查看: 5096|回复: 3
[已解决] 20 GA SATIN STEEL是什么钢材???
发表于 2006-11-1 11:53:17 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
发表于 2006-11-1 19:52:50 | 显示全部楼层 来自: 中国山东潍坊
发表于 2006-11-1 21:33:36 | 显示全部楼层 来自: 中国上海
20 GA 是厚度 0.0359*25.4=0.91mm5 z/ v4 W: P% g
SATIN STEEL 是不是stainless steel, 不锈钢
8 B' ?1 o& L. MSATIN STEEL 光滑钢板?
$ H' p  d" L/ q' K
/ N7 T" X' o5 i: aGauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing.
GaugeSheet SteelGalvanized SteelStainless SteelAluminumStrip & Tubing
Gauge Decimal
( J# D: \2 j5 y# P(inches)
Weight
8 N- w. S5 h1 Z; |(lb/ft2)
Gauge Decimal
0 `0 n- |) K9 K4 F+ p6 V(inches)
Weight
& t! ^, C% v9 F(lb/ft2)
Gauge Decimal
4 J) I) L/ K# H4 n( c$ y9 s1 F(inches)
Weight8 u. F3 {4 D& y3 w8 T
(lb/ft2)
Gauge Decimal( x/ }5 x0 x( N! x) u
(inches)
Weight9 f! `/ Z) R# r$ O: c
(lb/ft2)
Gauge Decimal
9 I% G. q. j% x(inches)
380.00600.00620.0040
370.00640.00660.0045
360.00670.00700.00500.004
350.00750.00780.00560.005
340.00820.00860.00630.007
330.00900.00940.00710.008
320.00970.01020.00800.009
310.01050.01090.00890.010
300.01200.5000.0160.6560.01250.01000.1410.012
290.01350.5630.0170.7190.01410.01130.1600.013
280.01490.6250.0190.7810.01560.01260.1780.014
270.01640.6880.0200.8440.01720.01420.2000.016
260.01790.7500.0220.9060.01870.7560.01590.2240.018
250.02090.8750.0251.0310.02190.01790.2530.020
240.02391.0000.0281.1560.02501.0080.02010.2840.022
230.02691.1250.0311.2810.02810.02260.3190.025
220.02991.2500.0341.4060.03121.260.02530.3570.028
210.03291.3750.0371.5310.03440.02850.4020.032
200.03591.5000.0401.6560.03751.5120.03200.4520.035
190.04181.7500.0461.9060.04370.03590.5070.042
180.04782.0000.0522.1560.05002.0160.04030.5690.049
170.05382.2500.0582.4060.05620.04530.6390.058
160.05982.5000.0642.6560.06252.520.05080.7170.065
150.06732.8130.0712.9690.07030.05710.8060.072
140.07473.1250.0793.2810.07813.150.06410.9050.083
130.08973.7500.0933.9060.09370.07201.0160.095
120.10464.3750.1084.5310.10944.410.08081.1400.109
2 Z2 d9 M' F* k
; M, ?/ @8 J  ?7 z$ x[ 本帖最后由 huase 于 2006-11-1 21:35 编辑 ]
参与人数 1三维币 +10 收起 理由
wuling + 10 应助
发表于 2006-11-1 21:42:17 | 显示全部楼层 来自: 中国北京
原帖由 shangming125 于 2006-11-1 19:52 发表
6 n8 z( v/ v3 z! F0 E是不是20G啊!我是猜得啊!
0 N0 V" k7 `" `
; K! b5 s1 e) |2 x4 s
6 q! ^4 @; C7 f  H: I; C肯定不是20G的,因为20G是20号锅炉钢,不可能是stain steel的
