楼主 |
发表于 2019-12-13 16:46:23
来自: 中国天津
明暗图渲染存在于CAXA的另一工程图环境中,默认为隐藏状态,如果希望打开,可以使用以下方法:! U3 ^$ K j% E- B6 E T
首先在安装路径下下D:\CAXA\CAXA IRONCAD\2011\Config找到文件IronCAD.config,注意属性只读勾选再修改
2 c# U* S! d1 I% n% {4 p! n<!--( U- ^/ ?0 m7 m
Comments:% p6 {, m! J! w* O
This file is used to configure IronCAD run time info.
& \% u% _$ j6 J+ P, g PreDefined Variable:- C* l( y2 U. |+ @
{INSTALLDIR}: the directory where the whole application installed
4 c7 O% _% K- `. n {APPDIR}: the directory where the application executable file installed( H) d* t7 w. a5 _& v
; _" X1 ^9 ` R/ `5 P<IronCAD Version ="12.0">
# v! a* ]' n/ P1 @5 T <Configuration>/ |) y# Y. O* ^" }( g R
<Global>
3 j, W7 X1 D- G. K0 H <!-- the DocTemplate section contains all the external document template declare -->. C3 G& o8 |; S R/ a3 \8 e
<DocTemplate> v+ F! A5 V) N+ Z
<Add Name="TechDrawing" Entry="{APPDIR}3iISTD.DLL" ModuleDir="{APPDIR}" Enable="False" />
( a; z4 [' M" f! x5 a1 R0 i- x/ E <Add Name="NEB" Entry="{APPDIR}3iISNEB.DLL" ModuleDir="{APPDIR}CAXADraft\bin\" Enable="True" />: \% t! L7 N; C- I c1 M) W
</DocTemplate>
7 Z8 G7 e y: ~) X2 ] </Global>
3 A$ N: Z+ w2 L+ H <!-- the NewUserSetting contains all the default setting for new user -->
5 I$ H/ `, H |& {, y <NewUserSetting>" ^4 Z u. ~; J1 q7 Q+ D
, H# G: E# W: e2 @5 O( l1 s4 G
</NewUserSetting>
$ D8 V6 z8 ~* h </Configuration>
: E, r. v8 }5 u% }4 j# R</IronCAD>
- [4 c0 v% b; d8 f/ t" V红色部分False改成True,再打开就有了
1 g" j9 R) q( [: S$ d9 a7 @ |
