查看: 1916|回复: 4
[已解决] problem when transfer to .pdf file
发表于 2006-11-11 02:08:52 | 显示全部楼层 |阅读模式 来自: 加拿大
i use solidworks 2006 creating drawings.(more than 3 page in one file).and i want one of them tranfer to .pdf file.but i can't do it. $ }/ E( o2 v! e
; H8 r% A1 r9 b
when i use SAVE AS to .pdf file, all the drawing are transfered.
7 S8 z" q2 U1 C+ C0 K& h) w5 | 0 s5 j9 Q! x2 R0 A% K) X8 `" P
could someone tell me how to transfer one page to .pdf file.7 ^0 s: A* _4 {/ h% h' f( V; W- M
5 `, B/ D3 o4 O6 {1 Pthks
发表于 2006-11-11 12:49:33 | 显示全部楼层 来自: 中国宁夏银川
网上word转PDF工具很多,搜一下就可以解决。
发表于 2006-11-11 13:13:11 | 显示全部楼层 来自: 中国上海
转图时有要求转的页面选择提示,选要转的不久得了。
 楼主| 发表于 2006-11-14 04:46:57 | 显示全部楼层 来自: 加拿大
回复 #3 zhangsj 的帖子
thks.4 p( t( e9 L- N; t: t% s8 i
' Z+ R/ G2 I/ }1 B
% M" I/ U* r, K% {but now ,if i save as ,i can't see this massage.
/ ^0 W- I6 A% |: X, S* M0 Zhow can i get this 页面选择提示? what happen to my solidworks 2006 software?
发表于 2006-11-14 08:25:52 | 显示全部楼层 来自: 中国河北廊坊
File list and file name must be in English. You can try.
