查看: 1969|回复: 2
[已解决] monel(蒙奈尔)的力学性能如何?
发表于 2006-12-8 17:03:58 | 显示全部楼层 |阅读模式 来自: 中国湖北
只知道monel(蒙奈尔)是一种合金,可以抵抗腐蚀,可以和不锈钢相媲美,但不知道他的性能怎么样,还请各位大虾大显身手哦!!谢谢!! :handshake8 o! F% n' |- d: f2 e6 s7 U
8 J7 G4 E& \* U$ D( l$ L/ x1 a
[ 本帖最后由 wwjxgz 于 2009-5-16 19:17 编辑 ]
发表于 2006-12-8 18:07:29 | 显示全部楼层 来自: 中国广东深圳
Monel is an alloy [size=-1](i.e. combination of two or more elements of which at least one is a metal, and where the resultant material has metallic properties). It is based on nickel (65-70%) and copper (20-29%) and also contains iron and manganese (5%) and other compounds. Monel was discovered by Robert Crooks Stanley who worked for the International Nickel Company (INCO) in 1901. The new alloy was named in honor of the president of the company, Ambrose Monell.
: b- b( Y: S; f0 d[size=-1]Monel is a trademark of Special Metals Corporation2 y7 k3 \( q. v; j) n# n5 D& Z5 t
% y( F& ?" y6 U" O" EThere are different commercial types of Monel such as Alloy 400, Alloy 401, Alloy R-405, Alloy 450, Alloy K-500, Monel 404 Copper-Nickel Alloy. Standard product forms are round, hexagon, flats, forging stock, pipe, tube, plate, sheet, strip, and wire.# {0 Q" Q( r6 F7 w. J
Characteristics of Monel- Highly resistant to corrosion. Monel is well known as a corrosion strong, rust-resistant material. [size=-1]It is[size=-1] resistant to corrosion and acids, and some alloys can withstand a fire in pure oxygen. - Stronger than steel 2 }: `6 l- S& x, u9 t% n
- Malleable " U* ~3 x* b7 I( N5 o+ c
- Low coefficient of thermal expansion # E/ |! x7 `6 w" F- [9 p
- Highly resistant to alkalis . F& A$ I; g1 G1 l& k2 u( D
- It can be welded, brazed and soldered ; Q9 W$ g  `% C+ }; |6 A1 k8 }7 S
; Y' p5 e7 j5 ~+ i
Market applicationsMonel is used for marine engineering, chemical and hydrocarbon processing equipment, valves, pumps, shafts, fittings, fasteners, and heat exchangers. It is also used as part of metal instruments and frames of eyeglasses.
0 h' p* s, [8 ]. |+ k) w: f8 S; k8 LIn 1950's Monel started to be replaced by stainless steel which could produce the same forms at a lower cost (due to use of less nickel).
" N3 E, |7 I, ?1 K' S2 F# NMaterial notes
+ J5 U/ ]1 H& ~5 X- x
Typical Monel 400 has the following composition in weight (%).C      Max 0.3
; d8 D# ]- f. e: T. Q% H5 cCu    28 - 34
, ]: L9 `: M2 AFe    Max 2.5 - Q) N& o$ S& J. z1 R, m
Mn    Max 2 ; I' H  _; ?& m8 l7 p% N6 u
Ni     Min 63
( y$ ]: H  a$ L  P9 J' S4 W2 E1 d6 VS      Max 0.024
8 c- p& K* ~! x% H+ [5 cSi     Max 0.5
9 g: ~! {7 z; b; d% m$ w" C8 o2 d2 h4 T
MECHANICAL PROPERTIES
Tensile strength, Ultimate 550 Mpa
Tensile strength, Yield240 Mpa
Elongation at Break48%
ELECTRICAL PROPERTIES
Electrical Resistance[size=-1]5.47e-005 ohm-cm
Curie Temperature (the temperature above which a ferromagnetic substance loses its ferromagnetism)35°C
THERMAL PROPERTIES
CTE, linear 20°C13.9 µm/m-°C
Heat Capacity0.427 J/g-°C
Thermal Conductivity21.8 W/m-K
Melting Point1300 - 1350 °C
Solidus1300 °C
Liquidus1350 °C
发表于 2006-12-9 15:03:46 | 显示全部楼层 来自: 中国黑龙江哈尔滨
楼上真是高手,我最怕看英文了,能否告诉我该材质的硬度最低多少?
