楼主 |
发表于 2015-5-19 00:38:42
来自: 俄罗斯
List of fixed PR's
6 N9 V' h. g- ?# t2 q7 {: @% t5 i5 Z5 {) ^0 f+ @ i
' k9 A; p6 p Y( s
& r) {3 N; t- K- z. OThis Maintenance Pack addresses the following PRs:
- M2 L# c' k" H' @+ K0 g--------------------------------------------------
w# j- k' q! q, p' H7 i
1 D# N4 w7 g! z" B" N7 R===API=== $ p: g6 }( l! \. F* ^2 f! m8 B
8 a# \& B. L% Y$ J4 v* a
PR 1128909: SegmentPointRelation3d.GetElement method fails on connection to other assembly
. ^! W, p f% y6 M6 {PR 7326618: API Interpart references are broken Z7 O) `2 Y( ?+ e; Q7 s
) m: x# }. ]7 _3 v* {+ I
===Assembly===
# R2 b( M' n5 D
8 k# Q' m0 b+ g( h$ ]PR 1997310: thread feature fails in standard part screws
/ Y" T+ e& m: aPR 7238389: Changes in Variable Table has no effect on other depending variable : X: h f) h9 _) M+ X
PR 7288288: Handle points of frames moved after Update all links done
" x7 ~- a4 s _2 \0 Z. b- \PR 7329238: Files opening with Read Only status when they are available# {. f- K8 N! y6 x& B3 S" q
PR 7340152: Relation fails in assembly% X' m" E) ?! a6 c& x7 D& {" R/ P, m
PR 7340513: Crash when editing a multiple profile assembly feature
! z& D4 v* R% ], [PR 7347154: not getting immediate feedback indicating that relationships have failed when IPA9 Z+ V3 N1 ~0 t% Q# z6 C
PR 7351598: missing assembly features when opening from Draft
9 e+ }: K% {3 [ S" ~ cPR 7360551: Subassemblies being empty when any instances are not tagged "display in higher level"$ b: D, h, [: \' i- k
PR 7339408: Cannot download the document message in open file dialog
+ ~7 A2 ^3 n) f. ?; b) \/ y" GPR 7345683: File units change for legacy files in ST7
! F6 [- |8 P' X4 L8 V+ G! d( r, NPR 7286029: The values are overridden and updated in the SE options+ }% N0 y$ n& Q# a1 }
PR 7343765: Missing properties on a Family of Assemblies - Please repair file
- o* P) _4 s8 |8 LPR 8266361: System error encountered during evaluate while editing 3D sketch+ @" @6 ?5 I1 G7 H* u( d, S
PR 7283939: decimal places in assembly physical properties mass moment of inertia is locked
! Z! @& s6 k+ ^0 ^PR 7329334: Alternate Assembly previews not being correct, {9 t: @" T) m ]( O0 X; J( q$ U
PR 7362568: not being able to edit a failed connect relationship
& z# T2 h: B+ l% v$ GPR 7249140: Parts disappear from the display
5 @5 |3 Q" U# z, `6 A8 M
f x2 B0 P6 u9 @5 x===Draft=== 0 E/ i! N" m; ]+ w
) o3 ]# I7 r3 U/ ?PR 7328318: Property Text "Last printed date" will not be updated - wrong date on printout
/ o: r' g6 F' J. [- W* aPR 7234234: vertex edges were incorrectly suppressed in a section view of an assembly
+ x4 }/ h" i5 q/ tPR 7235932: 3d connection device leaves fence select artifact
3 {3 P2 Q* s/ d TPR 7335228: Opening a DFT file crashes Solid Edge
( f9 a4 P0 g1 F6 {8 ZPR 7337320: Block in Drawing View will not be exported
( r* m1 {: ]! V; N# W9 t6 v0 zPR 7342543: Incorrect section view display$ P( [. \- {9 D
PR 7353124: Wrong dimensions in a Draft, when broken out section view exists
% `! i' @6 q: v1 S6 Q8 XPR 8253818: Material Table > customer properties cannot be retrieved e.g. in Draft. t. M8 d4 c9 R* A1 A
PR 7304635: Shaded draft view colors inconsistent
, C# L# d/ S% d! u! R( d! [PR 7360547: Repeatable ST7 crash in Draw In View
% x- N* t) L ~5 A
' x; Y) \, f4 }% o3 }===Part/Profile/Sheet Metal=== 6 T2 t+ ]0 e( m! B
$ [3 S8 C2 N# x. z+ I5 u
1 N5 f" v. q2 h& sPR 7345683: File units change for legacy files in ST7) r1 F0 R; ?/ h7 Z/ T/ w
PR 1996278: Unable to access edgebar features via API
3 p9 k. {- y m( G4 lPR 7295029: Deleting a hole profile locks Solid Edge if relationship colors are turned on & [: Y- X% B `# O) `
PR 7325679: Creating a 3D sketch, Solid Edge will crash
7 w: z- ~& |" u3 U3 WPR 7340095: SE crashes due to NULL pointer access" ` C# W) x7 [9 E5 I
PR 7340385: Solid Edge crashes if a feature has the same name as the solid body
0 b7 F; I; ^% F _) N1 A/ i, K+ APR 7356608: Dimension Type Feature Callout slows down the graphics performance
; b: \3 ?6 m1 D, v6 [PR 7357175: Hole feature changes geometry after editing the hole, that came via hole recognition
3 i5 I' h J& l4 HPR 7175521: Part dimensions change after doing a save-as
5 Z( U' u5 z8 x/ a5 Y" O8 SPR 7298290: Unable to repair web network
" M8 d/ q' X Q0 a; {& v B9 X) ~ v: xPR 7309165: Profile side changes direction when editing variables( ~) P& L2 I z9 w, x, ]
2 s% X2 Z: V* ] |7 H0 t, h===Translators===
( b: p. P( |/ E$ A' ~ v
6 ]% J1 {, i$ f* ?/ RPR 1991712: JT with long PMI causes crash
3 z6 A# q# i! m" Z; pPR 7234372: Problems to import SAT files to ST7MP2, regression against ST6
6 v. B5 X9 z9 tPR 7294318: Document name Formula will not be taken in 3d PDF
i% |. s( H; f/ I+ @6 DPR 7351253: Solid Edge Viewer keeps psm files within an assembly opened for several minutes
- \) R4 k( m3 f, h; XPR 7355757: Save as jt not possible - Insufficient error message
+ U; A" ^1 A. I: P4 L' P( ~' F+ W& Y! @. H
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
1 e/ G% ?! b. c/ T
1 |7 F y* B6 E% J# mPR 1997720: Cannot sync exposed SE dimension variables to SESP numeric columns
! j% w; [; C# s/ w" p& z0 b( K! GPR 7172511: Pathfinder do not get update with the assigned numbers for drag n drop assembly; T' D5 O y" M: ?
PR 7221411: BrokenLinkLog.xml does not include Alternates when running from cmd line
3 A! G+ V" L- }: o1 D* e/ JPR 7322191: Sync property values across part structure- q5 R4 V0 ]# O6 f& j! A* |
PR 7340397: Where Used on sub-part, Revision.Title values not populated" E$ i. o$ V5 o$ s* f L
PR 8265581: Content Browser shows only Favorite and Site Name - expand not available& z; E" w1 w: t) r6 e; d
PR 6974655: Numbering used to generate SE Standard Parts is incorrect ~* E- e6 ^5 y! J
PR 7332477: Shen the browse folder is accessed from WC or EC there is bad performance ' X1 C3 ^) ~7 R# k+ x C5 X
PR 7346513: Doesn't handle the Title (German Title) column as required 8 X. |7 D9 h1 {5 [/ S3 O
PR 7346893: Workflow Action "Update Drawings" creates unnecessary tasks
7 ` t% W1 I2 L& ~9 e7 W. ^# `& b+ j. J4 `
===Solid Edge Embedded Client===
1 Y2 l# P9 b6 u' o' d5 W) M, |2 @* ~" o# j% z- L" ]
PR 7283519: ASM occurrence property, Item Number are not being maintained from the TC BOM; f; o' v* O4 k$ Z6 s' x5 Q
PR 1993522: Revision field is blank in CPD when naming rule used
! x, Q" P; m3 lPR 7186212: Doing SaveAs of a NX driven reference assembly gives a Tc rules error/ s# Z8 I* [7 b
PR 7244837: Mandatory attribute in Teamcenter won't appear in "Add to Teamcenter" in SE( h" x6 S& ^( ~. ^/ j% y
PR 7324478: SaveAs copies ItemRevision name from source to new object in 10.1.3; T1 }: D- C; b3 g
PR 7355261: Solid Edge Structure Editor not displaying the correct items . I- m* {5 y V$ `
PR 7355760: Revise generates Partial Error
7 ?9 i6 f |. e7 P0 i+ x& nPR 7357577: create draft from model results in empty CPD
: K- k* o" H- ?& KPR 7370456: Save as from managed draft does not properly do link fix up to new assembly
$ U1 z1 Y7 m' B" VPR 7287253: Takes a very long time to open assembly files in SE Structure Editor
1 C, Q9 P3 z0 u4 n4 v& K% {$ f
2 Y- |# y, }# T$ J---/ b9 f+ c6 Q8 h$ [+ w/ y
End " B3 G% A) @% v5 [
---$ t5 E4 u4 r% f. Y9 a
