查看: 3443|回复: 8
[分享] Solid Edge ST7 MP5 Update only (by SSQ)
发表于 2015-3-18 02:12:40 | 显示全部楼层 |阅读模式 来自: 俄罗斯
To install this update you need Solid Edge ST7 to be preinstalled!6 P8 V8 g7 ^9 d: K' ?
3 F. a$ P4 b. l1 r: a. b- N
See ..\_SolidSQUAD_\readme.txt for more info..
+ |* i, S7 y* N' Z
8 f9 t2 O, w2 ]4 ltorrent file..
SE_ST7_MP05_Update_SSQ.rar
18.9 KB, 下载次数: 107
 楼主| 发表于 2015-3-18 02:13:26 | 显示全部楼层 来自: 俄罗斯
list of fixed bugs8 \4 K0 T7 i. y, ?1 x; J
: ~8 {( y7 J/ b) l0 X3 b  _: K% b4 `% P--------------------------------------------------
5 @' p* _1 L: i1 V% oThis Maintenance Pack addresses the following PRs:
& t8 |, j8 |" b--------------------------------------------------' T' V6 k$ D0 F# \& f; ~
/ y, w, Z1 K4 Y! L===API=== ' Q4 T8 T* j* _5 C+ j9 b9 ~( S
PR 1996343: 2d constraint solver in a sketch profile works differently in ST7 -   ~) ^% G" A2 S4 k2 G, [
PR 7274554: Physical Properties data corruption after "Move to Synchronous"
  T9 Q! G7 T% Z3 q5 K* F. t4 PPR 8252701: Assembly Relations are lost when using "TranslateMultipleOccurrences"- N  k& j% v9 j& b
PR 7306995: Density is not set when Material is synchronized4 s/ g. A! z# B$ e( \, P" u
PR 7248181: RevisionManager.Document.SetPath, Assembly Copies cannot be changed
2 i5 D9 {- ~* i" ~: |6 ~2 z0 z3 s3 _$ R' q
===Assembly===   w' B4 Q+ ~! r" |" t  N! `
PR 7247238: SE crashing when opening an assembly
" A- n' i0 v0 C) d- V! EPR 7251083: Enclosure fails to create in ST7 French' t: b8 z/ V: U: L$ g1 ^
PR 7261344: Stored Groove Weld information not showing in Options dialog box
( b3 j9 J" b# j! @: v8 jPR 7268784: PathXpres causes a highlight problem if a part is recomputed before
2 F, G' q& h6 n- B! e5 oPR 7279664: Interpart Copy copies old geometry after Replace Part  U. H9 M6 e& f  c) g6 {- E& x: H
PR 7284762: color changes in assembly being lost after Save
4 |7 C2 i+ @' }1 c+ j6 |) ^) }PR 7286828: after IPA edit -steering wheel move and cancel on suppress dlg undoes everything
" I6 f- P& Q0 a8 f: ~PR 1993287: Occ prop dialog shows wrong rotation values
" @( E/ C  e% a% q6 D- I& DPR 7253903: Assembly File cannot be opened. Corrupt file problem
% O1 ~7 Y; a: Y- G6 FPR 7254312: links do not update after save command
5 I, K' H6 D$ u( s) k9 C1 _PR 7261085: Simplify assembly not working in the French version of ST70 g' E1 C: ~5 b/ d7 ?7 `" I  o
PR 7225926: Relationships fail after assembly feature hole modification& y% P5 h* c/ t: u8 I/ g
PR 8255899: Assembly is not correctly updated after modifying dimensions% d5 P5 Y: f% R; C9 N3 d
PR 7271790: adjustable assembly not updating properly with a "reference only" subassembly.% b0 j& a" Q" D( m: c
PR 7298481: 1/64 precision is not sticking leading to wrong results.$ s) |2 b5 x% k& |: Z, C$ S, N, m" P# F
PR 8250893: Reproducible Crash within Framing$ V( k( i- h7 G& Z! T5 d8 A6 n8 Z
PR 8251764: Cannot update higher level assembly when occurrences are marked as hidden at the1 E2 T8 W- k* h
PR 7310380: Select Parts Constrained To command locks-up or aborts Solid Edge
4 g! S+ ?  x3 v7 z7 l5 w
+ @: M5 J8 H6 r9 t$ N===Draft===
# P/ `4 c3 ]6 r8 t' q  ?PR 2247261: Parallel dimensions are abnormal
0 K5 [" w7 y7 T; O8 m. Q% [PR 2249099: Dimensions move when I open dft in ST6- ]9 s0 s* M" e1 S0 {- v0 U% n5 H
PR 2249101: Moving one dimension cause placement change in other
% k2 C1 {& y5 z  j: R9 JPR 7212177: drawing view did not depict correct assembly feature in some cases. C$ b; @: L1 l3 M% W' @
PR 7216837: In ST6, the text "jumps" to a higher position in the callout box
0 L- N0 k* O1 T. E/ o" zPR 7247679: Reference Text generated in German SE version will not displayed in English SE2 e; ~' K/ X: a2 c  z
PR 7261278: shading on a drawing view that was cropped larger was incorrect! F- T) ^' u' e. p8 [4 u
PR 7263310: Solid Edge ST7 - Very Poor Performance when working with old Draft File* X- U% a3 x- D" O/ F  J
PR 7276910: Grid-Origin moves after switching sheets: f' ~$ ]- u8 g* D/ M* G( ^* k8 }
PR 7279255: align edge does not show alignment line
, T3 }4 Y( Z* K  l; a% K& v9 C2 iPR 7287234: Table cell changes size when opening file in ST7. O$ q6 ?3 n: W
PR 8259652: "Filled Textboxes" are shown in white (instead of red, yellow, etc...). K9 I' ~6 O  q, S* E
PR 1998827: Save as pdf results in rotation of portrait drawing% i% {0 G/ r# V( z% P
PR 2250493: abort when un-breaking views in some cases4 z! B# i; k4 d( [4 Z5 j0 O9 ~
PR 7245005: Error loop when placing a DV of PMI with subscript
5 F0 F4 O2 [- dPR 7290018: Coordinate dimensions are not migrating to sync properly for revolutions
0 Y9 C8 F* {$ i5 RPR 7259995: drawing view tracker incorrectly indicates model out-of-date1 d2 h2 P; r2 S8 Q+ J1 u7 k  B
PR 7269193: section view fails to cut parts in some cases
: l( @. s! j" h2 `6 ^+ y" j- zPR 8261329: crash while using a new configuration file for a specific draft to dxf export
; i4 C) i5 R& C8 B& q1 \3 h5 l, i+ n* APR 1997742: drawing view scale in wrong format (e.g. 2:10 instead of 1:5)
9 v6 J! V; H( c, Y
2 i* N: S" d8 P+ g8 L: W# o# d# d. ^===Part/Profile/Sheet Metal=== - K& k. D( Y4 Y% D! i1 f, P
PR 1999126: Preparing Piping Components
2 D. @8 L( n+ d2 R8 C2 b9 ~- kPR 7250325: Sync Chamfer Unequal Setbacks makes the model disappear
2 x; A  a% k# c$ b& D8 t! n/ rPR 7239628: Need the bendtable dialog to support pulldown lists and cell changed events6 g) p! m& x. P3 Z4 S# ~
PR 7239634: the PZLEx function returns 0 for the BendTableIndex argument for synch PSM model+ Q/ X$ [; `( s  @! s$ G6 U
PR 7250956: Mirror Assembly/Part Copy Flat pattern differ from original7 ?+ @3 X) @7 h% c
PR 7279296: SE becomes unresponsive with endless flickering of the display
6 h; w0 |  A! FPR 7274977: Problem using PCBto3D when hole table files have been edited in ST7 ) w4 g% n( z# s9 j$ |$ A+ {
PR 7239628: Need the bend table dialog to support pulldown lists and cell changed events! q! y! R* ?3 E8 ]4 J- I% d# |
PR 7247778: Open file regression from ST6
- J4 q# J: u  ?! aPR 7247647 (Master PR): Unable to open files created in SW2015 in Solid Edge
" }# w/ o0 Z& {2 a0 E  rPR 7284703/7245305: Update NX Adapter to support NX105 w7 ~2 P7 o+ t
PR 7249088: Remove material does not update display
- J( A, W  w: n5 R0 o" M3 F6 {5 m7 @  o
===Translators===) n2 p/ a; m0 @! x! c$ j/ J, z
PR 7198900: Scale is off on when multiple sheets are exported to AutoCAD
* @6 V5 N' R0 K% P9 M2 ~+ X7 v4 FPR 1991000: When saving to Dwg, 'Solid Edge ISO' textfont is not converted to textfont 'Aria( B( Z+ [4 c: a# l+ w
PR 7231939:SePvAdp.exe hangs when multiple assemblies are exported
- C: F8 I6 v2 `$ j$ ]) `3 EPR 7240716: Cannot import a Catia V5 R24- j! c* j" _/ {# W. ~2 N+ X6 k
PR 7274737: Import von JT# G2 P1 k% n! Z, k8 `2 p
: c3 V0 V' f! v- x9 U2 ?( M* |===Insight===1 p3 a: t8 U1 [1 p
PR 7207681: Insight: Non-string properties deleted from files
- ]& L. g1 o. ?* ^/ J5 R( [PR 7225962: File dialog is switching between managed and unmanaged version in Insight6 z2 H# b+ }' B# ?3 ~- _
PR 8261192: Insight Search lists all documents twice after an upgrade to ST7
% n# ]% T% ~$ f# W" z( o
$ f0 f1 b% s* ]  T* w, U* X1 e===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
& {! G+ o# K- k0 r2 rPR 7271007: SE SP Client: Edit a part in an assy and Revise, Part is checked out and Read On
( s1 b. n% ~( O! O) S+ H. {" Q8 WPR 7283302: 'Show selected item+WFcart in task description' needs to be back ported in ST7MP
$ _$ g4 D  X" k8 f4 a' gPR 8259630: Error message " exists in the following folders:" is insufficient
$ V4 Z) q1 G9 v1 SPR 7292077: SESP crashes while creating part having number column with default value
% y- h8 m3 F5 A" j% ~- K- c/ mPR 8250211: File >Save As marks the filename in blue, so that it cannot be modified
, l/ i+ `# y; t; S. ?1 i' jPR 1996897: Error Message AnchorGUIDTransfer at ST7 SP Server Update
, g; I8 y0 w2 f1 X7 W' KPR 7177847: Projects can be moved to InHouse via Favorites
( Q4 w1 m: T. S" {PR 7292967: Quick Workflow with Draft update send Email which is set to no sent
* v6 p& }8 t* |$ _3 c, _+ rPR 7193844: With Workflow Cart=No, status is not updated for documents
$ M) R& w" g1 e. x( @6 iPR 7199893: Some part are not released if part in sub-ASM is checked out2 P: I: N: X6 r
PR 7234699: Right Click in Pathfinder 2 times to open up a part or assembly
+ z6 l" `% Y2 aPR 7312417: when action set to revise the folder column should be read only
: n% g- T8 |/ g- t( u) J  R5 S+ E& ~% K! [/ P
===Solid Edge Embedded Client===' _7 c; D" E: o8 R: y
PR 7169854: Item Name in Solid Edge CPD not synchronizing between Part and Draft file
+ b' B$ `' ^& k/ O( dPR 7170066: Interdependent LOV group mapped properties field is not editable for some props
- p& J2 y( c4 V/ I% ~# l- K2 G9 BPR 7251662: Bad performance in new SEEC implementation
8 T9 d0 l+ B1 e) oPR 7278961: CFG file is not being uploaded to TC for an assembly having no links or component
& \% Q* i, m& s, x) y% {: U2 yPR 7278977: Draft image files such as emf, jpg, bmp etc. are not carried forward during Revise+ ^" `" }7 s6 J
PR 8258193: Add to TC Interactive will change the creation and modification date
4 z" H% }3 O8 v) n" a% D' _PR 7271453: AddToTeamcenter Interactive in French is consistently crashing+ v6 U& w8 S  ^  `& z) E
PR 7272921: Opening a managed doc via the API will do 2 BOM expansions  o* o, t  d8 C. j8 b9 j
PR 7279570: Error in UOM to non-graphic parts( p% I# ^* @2 d4 V: s* p3 B# z" ^
PR 7299494: Structure editor Save as operation entering same id for part and draft generates error& r( h% l: o2 U* _7 C
PR 1991572: Problem setting SEEC_ItemTypeList_SE Part and SEEC_ItemTypeList_SE Draft
9 l, L- A5 |0 T! q9 D5 HPR 6781873: AddToTeamcenter needs a better message for missing Meta Model properties
7 y7 E$ L  t: l/ X. y7 y" V3 vPR 6958514: Revise is using the default NR and not the one used in the file
! b" H; q: g1 q5 r1 g' R1 {, v% O6 u% q: jPR 7218222: Save As of Draft w SE_Draft_ofConfiguredAsm does not preserve the relation
2 e# T0 ]4 C2 ]9 Y- }PR 7305483: Solid Edge Model file remains checked out to me while the Draft is checked in
5 I# G% Y9 C* v6 ~" I$ rPR 8252307: AddToTeamcenter removes the TC_Import_Time from previously imported files % b% \6 ]& ^& C9 Q6 V
PR 1993522: Revision field is blank in CPD when naming rule used
. M2 z& J, O; f+ PPR 6997635: Save As on Solid Edge Draft in SEEC gives incorrect filename
' u& b0 K- p+ a$ a$ EPR 7226933: Opening a part with a part copy of direct model always prompts to update# N3 {7 ^; S6 R, `, \8 r  J
' A6 G5 p+ I. Y4 P- n9 u9 ^% H
- Y4 u7 F0 G0 J$ Z---* `/ ^2 [7 j+ c- i' R
End
" R% q+ q5 C( J: `---
发表于 2015-3-18 08:15:21 | 显示全部楼层 来自: 中国天津
不错,下载下来更新一下
发表于 2015-3-18 22:18:09 | 显示全部楼层 来自: 中国浙江杭州
很好,一直在用ST,很方便。
发表于 2015-3-20 13:47:11 | 显示全部楼层 来自: 中国吉林辽源
每次都更新 谢谢!
发表于 2015-3-22 07:41:47 | 显示全部楼层 来自: 中国河南安阳
谢谢,太好了
发表于 2015-3-23 16:15:41 | 显示全部楼层 来自: 中国北京
这么快就有更新了,谢谢了
发表于 2015-3-23 20:46:05 | 显示全部楼层 来自: 中国四川成都
只能更新成64位机器才能用了
发表于 2015-4-14 08:03:32 | 显示全部楼层 来自: 中国广东梅州
感谢您,solid_user!
