- 积分
- 8
UID345409
主题
在线时间 小时
注册时间2007-7-13
大家帮忙看看代码:- Z( j# P4 H/ @
得到了矩形的各个边的tag 也得到了边的条数,为什么得不到坐标啊,都是0,0,0???
' J6 y, m0 v# |0 a. s% B8 \" A double p1[3]={0,0,0},p2[3]={0,0,0};% `' T+ X& c8 c9 Z. H. g I
int vertex,type,count=0;1 O U3 [* z' d. d0 j2 D" s
tag_t obj_id,part_tag,edges_id;; t2 @# a+ z- s, P0 S: B
obj_id=0;
+ x8 n( u0 a+ h m" A' [" J0 O uf_list_p_t loop_list;3 _/ X- I& e- K9 ]5 W2 t
type=UF_line_type; _2 V& `$ X, C; K
part_tag=UF_PART_ask_display_part();7 p; s' I; k) Y; o6 l s0 G7 E
UF_OBJ_cycle_objs_in_part(part_tag,type,&obj_id);
; V% @5 o+ ]0 v& f4 O4 k5 { CString str1,str2; `# F' o- D- B9 _2 K8 g
' Y# q6 X, c; j' R* x; T8 P- y
while(obj_id!=NULL_TAG)
- g& a) ]9 u' M! T; i5 b {
3 _- |$ T! C5 C5 U
8 }1 F; e* i) {" a1 P1 L* F) Z# G count++;7 Q: h4 ~3 Y9 F
UF_OBJ_cycle_objs_in_part(part_tag,type,&obj_id);0 q- n t" N; i$ G! e
UF_MODL_create_list(&loop_list); ` x5 U* [7 y+ T
UF_MODL_put_list_item(loop_list,obj_id);' j) M) l( c: |) s$ [0 O) f! `0 F
# L$ }4 G( v4 h/ S9 e! P" p//edges_id得到了啊
0 W* e8 o- O# L: g! [" ?. ^
5 b( o7 A! k- P9 q for(int k=0;k<count;k++)
+ w0 U$ U% k: x, ~ s& i2 ^ {& V" y9 {9 S* q1 e" v% M
UF_MODL_ask_list_item(loop_list,k,&edges_id);! ^8 q4 ~+ g6 s
UF_MODL_ask_edge_verts(edges_id,p1,p2,&vertex);
7 Q& ?) b+ x2 R; y+ C+ n( f- K' l9 }. J str1.Format("\n第%d条边信息:\n",k);
+ q* \$ c$ u3 r( m( s d1 G UF_UI_write_listing_window(str1);
8 h- `3 u5 ?( v! E8 s, t/ E str2.Format("strpoint:X=%f,Y=%f,Z=%f,endpoint: X=%f,Y=%f,Z=%f\n",p1[0],p1[1],p1[2],p2[0],p2[1],p2[2]);
: B" g( V6 D+ E/ A" q! S UF_UI_write_listing_window(str2);7 V: B# ]! Y6 _# s; L- q4 i! n* H) r
