查看: 2369|回复: 3
[已解决] 怎样写关于读取硬盘号的LISP函数
发表于 2007-7-22 15:13:52 | 显示全部楼层 |阅读模式 来自: 中国湖南株洲
发表于 2007-7-23 14:37:07 | 显示全部楼层 来自: 中国浙江宁波
(Defun C:phyhar (/ code code Drives lstSer StrDrive SerialNumber)& a" ^4 C5 r8 y
(vl-load-com)
6 O; j; a2 X( F(setq code "C"& F$ E0 {* I! N: {  H# [
(setq FSO (vlax-create-object "Scripting.FileSystemObject")* ?) }4 ~9 B% p0 b1 O
Drives (vlax-get-property FSO "Drives")
: U: J) I; h/ @8 V)/ \- o; Y: c3 f
(setq lstSer '())- A$ x4 n- q3 Y. F8 n2 F* U0 c6 z8 A
;; iterator the HardDisk for the SerialNumber .5 }+ R& S" G% Q: |' `; K
;;;(repeat (vlax-get-property Drives "Count") 注释掉此行
2 K" f: i8 C! @4 c! {  {3 j(setq StrDrive (strcat code ":"))
- |% W. J/ A4 x" G( b(if (and (setq Drive (vl-catch-all-apply 'vlax-get-property (list Drives "Item" StrDrive)))
) {* T& g2 L& i* H( H4 Q(not (vl-catch-all-error-p Drive))4 y: @6 e+ k% i
(vlax-property-available-p Drive "DriveType")
9 g) w! ^  [" x* ~(equal (vlax-get-property Drive "DriveType") 2)
; _/ y2 S. E& j2 h; k2 b" d(vlax-property-available-p Drive "SerialNumber"), Z7 }# N" ^0 J, d( R
(setq SerialNumber (vlax-get-property Drive "SerialNumber"))
' R9 S6 r1 h3 l! n4 F& t)+ X# P% Z" Q5 z) ^
(setq SerialNumber (rtos SerialNumber 2 0)' P  `' m: t0 i% z( V
lstSer (cons (list StrDrive SerialNumber) lstSer)
! G9 t( w9 z$ e( \; H7 g)
7 o# q! C8 E  N0 a): g+ c6 c, ]9 W! i( V* \) `' x+ P+ q  |
;;;(setq code (chr (1+ (ascii code))))  注释掉此行7 |8 [  Y7 c" |9 ^
;;;) 注释掉此行9 E5 _1 S' W9 f9 j
;; relese object .( i+ z4 t) ?* _9 Y+ C# O
(vl-catch-all-apply 'vlax-release-object (list FSO))" s! T9 n- m8 ?
(vl-catch-all-apply 'vlax-release-object (list Drives))
  g0 @, G, j* c9 W;; return the value .
4 B' M9 u% f) |* W(princ(reverse lstSer))5 V! ^! Y4 u9 Q6 R& j+ G
), a' ?  _. p) ?' T+ x4 K# N- @" G7 r
- }3 \9 O$ M! d0 {4 g
& l4 T  h0 d* t2 M6 f" _6 F. b
你把循环部分注释掉,不就只得到C盘的SN了吗?- K5 m+ V  o) e* C
) p/ i% ~/ q' y  [( S3 ]- c
[ 本帖最后由 sealive_leafage 于 2007-7-23 14:39 编辑 ]
 楼主| 发表于 2007-7-23 20:13:07 | 显示全部楼层 来自: 中国湖南株洲
发表于 2007-7-23 20:58:15 | 显示全部楼层 来自: 中国浙江宁波
(Defun C:phyhar (/ code Drives Drive StrDrive)
' U" o9 r( Z; p- R* Z# ~  (vl-load-com)
- v/ ~% `' o8 D0 f0 o  (setq code "C")
% I; I1 A% h7 O. ?; v! B  (setq FSO    (vlax-create-object "Scripting.FileSystemObject")
( G) ]/ _7 @1 M1 V8 K' z: VDrives (vlax-get-property FSO "Drives")0 L( m& d) A6 r' A* z3 H+ J
  ). }% f4 `3 z' p, t
  ;; iterator the HardDisk for the SerialNumber .( S9 I8 p3 g+ R3 ^3 {
  (setq StrDrive (strcat code ":"))8 p% u7 P0 n/ l& \- H- M
  (if (and (setq Drive (vl-catch-all-apply. L+ a% l8 j  ]3 `4 D
    'vlax-get-property  o: r( z+ ~9 ^- z; q
    (list Drives "Item" StrDrive)- d, v5 V! F$ i
; I  V8 i2 k3 y- }; b    )* V3 o) `* G* g2 S, a9 _
    (not (vl-catch-all-error-p Drive)): b) c8 K1 _$ P
    (vlax-property-available-p Drive "DriveType")* }5 T: h4 b/ s: _! n/ I. z
    (equal (vlax-get-property Drive "DriveType") 2)/ l# p$ t' Q; y2 W& ^
4 F* N4 P5 {+ K/ z! J; j    (setq SerialNumber (vlax-get-property Drive "SerialNumber"))
5 B$ H' z# v$ f7 A      )+ i8 {1 a; |' @
    (princ (rtos SerialNumber 2 0))  Q. F4 S) `1 j6 |; l
6 ~: Y7 s# u/ V! h  ;; relese object .
8 h* G, a+ O5 m2 |  (vl-catch-all-apply 'vlax-release-object (list FSO))
# i5 b5 y# j/ b) C% ~9 [  (vl-catch-all-apply 'vlax-release-object (list Drives))
! v5 ]: p- S8 `/ V). d, N; n0 s/ T( H7 Q
6 p2 ^) e- J6 ~' h建议你多看看LISP语法!/ ]8 c/ v) ]" ~
$ N% V8 N7 M$ G% b4 {
[ 本帖最后由 sealive_leafage 于 2007-7-23 20:59 编辑 ]
