发表于 2009-1-4 16:56:03
来自: 中国江西南昌
I don't know the box what you said used for what product. Because the box used for different product, you need to use different method to calculate. I advice you to use software such as pro/e、ug and catia this software all had the function to analysis.
& A" P2 b. Y7 E6 x v+ y but has a question, use this software, it is difficult to evalulate the results if it is ok, I think this need your experience. usussaly the result of the intention is not smaller the material of your product.
; |' ^& D. Q% x$ @' P; P# O/ b; W I usually to analysis by Pro/E, It is enough us to calculate. 3 P! h' w( _4 x6 x( N$ a3 a: }. ^, v
Of course, you can use the software of Analys. |
