查看: 3596|回复: 19
[求助] 批量更改属性宏代码求助?添加属性的?
发表于 2016-1-11 11:11:38 | 显示全部楼层 |阅读模式 来自: 中国上海
. J0 A. D) E- q" J1 j" O# I
# n& x  G5 ~( C
, x) N/ a2 ?$ e
Sub ReadPrp()
Set swApp = CreateObject("SldWorks.Application") '启动SW
ReadFilesCount = 0
HeaderRow = 2
RowNumber = HeaderRow + 1
PathName = Cells(RowNumber, 2) '读取第一个路径的值
While Not (PathName = "" Or PathName = 0 Or IsEmpty(PathName)) '直到读完路径栏
    FileName = Cells(RowNumber, 3) & "." & Cells(RowNumber, 4)
    If UCase(Right(FileName, 3)) = "PRT" Then swFileTYpe = 1
    If UCase(Right(FileName, 3)) = "ASM" Then swFileTYpe = 2
'    If UCase(Right(Filename, 3)) = "DRW" Then swFileTYpe = 3
    Set swDoc = Nothing
    If Dir(PathName & FileName) <> "" Then
        Set swDoc = swApp.OpenDoc(PathName & FileName, swFileTYpe) '开启档案
    End If
    If Not swDoc Is Nothing Then
        ColumnNumber = 6
        PropName = Cells(HeaderRow, ColumnNumber)
        While Not (PropName = "" Or PropName = 0 Or IsEmpty(PropName)) '直到读完表头
            PropValue = swDoc.CustomInfo2("", PropName) '获取属性
            Sheet1.Cells(RowNumber, ColumnNumber) = PropValue
            ColumnNumber = ColumnNumber + 1 '下一栏
'            If swFileTYpe = 2 And ColumnNumber = 10 Then ColumnNumber = 13  '组件跳过读取零件的材料属性
        Wend '回到>直到读完表头
- f& h; R# ]1 V. `
这个 读取自定义 属性的  如何改成读取 配置属性的?????
8 _$ G/ v+ L) w2 s: F
  r2 _/ x0 G% E7 U6 J2 D
Sub WritePrp()
SavedFilesCount = 0
HeaderRow = 2
RowNumber = 3
    If UCase(Right(FileName, 3)) = "DRW" Then swFileTYpe = 3
    Set swDoc = Nothing
        Set swDoc = swApp.OpenDoc(PathName & FileName, swFileTYpe) '打开文件
    End If
        ColumnNumber = 6
        If PropName = "材料" And swFileTYpe = 2 Then GoTo 200
         If PropName = "材料厚度" And swFileTYpe = 2 Then GoTo 200
'            ConfigName = Cells(RowNumber, 3)
            PropValue = Cells(RowNumber, ColumnNumber)
            If Len(PropValue) > 0 Then
            swDoc.DeleteCustomInfo2 ConfigName, PropName '删除属性
            swDoc.AddCustomInfo3 ConfigName, PropName, 30, PropValue '新增属性
            End If
'            If ColumnNumber = 9 And swFileTYpe = 2 Then
'            ColumnNumber = ColumnNumber + 3
'            End If
200
        Wend '回到>直到读完表头
        Dim lErrors             As Long
        Dim lWarnings           As Long
        SaveOk = swDoc.Save3(1, lErrors, lWarnings)
        swApp.CloseDoc PathName & FileName '关闭工程图
        If SaveOk Then
            Cells(RowNumber, 2).Interior.Color = RGB(255, 255, 127)
            SavedFilesCount = SavedFilesCount + 1
        End If
    End If
这个 输入自定义 属性的  如何改成输入到 配置属性的?????
哪位高手 指导一下
9 `1 r+ n" H9 X6 D. H# X. U3 \: S% F/ m
& v3 @3 ]; L; n+ h& V
. M& n8 [. G1 ?. w" ]
发表于 2016-1-11 11:25:06 | 显示全部楼层 来自: 中国浙江嘉兴
http://www.3dportal.cn/discuz/fo ... ead&tid=1451365
  E8 D$ N: O% M5 J% q+ a
$ @& t, M8 v, h- |
6 ^0 O1 e  {# \( x. F4 v% Z$ x有關 配置属性 如上可參考看看
 楼主| 发表于 2016-1-11 11:33:45 | 显示全部楼层 来自: 中国上海
好的  谢谢
 楼主| 发表于 2016-1-11 12:57:06 | 显示全部楼层 来自: 中国上海
这个还是 改不好   有哪位高手 帮我直接改一下  贴出来  谢谢了
发表于 2016-1-11 13:21:57 | 显示全部楼层 来自: 中国浙江嘉兴
$ `$ f" E) {! V+ t/ k+ Q7 B
5 x$ S" {4 n  ^. i3 W( M$ G; I* CSub ReadPrp()  及 Sub WritePrp()    之編程皆不完整 (兩個宏都沒有 END SUB)
! ?" H3 G5 N! }% `1 i) h- t! I# K# |1 C1 o; f
需要幫助請重新上傳原始SWP檔- K, J$ W- Z3 |$ H9 p( W" C
! M* G9 |2 u2 m$ P( h& i4 c* P
- |2 h  j9 p6 h  Q' V! T6 t是配合EXCEL操作的嗎?   是的話也需上傳EXCEL檔
: B; ^: Z  F) u+ @) F$ Q
7 f1 ?! ]$ y! O* Q2 c! m6 {1 Q' X1 ?8 z: W8 u: }
 楼主| 发表于 2016-1-11 13:51:30 | 显示全部楼层 来自: 中国上海
我已经发给你了 网盘  帮我看一下 改改 谢谢了
发表于 2016-1-11 14:32:39 | 显示全部楼层 来自: 中国浙江嘉兴
litao036 发表于 2016-1-11 13:51
# S/ @3 D$ v+ {6 r: X* ]我已经发给你了 网盘  帮我看一下 改改 谢谢了
/ W# G$ |3 V6 R& m5 b
無法操作
2 U8 a4 N; X6 _0 X& D8 D/ t# E6 Y4 z$ [5 t6 S6 |& V
, Y$ F9 Q- U5 h* m7 q
& X$ ^; e, T0 w6 r. D
 楼主| 发表于 2016-1-11 14:37:31 | 显示全部楼层 来自: 中国上海
你是32 位系统?
点评
win7 64位元  发表于 2016-1-11 14:44
 楼主| 发表于 2016-1-11 14:42:34 | 显示全部楼层 来自: 中国上海
 楼主| 发表于 2016-1-11 14:45:53 | 显示全部楼层 来自: 中国上海
Solidworks 批量改名改属性工具.zip (141.15 KB, 下载次数: 61)
 楼主| 发表于 2016-1-11 14:51:42 | 显示全部楼层 来自: 中国上海
ryouss 发表于 2016-1-11 14:32! W0 S' [4 Q* Q
無法操作
2 x, c7 P- M9 O& J2 Y7 |2 M! M
我从新上传了  你在看看 哈哈
发表于 2016-1-11 15:00:03 | 显示全部楼层 来自: 中国浙江嘉兴
* l7 D; m7 w  g
3 e* H/ H# I. ~3 T點了 "系統註冊控件" 已不顯示錯誤了
+ o, \% h. u1 z+ o7 ]
0 |: u1 x7 {( B- q9 u3 s0 W! R但是 點了 "系統註冊控件"  什麼也沒動作2 L8 n: g  A7 |' \6 ^2 P7 ~- `( `4 Z
) _, f0 c6 }' @1 P% O; Z
應該陳述下如何操作
7 G/ j/ [; H; v% h7 Jexcel也是2010,宏的簡体字全部轉成繁体,就不知道是不是註冊繁版的因素.3 d% y+ H" h9 x! F8 N/ f" r
发表于 2016-1-11 15:18:04 | 显示全部楼层 来自: 中国浙江嘉兴
另工程圖也用不到  配置屬性' ]" A5 A& z# `
; e0 f. q' G* ~
sheet1.jpg # E9 I$ M& m# p3 q2 {; f
 楼主| 发表于 2016-1-11 15:23:00 | 显示全部楼层 来自: 中国上海
ryouss 发表于 2016-1-11 15:18  Y3 A! a' Q2 h' r& l$ f( ~) h
另工程圖也用不到  配置屬性
; z9 `. E7 b" ~+ O+ U
1、集成改名改属性;* a9 ~4 }  {2 a# f
2、菜单采用系统菜单方式,看着专业,呵呵,' C1 Q; g: {3 m; K' P
3、鼠标点击零件行可显示零件的预览图,
0 K0 X+ O7 b6 I! p' i5 }+ v7 g! r- ]9 l4、零件的预览图拖动图标题栏可以移到自己需要的位置固定;  f0 [: I" A/ ?1 m, R
5、预览图标题栏点右键可设大小,
5 Q- a! n% m3 X. ?; \* r* F, d6、增加环境设置工具;1 Z6 E6 G% Z% ]* F' s4 X
7、如果选取的零件有工程图,会在零件名的左侧显示五角星;改名时会将工程图的名字一并更改并关联。
. }) k# G9 n" u& J
8 h: |- ]. W" d/ E/ B. v1 o( h/ c3 J1 i% |; ], s/ z
使用说明:$ y" n4 w7 _0 I7 A' e; }6 R" U
1、详细功能自己体会;9 Z5 i1 I  }3 J3 p
2、表头1-6列请不要更改,7列及后续列可按照各自产品的属性值需要,自行更改。
发表于 2016-1-11 16:40:45 | 显示全部楼层 来自: 中国广东佛山
支持原创~
发表于 2016-1-11 22:24:34 | 显示全部楼层 来自: 中国山东莱芜
sw2016出现错误
发表于 2016-1-11 22:47:45 | 显示全部楼层 来自: 中国山东莱芜
可以读取外形尺寸,但是属性读后没有显示,属性是配置属性,是不是不支持。
发表于 2016-1-11 23:22:04 | 显示全部楼层 来自: 中国山东莱芜
试过,只能读取自定义属性,若能读取配置特定属性就好了,不知能否改,求助。
发表于 2016-1-27 21:05:29 | 显示全部楼层 来自: 中国山东莱芜
以下是闷人的做法,能否参考
) y: `1 Q. r# x# k【利用 Excel 批量修改SW檔案屬性】http://www.solidworks.org.tw/for ... hread&tid=26079
