查看: 1158|回复: 1
[分享] Surlyn 8920 thermoplastic resin
发表于 2007-8-6 13:41:31 | 显示全部楼层 |阅读模式 来自: 中国四川成都
Surlyn® 8920 thermoplastic resin
+ B  m7 \/ r& {  A1 C8 P9 T4 ?General Description
$ `5 j5 g& g0 J3 ]8 KSurlyn® 8920 thermoplastic resin is an advanced ethylene/methacrylic acid (E/MAA) copolymer, in which5 S  i: s% U) f( B9 G1 O, @
the MAA acid groups have been partially neutralized with sodium ions. The amount of MAA and5 l/ N* P* H+ d4 W. W/ F* ?
neutralization levels for this grade result in excellent abrasion resistance, clarity, and stiffness. The resin$ Y* K1 H2 \4 f2 J" b. M
can be injection or blow molded, and is processable by extrusion into sheets or shapes. It also can be used  y* I) H5 M) E# y/ e8 S, t6 B
as a nucleating agent for PET molding applications. The resin complies with the provisions of U.S. Food/ K, @, Z3 `' x
and Drug Administration (FDA) Title 21 Code of Regulations 177:1330. Typical performance properties are8 o# C) F' [3 j8 i" h9 y
shown below:
Surlyn8920.pdf
36.62 KB, 下载次数: 2
 楼主| 发表于 2007-8-6 14:04:56 | 显示全部楼层 来自: 中国四川成都
Surlyn树脂的简要说明
DuPont™ Surlyn® 8920 Data Sheet$ V0 J" G1 B3 {) X7 W' W9 G9 d* u1 P8 v
杜邦公司的   沙林TM(SURLYN&reg  离子键聚合物树脂  技术资料。
