查看: 1332|回复: 3
[求助] mastercam数控车后处理问题
发表于 2019-12-8 13:42:50 | 显示全部楼层 |阅读模式 来自: 中国河北
请教大神们,车床后处理怎么样修改,能把G2或者G3改成非模态格式的,也就是说G02 X100.Z50.R2.  后面再跟一条不把G02给省略掉,万分感谢诸位大神们的解答!!!
发表于 2019-12-8 22:50:36 | 显示全部楼层 来自: 中国吉林
以默认MPLFAN为例,搜索 , C; B  P! {- c' P) Y) @: S
psgcode         #Output the Gcode based on the current plane
  w2 s+ R% m% V5 K1 V4 U; I/ V找到代码1 O8 M/ ?9 H  P9 ~  ~
psgcode         #Output the Gcode based on the current plane# l" E) I: I0 w8 ?, h
      if c_ax_flp,( w) Z5 }6 k2 `  C# T3 V
        [  p3 t$ @* o+ h" n, S
        #Reverse arc direction for c_axis flip
" C' U7 H  j9 ~7 l# C; m+ t3 R        if gcode$ = two | gcode$ = three,
4 L4 r: ]4 x/ z1 {9 j' b$ Q# q          [4 g* _5 C. {' M4 c' r
          sav_gcode = gcode$
8 Q  X' P9 q+ ~6 P* o          gcode$ = (5 - gcode$)  #G02->G03 or G03->G029 O5 d2 p, _+ h- Z1 B; Q( ^# c3 i
6 F6 t" q( z( X- V        ]
0 W  h+ y9 s( ~. f          if plane$ = zero, `sgcode6 O) l" ]% |7 [3 f% v
      if plane$ = one, `sgcode1
8 l* s  G" B/ a# G6 f6 l      if plane$ = two, `sgcode2
& }5 _5 Z* r/ H" f1 F      if c_ax_flp, gcode$ = sav_gcode& W8 y, G4 d/ f5 ?9 o2 p# T
* A/ o5 Y# j% L' F1 s, ~5 G, q
加点作料改为
+ l0 }7 u! u0 J' l, l/ {5 zpsgcode         #Output the Gcode based on the current plane
5 G  p# `- _3 O      if c_ax_flp,
$ U5 D$ x! ?/ _5 v) r+ D        [* }" `1 i6 I  q2 i% Q! a
3 G0 y" P% ^7 q! F3 n. b: q        if gcode$ = two | gcode$ = three,5 d: K$ @" G3 \! K' m- N
          [% p9 A1 I3 N, m9 P6 N
          sav_gcode = gcode$
( Z% E/ j4 }; A+ }7 J3 [          gcode$ = (5 - gcode$)  #G02->G03 or G03->G02. }% P( \; g7 ]% w% N% z2 d4 [
          ]# O3 X. \% A% R5 Q; n- M4 ^" x
0 t& I* K/ w7 \% u0 u1 {      if gcode$ = 2 | gcode$ = 3, result = force(gcode$)4 t* h  m( L. y6 S# }
          if plane$ = zero, `sgcode  F& D0 U& G- B, E. J
, X& Y1 q3 S/ d4 A$ h- v& X      if plane$ = two, `sgcode2
6 ~/ n: |% O0 q8 I2 Q- `      if c_ax_flp, gcode$ = sav_gcode3 j; d9 ?4 W. K; w
保存 完事
发表于 2019-12-8 23:29:11 | 显示全部楼层 来自: 中国广东深圳
学习大佬
发表于 2019-12-8 23:30:40 | 显示全部楼层 来自: 中国广东深圳
路过不买 发表于 2019-12-8 22:50
! f& p& a6 R3 H7 v以默认MPLFAN为例,搜索
+ j, ?/ @$ n; b+ qpsgcode         #Output the Gcode based on the current plane
7 w3 M# H" @% l* b找到代码
" u% M  a  Z" t/ M' U( B' R% C表哥:那可以问下后处理添加强制备刀,不需要开启预备刀怎么改
