发表于 2007-5-31 09:14:42
来自: 中国江苏苏州
EN AW-2011 / ISO: Al Cu6BiPb : l0 d( F1 i+ D
Composition: Al 5.5Cu 0.4Bi 0.4Pb
1 N8 I! q4 o; M/ x5 d: k- MApplications: Screw machine products: various machinery components. Screws, bolts, fittings, nuts, automatic lathe products. Applications where good machinability and high strength are required. + j5 E; z" y: O# k. y& z
Characteristic Properties: Excellent free machining characteristics. Heat treatable high strength alloy with a strength slightly lower than 2007 and 2030. High fatigue strength. & m2 e4 W- S4 Z4 E4 W
Precautions and Warnings: Low corrosion resistance for outside applications. Hard anodizing or other protection is recommended. - R. t7 n% p4 R Z' s5 Z
Product Forms: Bar, Rod, Wire, Tube |
