发表于 2016-12-13 13:55:07
来自: 中国辽宁丹东
materiala = swModel.GetCustomInfoNames()& E- D. h) E$ D/ _' V# o
这一句好象是取属性名称数组! m x% w2 v/ b. }5 e$ L. J; J
, a" K5 u# k8 ?) c0 q8 b/ d$ Y
先写一个材料的自定义属性名与值0 k* R' |$ d" f, q) r! Y$ m% o( H
再取出来运用。% y# C' w' k2 }2 {1 g, |
如下本人方法:7 C9 x0 M5 J+ u
- Dim swApp As Object- ^/ S7 }$ E# J) R( y+ ]
- Dim Part As Object
! Q" M: @9 @' z G! q& k. X - Dim swModel As Object, b9 A3 B) j; e5 X0 d7 H, d9 S( Z8 H
- v4 R* E( P6 h8 r# x2 e* `4 [
- Dim Filename As String
# o( ?) s; q+ g - 'Dim Material As String! \% B# P7 h% M
- 'Dim No As Integer; A6 q3 T. t9 m7 S, l4 U& D
- 'Dim Nom As Integer
- A$ i. b( ? `$ f- j* g - Dim Title As String
! E* x- v& g$ i; w5 U6 c7 m4 ~ - Sub main()0 [ Y2 M. ?8 s) N" H0 w
- Set swApp = Application.SldWorks; h- t1 z" E' H# N
- Set swModel = swApp.ActiveDoc
9 T: W$ ~' N0 L8 J% y2 e: q
6 H$ m. q" P2 C, R0 m- 'Set swApp = Application.SldWorks" u% P& y G- @4 \( _
- Set Part = swApp.ActiveDoc
% U! Z# j( b( ]: v2 m/ |4 C2 R - Filename = Part.GetPathName()3 A1 `) e3 X9 D
- 'materiala = swModel.GetCustomInfoNames()
! L7 Z5 r% b/ C7 W - No = Len(Filename)
- O. T$ U, E% a - 'Nom = Len(Material)
- ], |' v1 V5 V; j0 P0 l. x4 Z
1 V! U8 P6 I" v, C0 Z1 n- Filename = Left(Filename, No - 7)
2 ]1 v6 U/ F+ s, i. G - 'Material = Left(Material, Nom)
5 D: m( D" ]! v! d& Y - 'Part.SaveAs2 Filename & "-" & Material & ".IGS", 0, True, False) L: B+ g; P2 A- j
- Part.SaveAs2 Filename & "-" & QsxZh & ".IGS", 0, True, False
& M( ]4 j9 K* h1 X _) V - Title = Part.GetTitle) _. N) m& ]; u' ?
- Set Part = Nothing& A9 p- O) e7 H! | m3 b. a0 g
- swModel.Save '保存文件/ y& U# C( I/ d* |8 s* B& P' Q
- swApp.CloseDoc Title; U% R9 {, `+ O! A7 n. H
- 'X = MsgBox("输出IGS文件在SW工程图同一文件夹", 0)6 O* m3 [' p( v. [$ w
- End Sub
4 O8 F c x& F" T- }0 U4 r' L
( w) k, Y4 [, Z$ s. |- Private Function QsxZh() As String '取属性值
6 B' Y+ Q: F/ t6 {, Y - 1 l; A1 _4 R- Q& F+ S/ l* Y7 t% _
- Dim retval() As String '自定义属性集合$ R2 ?) N& P6 ~3 P6 R
- Dim i As Integer' O0 z" L+ \) A# u" z- Y) r- f: N
- Dim Ming As String '属性名6 B: e" m7 V, X T. ^, e" g/ ?
- Dim Zdysxz As String '自定义值# x0 G6 X) s2 k+ X$ [( P
- Dim blnretval As String, x, D* r5 F) _- T9 c" c
- Dim XrZh As String '写入值7 G$ J0 K! x5 A! ?5 ?; b
- , ?) Y: D( b% K- \, U
- XrZh = Chr(34) & "SW-Material@" & "part" & ".sldprt" & Chr(34)
3 f v8 h9 L% \- u - blnretval = Part.AddCustomInfo3("", "temp", swCustomInfoText, XrZh) '写入自定义属性临时名称与值7 w+ z! U, r+ y+ j: I2 ~3 ?
- retval = Part.GetCustomInfoNames2("") '读出自定义属性名称集合7 Y: p; G; U1 D# x. E
- For i = 0 To UBound(retval)' L$ z; J* C7 x4 n A( p
- Zdysxz = Part.GetCustomInfoValue("", retval(i)) '读出自定义值2 k" l" z) A1 u7 [: @
- QsxZh = Zdysxz5 x7 r* O" |0 f3 g0 j# ~" s
- Next
2 {: Y- v2 G- C+ B; u - & M1 x8 R$ H A9 T, l4 e" U) N
- blnretval = Part.DeleteCustomInfo2("", "temp") '删除自定义属性临时名称
2 s8 {! s0 C8 q E0 s - , j5 @- X& f3 u- |/ Y
- End Function
' {5 V# l; M4 Z7 z' @
复制代码 * O9 ?' o! {3 K9 m
另存IGS.rar
(11.82 KB, 下载次数: 22)
