查看: 2569|回复: 3
[原创] Siemens NX 8.5-10.0 version 2015.04 Solvers Updates
发表于 2015-4-28 11:22:30 | 显示全部楼层 |阅读模式 来自: 中国台湾
SiemensNX 8.5-10.0 version 2015.04 Solvers Updates
  y) T) {! _: B: z- r2 G! z' w& G& ]4 ^$ _2 W( C
SiemensNX 8.5-10.0 version 2015.04 Solvers Updates | 527.4 mb
8 k0 S# [  M, G; A3 @6 Y
Siemens PLM Software has released an updates of NXCAE_EXTRAS module to SiemensNX 8.5-10.0, is used to address thermal analysis requirements in a wide rangeof industries.
9 [* g' m0 I0 x) w: S0 k  y# d
# n/ `" \3 X" @" g( ]NX Thermal software provides heat transfer solutions and is an add-on module toeither NX Advanced FEM or NX Advanced Simulation. NX Thermal can simulateconduction, convection and radiation phenomena for complex products and largeassemblies. NX Thermal is used to address thermal analysis requirements in awide range of industries including aerospace and defense, automotive andtransportation, consumer products and appliances, energy, medical, electronicsand semiconductors. In addition, NX Thermal can also be used with NX Flow, theNX-integrated CFD solution, for coupled thermo-fluid simulation.+ i5 `8 O, Y2 A% C
1 b4 D# w( [- E# H) j
NX Thermal continues Siemens’ long heritage in thermal simulation and leveragesthe same technology that underpinned the I-deas TMG solution. NX Thermal useshigh-order finite volume-based technology on a FE mesh to accurately andefficiently simulate heat transfer phenomenon. It combines the versatility ofFE-based analysis with the accuracy of a finite volume scheme. The NX Thermalsolver technology allows simulation of NX parts and assemblies within complexthermal environments.
Siemens NX 8.5 TMG 8.5.305 Thermal/Flow Simulation SolversWin32/64 (update only)
! b% H7 E# y$ aSiemens NX 9.0 TMG 9.0.444 Thermal/Flow Simulation Solvers Win64 (update only)
1 z! e% b2 G+ y+ H% ~Siemens NX 10.0 TMG 10.0.236 Thermal/Flow Simulation Solvers Win64 (updateonly)
  ^0 ~8 h* t9 _2 TAbout Siemens Industry Automation Division
: z" ^$ b$ m( z+ |9 \' m. d; ]8 F, d" Y6 N7 m4 V$ w0 V
The Siemens Industry Automation Division (Nuremberg, Germany) supports theentire value chain of its industrial customers – from product design toproduction and services – with an unmatched combination of automationtechnology, industrial control technology, and industrial software. With itssoftware solutions, the Division can shorten the time-to-market of new productsby up to 50 percent. Industry Automation comprises five Business Units:Industrial Automation Systems, Control Components and Systems Engineering,Sensors and Communications, Siemens PLM Software, and Water Technologies.1 u1 ^/ P: L8 ?+ M
$ p" p! R: q  H9 a
Name: Siemens: W/ ?8 a) ?5 e$ c6 y
Version: NX 8.5-10.0 TMG (2015.4) Solvers Updates: _3 Y+ E* ^! ~+ P
Home: www.plm.automation.siemens.com7 ^/ Q, H# @& r4 [: l( Z7 R
Interface: multilanguage5 c3 \& E1 D2 h! @9 s8 m3 n  n6 S
OS: Windows XP / Vista / 7even / 86 z) G+ `. v/ |) M
System Requirements: Siemens NX 8.5-10.0 with NXCAE_EXTRAS moduleand SSQ's crack to be preinstalled
0 D: d$ R/ A- }0 |8 zSize: 527.4 mb
. j+ S6 s( b+ @$ R5 c9 B/ E5 d+ ^  K- X) E. x8 o
* ~1 _: `" u! L3 R5 K6 aATTENTION! It's NX 8.5-10.0 TMG (Thermal/Flow) solvers updates only! To installit and to use a crack you need NX8.5-10.0 Win with NXCAE_EXTRAS module andSSQ's crack to be preinstalled!
" T& t8 `) A2 @& J  l' e  V: B( v0 A$ _& h3 ]
百度云链接.rar (172 Bytes, 下载次数: 56)
发表于 2015-4-28 14:41:28 | 显示全部楼层 来自: 中国陕西西安
已经无法下载
发表于 2015-6-1 20:17:44 | 显示全部楼层 来自: 中国山东泰安
楼主,更新一下下载链接吧!
发表于 2015-6-5 08:35:26 | 显示全部楼层 来自: 中国河北沧州
链接已坏 请跟新
