发表于 2007-8-10 00:29:56
来自: 中国山东烟台
SA-240Type310S 相当于310S 查资料就行了. w% W& W/ r4 U$ u7 U3 [+ W- |
CortenA %:0.10C, 0.40Si, 0.48Mn, 0.094P, 0.019S, 0.52Cr, 0.34Ni, ...
% Z( G% H o& _: b+ k1 W8 e4 |9 Z4 {( D7 l( u
Weathering steel, best-known under the trademark Cor-Ten steel, is a group of steel alloys which were developed to obviate the need for painting, and form a stable rust-like appearance if exposed to the weather for several years.% `! P' K4 c: z) R# P0 _2 C. V
- E/ v2 }. F# L3 s: G! r1 jUnited States Steel (USS) held the original registered trademark on the name COR-TEN, which passed to International Steel Group (now Arcelor-Mittal) with the purchase of USS's heavy steel plate business.[1]' M5 u- ]+ ~1 f% k
/ U# C: ?0 g- ~/ e# e( x* UIn some areas it may be known without the hyphen as "Corten steel".
- I j. [5 X! k1 m# K1 \2 w# I0 q- v
) t+ I* D8 V: V" I" R$ TThe original Cor-Ten received the standard designation A 242 ("Cor-Ten A" from the ASTM International standards group. Newer ASTM grades are A 588 ("Cor-Ten B") and A 606 for thin sheet. All alloys are in common production and use. |
