查看: 2267|回复: 3
[分享] 铝合金论文
发表于 2006-12-23 19:16:44 | 显示全部楼层 |阅读模式 来自: 中国浙江宁波
铝合金论文
% D4 s$ R7 i* ?7 G6 C3 Z) _ * K0 l0 C' K7 I7 D# }
In¯uence of aging parameters on the mechanical
3 k+ T# |& c  R) e7 Jproperties of 6063 aluminium alloy, l, b* |8 O6 A
Ra®q A. Siddiqui*, Hussein A. Abdullah, Khamis R. Al-Belushi5 s5 b( R9 d; J/ l6 g$ o7 }
Department of Mechanical and Industrial Engineering, Sultan Qaboos University, PO Box 33, Muscat-123, Oman& \& ^8 e& o# M0 F. r  b
Accepted 17 December 1999
铝合金论文.pdf
678.67 KB, 下载次数: 22
 楼主| 发表于 2006-12-23 19:17:36 | 显示全部楼层 来自: 中国浙江宁波
铝合金论文6013合金
Mapping of the rate-controlling steps for environment-assisted9 |8 s0 X4 g" a
fatigue crack growth applied to the aluminium alloy 6013 T6# Q- o) G$ k% X+ t- |# n  Y
F. Bergner *, H. Bersch, H. Worch, G. Zouhar! W$ z; T  k+ S1 Z  p* m* j% b
Dresden University of Technology, Institute of Materials Science, D-01062 Dresden, Germany
% H8 Y( A3 t0 UReceived 16 July 2001; received in revised form 17 December 2001; accepted 20 December 2001
06022321364005809.pdf
142.35 KB, 下载次数: 9
 楼主| 发表于 2006-12-23 19:19:48 | 显示全部楼层 来自: 中国浙江宁波
铝合金论文7010合金
The application of advances in quench factor analysis property
& Q8 W& S  N) J6 ]/ d8 _7 wprediction to the heat treatment of 7010 aluminium alloy1 M8 H- A. I4 b4 R
Robert J. Flynn a,∗, J.S. Robinson b
3 Y6 P- N1 Q! N6 P9 Y, _a Materials Ireland Research Centre, University of Limerick, Limerick, Ireland
, S" ~' f' \, p' k, g( m4 T( h7 Qb Department of Materials Science and Technology, University of Limerick, Limerick, Ireland
06022412411814145.pdf
229.26 KB, 下载次数: 11
 楼主| 发表于 2006-12-23 19:21:37 | 显示全部楼层 来自: 中国浙江宁波
铝合金6063合金
Abstract( \$ N5 ]2 A- v) `: ^
Wear behaviour of age-hardened 6063 aluminium alloy was evaluated under dry sliding conditions. A certain part of the2 b9 s: r# \- W. I: s' h  u5 `
aluminium samples was solution treated at 510 jC for 2, 4, 6 and 8 h, water-quenched then aged at 180 jC for 4 h, and the other% ]+ ~. J9 J( K9 u# ~& F
part was solution treated at 510 jC for 6 h, water-quenched then aged at 180 jC for 1, 2, 3, 4 and 5 h in a muffle furnace. The% k  F  z' g- V& ^; @7 R
as-cast and the aged samples were fully characterised before and after the wear testing using hardness, profilometer, scanning
" g$ b; I  R" ]" m5 D( C: p" {electron microscopy (SEM), optical microscopy, X-ray diffraction, and energy dispersive detector (EDS). The wear tests using8 d, M" c3 w# d; I" h- {
on a pin-on-disc machine showed that the aging treatments improved the wear behaviour of AA 6063 alloy compared to as-cast# ?, L4 L4 O& M# P8 \- m
samples.* \% ?2 [( f4 }9 c
D 2003 Elsevier Science B.V. All rights reserved.# O+ l! J6 J5 `* q2 Z/ t
Keywords: Artificial aging; Aluminium alloy; Wear; Pin-on-disk tribometer
hhh.pdf
1.02 MB, 下载次数: 16
