查看: 1886|回复: 1
[已解决] 在UG4.0中做仿真 NASTRAN提示以下错误
发表于 2007-5-22 12:59:09 | 显示全部楼层 |阅读模式 来自: 中国北京
在UG4.0中做仿真 NASTRAN提示以下错误  y8 A6 n, E2 M! S8 ~$ O8 p
) ?) T* n3 s& n& b1 S- I; f3 x3 [
请帮忙解决,先谢了. T9 d  g9 N! u( p( {
( f- n6 m4 E! T
' J7 i1 m2 O2 \' i
列出信息创建者:     Owner
8 ~' l0 J! ]& g% \* g3 p日期                           : 2007-5-22 11:11:48$ q* }& \; L; }1 u3 A9 K+ P4 U4 L
当前工作部件              : F:\hy_sim2.sim$ }  Y8 X" z9 z# S) ^, C
节点名                      : hedy-7dedff6bf9
7 f8 B' @& c+ e" F! J============================================================
" {+ f1 l0 l; S+ g& T, E" y+ S& m3 d$ \
9 G3 V! s& U7 C9 y' o------------------------------------------------------------
9 J/ u4 h- U0 O) y, b' P" D1 o+ W/ J, }& ?. d9 ^6 |5 q' H# M3 V
解法综合检查错误汇总
* L/ U) v+ f: ?! W# T) d
% K! t! P" a6 R------------------------------------------------------------- U) {5 v; d7 C- y' Q" ?6 r7 n3 G$ J
4 }: U& Y" S" u+ c6 D& I6 X
解算器是 NX NASTRAN DESIGN
  @/ l" d+ W. w( B+ g2 y环境: NX NASTRAN DESIGN - 结构
9 r1 e4 l3 }" G  Y) c' t解法是 线性静态 - 单个约束
& @% {5 D8 _/ b0 }* C& C6 b2 R/ B) O/ b7 |6 r4 q" ~! o
- ~! f0 x0 U% H, @
2 j; b# Q# I, ], f2 S- oMesh-Based Errors Summary+ d; D! _9 \$ z9 [# F
$ |/ b8 O" W- _7 J( d错误
; _0 ], ~3 U# E0 xNo material associated to mesh "3d_mesh(1)".
) M" p. H8 }) p& \7 OEither no material is assigned to the mesh or some of the underlying geometry (body) do# g0 L% S& T7 j9 j1 E
not have a material.
" A& M9 R- X- YSUGGESTION: Apply a user defined material to the mesh or to all of the underlying
% P5 h; I& c- J8 zgeometry (body).
5 O; g, }* c4 B4 `  ^Total: 1 error and 0 warning6 ?3 T5 _# a7 d! \7 P3 o
4 f3 t2 Q' p3 FMaterial-Based Errors Summary
0 R  T6 ~# O1 B' q7 u/ E-----------------------------# R) p! Z9 e# ?4 M( z) X- E, ~
Total: 0 error and 0 warning  }0 t4 v0 f  @, l; h# ~6 `
4 v% ^( e3 S& Q$ \# k* j+ \Solution-Based Errors Summary3 c  v3 j: M/ e8 y
-----------------------------. m& @+ o0 C, k& r' ?
Total: 0 error and 0 warning( Y! N; `# K) }, l
( b" p- L" W- a- R/ ^8 A
Load/BC-Based Errors Summary
8 I, h# U, ?7 ~% m% B5 P- K; {/ l----------------------------
+ x: V1 G5 g/ {# A警告4 m2 `: m% Y5 f7 k! o0 ?0 D! t8 k
Constraint "Fixed(1)" is applied to a mesh that has a face affected by tiny features.2 z' v9 t1 n% f0 V( ~+ [7 F3 O
(highlighted).
- _( |6 N4 I+ R* A8 k* ?8 h, {8 tThe geometric constraint may not be distributed completely. Use the expanded display
  H" c6 u# ]0 E, Y3 \style of the constraint to verify. Meshing the highlighted geometry again may correct3 z* d6 F" H  z1 o) q$ u& X1 K
this condition.  S! t/ l1 ]: ^  W4 d/ R
警告( q' j) O+ p5 ^7 E0 T; l1 u9 ]
Load "Force(1)" is applied to a mesh that has a face affected by tiny features.
* Q. R7 _' }5 @" f# f  I(highlighted).
$ X/ V$ E" ~; }( d: a; RThe geometric load may not be distributed completely. Use the expanded display style of! A8 s9 E) p3 w
the load to verify. Meshing the highlighted geometry again may correct this condition.1 E1 Q1 W' U5 ^0 U+ I
Total: 0 error and 2 warnings% p9 L* _1 T( e; z* L0 s7 n3 _( e
- S4 @+ K0 [; D" j# }( k5 ]
Nastran Model Check Completed
发表于 2007-5-26 11:08:52 | 显示全部楼层 来自: 中国四川自贡
没有加材料,网格问题应该是超过雅戈壁了
