查看: 2190|回复: 1
[已解决] 请教技术资源组----关于AISI标准
发表于 2007-6-5 13:37:31 | 显示全部楼层 |阅读模式 来自: 中国江苏镇江
本人收到几张美国图纸,对上面的材料不是很清楚,请技术资源组不吝赐教:
3 r1 {. T8 U1 X" l1 M. QAISI  A-4140 H. R.
! D, ?5 @  I0 p# p2 K+ A0 h9 Q- `" G! qAISI  A-4340 H. R.
% w. n2 S. O8 u) w/ C% N6 dAISI是哪个标准阿?他与ASTM标准一样吗? 9 b" d' e8 n: b( ~! ]8 f
麻烦高手帮我查一下以上两种材料对应的中国材料代号
+ o- S6 q+ |. O% D8 O& I 不慎感激!
发表于 2007-6-6 20:19:48 | 显示全部楼层 来自: 中国
Subcategory: AISI 4000 Series Steel; Ferrous Metal; Low Alloy Steel; Medium Carbon Steel; Metal
2 V' w( b" |' ^9 Z) y7 T% Y9 [: }6 v4 {8 B1 l/ w) M1 d2 t
Close Analogs: AISI 4140H' h% c1 y' S: q% m% r
9 z  Y: G9 g% R1 z/ D
Key Words: AFNOR 40 CD 4, AFNOR 42 CD 4 (France), ASTM A322, ASTM A331, ASTM A505, ASTM A519, ASTM A646, B.S. 708 A 42 (UK), B.S. 708 M 40 (UK), B.S. 709 M 40 (UK), JIS SCM 4 H, JIS SCM 4, SS14 2244 (Sweden), MIL SPEC MIL-S-16974, SAE J404, SAE J412, SAE J770, DIN 1.7225, UNS G41400, AMS 6381, AMS 6382, AMS 6390, AMS 6395, IS 1570 40Cr1Mo28, IS 4367 40Cr1Mo28, IS 5517 40Cr1Mo286 Y9 `4 r9 I, H" F+ R
3 V( e0 \! Y  Y# }" }Component    Wt. %  - j% L) l) W4 K# B" k
! G3 D# r' w' m) R9 x- ?' A - B# K; Z' a- Q; |( c# L3 N# W
C 0.38 - 0.43
( H$ q/ q- A% r1 W! q& v# N# GCr 0.8 - 1.1
) l: _/ E. ^1 hFe 96.785 - 97.84
) Y% v( z+ S; C* q8 O+ e7 LMn 0.7 - 1
- I9 ~1 b* m, U/ k6 r( v/ HMo 0.15 - 0.25
/ g. b; Q/ W$ ?3 }: i& @P Max 0.035   . |) l/ E/ R% g/ k9 t0 S3 W
S Max 0.04   0 |) x7 `  i$ [& V  _; f
Si 0.15 - 0.3
; K" `% }) c2 U( }6 i & f; \6 }) d: f/ D
: r. g! }! \/ h& A( ?Material Notes: : T4 m( |, r3 G+ W) ?% q
Normalized: heated to 815?C, air cooled. Medium-carbon steel with high hardenability and good fatigue, abrasion and impact resistance.9 Y+ Q  b: C# U8 P/ U' y2 R
Subcategory: AISI 4000 Series Steel; Ferrous Metal; Low Alloy Steel; Medium Carbon Steel; Metal  j7 v* R8 h) \3 b+ |( n4 ~
% O/ f+ y9 F* V
Close Analogs: AISI 4340, AISI E4340, AISI E4340 H6 p( M) w3 h7 j% S. v2 |' c2 L4 N
2 H, q2 W( a- D- r; t3 y% _Key Words: alloy steels, UNS H43406, ASTM A304, SAE J1268, DIN 1.6565, IS 1570 40Ni2Cr1Mo28, IS 1570 40NiCr1Mo15
1 [# o* e9 M7 G/ w  V0 O; T4 J- v
. D7 D$ |9 |* \  E. SComponent    Wt. %  : l6 F2 b' A0 @; X! P
+ s6 I2 ^! w+ d" B1 K, B& {( S6 O
% h. f' H( v9 {8 M) `
C 0.37 - 0.44
& i* B0 Z6 W$ f' OCr 0.65 - 0.95   2 A. J9 [' ]% y, x9 s. a8 B  r7 `
Fe 96   $ G- G! z7 H) b8 k+ Z6 L+ ~& r
Component    Wt. %  ; b" v7 M1 w2 S' j
- L# ^- x* S' \ ' {' k) R6 t" [
Mn 0.73
- Y4 r) }, \. k& X' EMo 0.2 - 0.3   + X( c- d. M3 r! \
Ni 1.78
$ x8 ~+ M# O6 ~) A Component    Wt. %  7 I* C" i. H3 [7 u1 ?- {: d
  w- M8 g+ i0 C& z1 X : n" b. [6 [7 g1 U, M* f+ ^
P Max 0.025
- W$ w6 g8 ?" h8 n3 G9 OS Max 0.02
9 n8 I+ v! q0 X" G2 o" LSi 0.23
9 _$ G; ~; [9 S% B   w* I/ D3 z% r, R" T7 O
. ]% T7 ]4 e* H5 U, F7 }. BMaterial Notes:
& f6 q9 v: c4 @. MTransition temperature: - 90?C (50% Brittle); \. a1 p' G. i0 y/ x
7 v2 e( E, L+ m6 w2 |) \Click here to view available vendors for this material.
! K1 C" n0 T" ]0 d  j
1 h, I: ^" W5 X* R. K; x+ v7 f' W8 B New suppliers have been added for this product during 2007! The list of suppliers can be seen by clicking the truck icon to the upper right or the text link just above.
) V* B, p3 r" k3 }
. g1 M. p6 w; S) D$ W) QPhysical Properties Metric English Comments
5 h' }+ }  ^: o) W' C8 _. ?
9 F! I  I- }/ D! T4 n/ K ! T! F4 k9 R* T1 f0 C8 t1 ~
Density 7.85 g/cc 0.284 lb/in?   " v  m/ l; d% {$ f+ g
! r$ t; e9 Q: B  q$ B
Mechanical Properties
/ \7 [- T, [1 r, N8 z & A! H  @  w4 e8 A
3 `. j( h- ]1 @, h. K. g
Hardness, Knoop 381 381  Converted from Rockwell C hardness.
) L. R( @6 x/ p5 J3 cHardness, Rockwell C 38 38   # o8 a. y5 R' L
Hardness, Vickers 368 368  Converted from Rockwell C hardness.
) B/ n& r8 Z9 Y0 L, `9 EModulus of Elasticity 205 GPa 29700 ksi  Typical for steel
5 L9 G+ W6 o  {* w/ WBulk Modulus 140 GPa 20300 ksi  Typical for steel. ( i! j6 h3 ?3 ?+ |8 S- f3 w
Poisson's Ratio 0.29 0.29  Calculated
3 U- R, ^) |  b; a9 T/ ]( g9 W$ Q3 iCharpy Impact 20 J 14.8 ft-lb   7 E0 x7 ^! J. I* {8 u0 ^( S& p( t/ S2 S
Machinability 50 % 50 %  annealed and cold drawn. Based on 100% machinability for AISI 1212 steel. % c) m- V- S0 e* c2 k3 ?. M
Shear Modulus 80 GPa 11600 ksi  Typical for steel
