查看: 3097|回复: 1
[分享] Solid Edge ST7 MP9 Update (by SSQ)
发表于 2015-9-7 18:37:55 | 显示全部楼层 |阅读模式 来自: 俄罗斯
It's update only! To install it you need Solid Edge ST7 to be preinstalled!& N( f. |  g2 L7 p! k* U; a
See _SolidSQUAD_\readme.txt for more info..
% }4 |/ q' @1 D, u6 V9 [- K) g' {& _' ?# z+ [% k* V9 V
torrent file..! N; t3 Y9 S' N
SE_ST7_MP09_Update-SSQ.rar
15.86 KB, 下载次数: 46
 楼主| 发表于 2015-9-7 18:38:33 | 显示全部楼层 来自: 俄罗斯
list of fixed PR's
1 C& M# e2 ~6 n7 S8 L7 K3 Q! ?
: i1 b$ w  d# F' a+ m' q, G8 X  N" ]* @--------------------------------------------------
3 p! u9 n" X  Y" v& ~" @& t! OThis Maintenance Pack addresses the following PRs:
% q; c5 }4 s5 L, M- I--------------------------------------------------& C2 P# F( g2 K1 t
" ~5 ?# x8 R& k! Q===API===
# s9 h. i3 C4 V. O+ l- \! CPR 7418372: CommandInfo::Icon returns HICON of image list instead of a command icon bitmap
0 S2 O0 l# c  Z& {: Q- @PR 7415571: API: ModelNode::GetCutLength returns 0, {4 Y( X+ D" L  A+ o/ G5 R
PR 7437107: The API 'ThreadDataByDescription' does not work in ST7& ]+ s/ }. w3 L  T) U; T0 S
PR 7457728: constraint.GetGeometries API does not return the correct geometry
( C% M0 X. L  |& M7 q6 ~8 s- l! Z+ K. D. m3 a' W$ |
===Assembly=== . T, ~/ `/ E' o% M- ?) w7 d( x
PR 7405944: not exiting the command when a subassembly becomes fully defined during placement1 k, |' [& H& S8 K; F
PR 7410611: Added Display Dimension control to the Occurrence API; o( U# I! L" c; U/ E1 X
PR 8264755: "Save Simplified Assembly As" failing
# c' A9 g  i4 P2 `3 f, UPR 1928569: Wrong Amount in "Atomic Parts List" (Reports and Draft)) N2 c1 l7 W! L. Z
PR 7413477: Expand All causing part files to load
; ^& k% L! F: ]" x" J# {+ K6 f/ LPR 7423057: user is unable to copy sketch into opened Subassembly
: @3 n. @/ t4 U0 Q* Z) qPR 7432598: Updating all Open documents on each Peer Variable Table record update9 w! f; n/ @# @: @& P
PR 7439634: Item number blank and read only in occurrence properties in FOA files3 k! Q/ K! B3 P, N( ]) k3 A
PR 7446113: part status not correct when adding tangential relations; \1 }/ {) u( u+ r
PR 7457275: Interference checking on construction surfaces in ST7
# k4 }( \" @4 M2 m" i  p9 vPR 7459332: not being able to drag a component in some scenarios when going between a selected edge and a triad axis
/ x1 k; D( \& o& _- R( e0 R& JPR 7462671: inactive simplified subassemblies not being included in physical properties calculations.) z# N' l. q# \
PR 8506060: Break links does not exist on the edit links dialog in ST7
- j, S; w6 a1 }1 ~! VPR 7463722: "Display in Higher Level" setting will not affect physical properties calculations
' i3 O: F$ [( T( q3 d5 v: d# V# oPR 7470955: PMI Section view does not cut a fillet weld
- E' r) `) d4 S6 _: X& `, Y' j3 m  x
===Draft=== $ E: u" D( h+ F; @8 \/ x7 k
PR 7384379: Unusual semi-circles appear in some dual dimensions
- Q" I* j4 l- ^+ rPR 7415256: Grid disappears when switching sheets0 T" g- p2 V5 Y/ v5 y) Z
PR 7415586: Parts List changed unacceptable after update views
! L8 T9 }+ e8 T4 p, L3 n. v: kPR 7363506: Loop test does not include spreadsheet7 j7 U$ w+ ^3 d5 |: l
PR 7376599: Honor hidden explode flow line in drawing views with explode configurations5 d* L& S" z2 b* o  v
PR 7405632: Tolerance becomes abnormal when I change a text scale
  _* G: t( f% M/ B- OPR 7407307: Blocks on background sheets not exported to DXF2 w- d: E0 |& C
PR 7432084: Solid Edge crashed while reading entities" t$ c; ^' S9 k  [9 r, \: J
PR 7436337: Tangent command is in a bad state after pressing SHIFT and middle mouse button! d& X- T7 R/ y, L0 X
PR 7440042: Drawing View Properties / Style page shows the wrong style
0 \; |2 r7 I. V- P: J* @, SPR 8505679: Direction of displacement is reversed in the saved image
& S5 e" R7 g; Y7 X( j/ I$ L: D7 ]+ A5 S
===Part/Profile/Sheet Metal=== ; c- N/ |4 v* _
PR 7421230: Crash when inserting feature library" W/ u) }0 G: h5 L
PR 7392093: Driving dimensions do not accept decimal values
" r0 _5 h! I; I9 A  x) Y& c- oPR 7434569: KeyShot import issue
) g/ e' @" V, R+ f; a  G. DPR 7247507: Problem of changing geometry in Sheet Metal Assembly 3 N' r4 o2 T$ z2 z5 k
PR 7271837: Deselected region reselected when green checkmark clicked: v, [0 P- W  F8 O/ Y6 k  v9 H
PR 7437087: Smart Dimension locks 2 files up - Please repair in ST7# x0 V( E$ k' `, }2 y5 r. G
PR 7441752: Transfer from styles via material.mtl doesn't work correctly
1 g/ E3 r' F  W5 P+ D. w) XPR 7444567: Unusual semi-circles appear in some dual dimensions
4 w1 F- z! _0 {# mPR 7448157: Sheet metal part can no longer be edited5 W, C( x' U1 Y& @7 N& u7 L+ w8 c
. d( Q# V, d  v, Y5 P/ s' b4 n===Insight===
3 H$ z, J) Y$ I1 VPR 7398888: Difference in assembly contents and relationship when opened with different user0 F5 m3 b- o& g3 i# d+ \4 p2 L! @
PR 2215861: SaveCopyAs changes Author value in Summary Property to Windows User Name
8 u/ K  A+ d, H% q  B- QPR 7143583: Revise via SE is changing the author property
" E$ n, A1 e6 n" r& {/ w  E: [PR 7361387: Unit Tolerance for Insight Managed files doesn't work - Dot / Comma problem
- O$ l& L# O% E0 G/ R0 g+ w6 X. O$ }7 n  j3 N' [! }
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
, t0 w, ]+ m" A$ [' ^PR 7387776: Crash seen on sending part to RB which saved under a folder that has "," in name
9 E" `1 P- |9 X3 F9 k! s9 YPR 7408925: SESP Client performance slow on Address -> Select Folder dialogue
2 ?5 M) y; S) m+ G3 qPR 7431109: Select Folder dialog for New Document is incomplete if Windows Display is 150% 0 s  X) W1 F5 d7 r8 B% {
PR 8274706: SESP workflow issues: SESP people picker web part takes lot of time to load0 l- r2 P. S! V0 k7 i$ X
. n) z, f) r* J5 @
===Solid Edge Embedded Client===
! K; \+ ?. T# |# J) DPR 7412957: Multiple scenarios where SESE will either crash or freeze! \  j* @0 f0 u7 ^4 p
PR 7429671: SEEC: Initial value required attribute not available in ATT Interactive
) s' |+ N6 v% l' X# r2 g6 Y( RPR 7458795: SEEC - revise all of a complex structure assembly does not finish
. z  ]* Y& s+ D, nPR 8263114: AddToTeamcenter interactive doesn't honor the preference SEEC_property_item_name# r; N4 K$ M9 R5 a0 z
; o& }: `4 U9 F2 @+ R' k+ O
===Translators===; b* Y$ D8 P0 }5 {9 B
PR 7426671: Solid Works files won't open in Solid Edge
4 _0 k1 j& T7 Q2 Y4 jPR 7428388: On some parts of the assembly SE in sync mode cannot recognize holes6 N9 M, u; G* i1 b  d
PR 7428887: Export to 3D pdf, KeyShot, SEV creates several instances of the same part copy- U' P( o. @6 M
' }: p" w+ Y' k---
- {! ~1 ~; a7 w$ ZEnd 9 j9 _7 G" Q) j" Z) T& S( S
