 i% J4 z) p6 X, e3 c- E" d
        (write-line "T12" f)* z5 s) N- ?* F. d6 v. g
* S1 Z/ W1 A- j2 A: h# h3 A        (shafferwrtstr)  f* `0 s/ m& ^7 s! b
8 h6 j, K; N9 y3 G7 ]6 J+ [: z也需要修改吗?
发表于 2014-7-3 17:49:14 | 显示全部楼层 来自: 中国台湾
除了层名异动外,同一骨架子
- J3 O5 n, p( O1 K6 s* t: U6 w; d8 G/ s* k% [
Copy then 改名 ...- q  x+ C3 S" n2 _, p5 G: r; U
有几段就补几段 依原框架续加
发表于 2014-7-22 15:14:45 | 显示全部楼层 来自: 中国广东惠州
完全没看懂
