查看: 1688|回复: 3
[已解决] 为什么整圆工件而程序却是很多小段?
发表于 2007-5-20 02:46:20 | 显示全部楼层 |阅读模式 来自: 中国天津
% Y& y+ ~8 e$ z  _/ ]* A7 q) q1 f! [
为什么整圆工件而程序却是很多小段?甚至有的被处里成直线,这样的程跑起来很慢,而且也漂亮!( S9 K& H3 T, W; A
N0030 G00 G90 X19.126 Y-28.431 S2000 M03  M08
9 C$ k, i  r' {: F! xN0040 G00 Z33." Y" ?( I9 X% I6 b- k# I- O
N0050 G00 Z27.' R* x  `9 n" p' B. U5 o" f
N0060 G01 X19.126 Y-28.431 Z24. F800.
  r2 q' @! `! T5 R! WN0070 G03 X13.129 Y-28.375 I-3.057 J-6.297
& b2 ~, q. c5 ^6 Z! gN0080 G02 X10.821 Y-29.333 I-13.127 J28.368
$ y6 s; c' I& Z$ s: C; s5 GN0090 G02 X-8.776 Y-30.008 I-10.819 J29.326
( a' h! g/ i9 h8 R9 @. |N0100 G02 X-21.544 Y-22.655 I8.684 J29.842
: M' @! w, }& c4 u$ vN0110 G02 X-22.655 Y-21.544 I20.752 J21.8635 v$ d2 l! R( f
N0120 G02 X-30.797 Y-5.386 I22.515 J21.476/ I! x6 {: \$ z+ ~2 Q
N0130 G02 X-26.285 Y16.927 I30.787 J5.388" F1 w; H4 l8 t4 v( `9 [, k
N0140 G02 X-8.776 Y30.008 I26.282 J-16.922
  e3 q/ G3 s& m* j& e0 c# ^N0150 G02 X16.927 Y26.285 I8.776 J-30.003
! c1 Y# ^# o, AN0160 G02 X25.227 Y18.466 I-16.827 J-26.177! k$ @6 M( }( M' i/ ]
N0170 G02 X26.16 Y-17.119 I-25.213 J-18.466
1 K. o. A  L+ ^' q' L" zN0180 G02 X10.821 Y-29.333 I-26.158 J17.112
- G- U- B+ U4 m% V9 o  ]& w4 Y- x& R0 uN0190 G01 X10.47 Y-29.499 Z23.897* E8 M; B  a* L% d
N0200 G01 X10.117 Y-29.662 Z23.793
* i8 `7 G" L  G0 l# q/ cN0210 G01 X9.761 Y-29.82 Z23.697 o: ]; g; y+ ~1 R9 I
N0220 G01 X9.404 Y-29.974 Z23.586
  l2 H; O" z0 k3 e# D, CN0230 G01 X9.044 Y-30.125 Z23.483
7 O$ Z$ P$ O1 I- \N0240 G01 X8.682 Y-30.27 Z23.379
' s- T: e+ B! t" c8 {/ g7 f3 BN0250 G01 X8.317 Y-30.411 Z23.2767 o$ H8 W$ b5 N" E# W7 H5 U; H$ T
N0260 G01 X7.951 Y-30.548 Z23.172
. I% Y; `* N* r, Z4 C! b( EN0270 G01 X7.582 Y-30.681 Z23.069
2 x7 O! i& j. k  E. `N0280 G01 X7.211 Y-30.808 Z22.966* [! i/ [( r8 S
N0290 G01 X6.838 Y-30.932 Z22.862
3 \6 a' A6 S* h# X% r$ Z0 {N0300 G01 X6.463 Y-31.05 Z22.759
( d! @$ X+ i0 DN0310 G01 X6.086 Y-31.165 Z22.655  T9 i4 W8 V4 O( o! E& L
N0320 G01 X5.708 Y-31.275 Z22.552
) H& ?- E# L3 T, O# D: J7 sN0330 G01 X5.328 Y-31.38 Z22.448, a/ B- c4 H0 f; N" }3 K
N0340 G01 X4.946 Y-31.48 Z22.3456 t7 n1 b5 Q! e
N0350 G01 X4.562 Y-31.577 Z22.241
, j3 V2 Q7 K- Y# a8 L% {" pN0360 G01 X4.177 Y-31.668 Z22.138
' V& w5 ]  M" c" pN0370 G01 X3.79 Y-31.755 Z22.034...............................................(这么简单的刀路就有300多段程序?)
发表于 2007-5-20 06:34:37 | 显示全部楼层 来自: 中国山西太原
呵呵 长见识了                    楼主高手啊
 楼主| 发表于 2007-5-21 03:18:10 | 显示全部楼层 来自: 中国天津
请高手多多指点
发表于 2007-5-22 15:47:19 | 显示全部楼层 来自: LAN
回答!
在机床输出的时候给个参数了,然后看看后处理有没有问题了。
