查看: 1473|回复: 0
[转帖] 阀门技术英语(1)
发表于 2007-9-12 14:08:29 | 显示全部楼层 |阅读模式 来自: 中国广西桂林
1. 阀门种类术语
! I7 J, u. l8 B( `  M2 ~6 F5 _Angle Stop Valves     角式截止阀
2 K  p" i* I  D5 m) \Angle Throttle Valves     角式节流阀
3 e! [# o+ v- G- u$ pAngle Type Globe Valves     角式截止阀   / u' f* Z) k9 W) D6 \5 p
Butterfly Type Non-slam Check     蝶式缓冲止回阀   * t, {7 O( e8 Q1 y! b- w) \
Butterfly Valves with Gear Actuator     蜗轮传动蝶阀
# R# G) i6 R5 y: eCock     二通
. E; j6 D: g2 i5 J$ ?/ E# s2 y+ X$ `CQ Thread Ball Valves     CQ 螺纹球阀   3 q! T; J9 h$ U& v
Diaphragm Valves     隔膜阀
/ R) V+ W) e% ^Double Disc Flat Gate Valves     双闸板平板闸阀
: r: r0 w; v8 o+ d* X# k, qDouble Disk Parallel Gate Valves     明杆平行式双闸板闸板   ( S! i) |" i: H6 @6 B7 e
Double Opening Exhaust Valves     双口排气球     p% U% l7 D8 G- M; I
Electric Actuated Stop Valves     电动截止阀   & v' N9 r5 B2 l' k; k: m
Electric Actuated Wedge Gate Valves     电动楔式闸阀
, q  J8 ~+ ?; r! e  [1 `Electric Double Disk Parallel Gate Valves     电动平行式双闸板闸板
2 t* C9 w; T2 DEmergeny Cut-off Valves     紧急切断阀
( a5 v2 \5 [9 H8 S+ N$ x" EFree Float Type Steam Trap     浮球式疏水阀
9 i! D5 K/ a( nFlange Ball Valves     法兰球阀
  {0 C9 ~+ ^3 Y9 _& @6 T% m# UFlange Gate Valves     法兰闸阀   ; U) ]; \2 O: A1 ]8 o* {' Q
Flange Globe Valves     法兰截止阀
; G: Q9 E. g, H6 n, v. e& N5 R, AGauge Valves     仪表阀
" }: p0 _7 k, F- zHard Seal Butterfly Valves     金属密封碟阀
, T; C$ o# o  s' C* C* iHigh Temperature Pressure Power Station Gate Valves     高温高压电站闸阀
, e+ F; B" V) x$ l7 {: MHigh Temperature Pressure Power Station Globe Valves     高温高压电站截止阀   # u: F- }4 j' S$ O& M; h% s/ e' F
Lift Check Valves     升降式止回阀
) u; a8 N  {* I" v7 L& RLift Check Valves     升降式止回阀   6 F0 E' t1 ]. y, q
Lining Ball Valves     衬里球阀
, N- h; [3 r  I5 i. a1 A5 DLining Butterfly Valves     衬里碟阀
, _6 a& ?3 q# U. }9 h0 l/ CLining Check Valves     衬里止回阀
8 F; O0 j+ s9 Q. K. zLining Cock     衬里二通
7 o( w+ h8 I$ QLining Globe Valves     衬里截止阀
& c& B! {; C  |, ~/ |Lining T-Cock Valves     衬里三通旋塞阀
0 E% V/ x% g. d  T$ yLiquid Indicator     液位计
; H$ r' o7 x# \& F; D# k% F) J3 D* CLPG Pipe Fitting     液化气管件   ) s; O1 p1 O; s, c; p# i6 A
Magnetic Co-operate Globe Valves     磁耦合截止阀   ; d" w+ S* @; m
Magnetism Forle Pumps     磁力泵   : N) U/ h3 a# N! I: o; ]
Manual Oil Pumps Valves     手摇油泵 ( 阀 )
0 l: P( _4 q" t8 T$ qMeter Needle Type Globe Valves     仪表针形截止阀
$ r, S8 w+ m+ Z* aOblique Stop Valves     直流式截止阀
# t1 v* O6 S( j5 jParallesl Slide Valves     浆液阀   1 e1 `( h' u* t+ \/ b7 b
Piping Centrifugal Pumps     管道离心泵
8 {( ], u: ^3 w+ ~, e6 RPiping Pumps     管道泵   " j" o- a* j: y
Piping Safety Valves     管道安全阀   / w5 Q# \& p, T; H  q: c
Plunger Globe Valves     柱塞截止阀   " F) D% }3 ~- W1 m
Quick Draining Valves     快速排污阀
$ Z1 U1 \6 g' wRestrictor Valves     过流阀 ( 或节流阀 )
