我们公司在代理一种美国的酸液再生添加剂, 通过在金属酸洗液内添加少量该添加剂, 结合在线过滤可以去处酸液内的金属离子和有机杂质,使酸液重复使用,勿须排放. 下面是该产品在其它论坛的贴. 那你能把盐酸也重新利用了??对于多少量的废水用你的方法合适?? 该药剂是专门对金属处理废酸开发的,可在原液pH的条件下处理。结合在线过滤器,废酸可循环使用。至于处理量,没有要求,因为新增设备只有储罐和在线过滤器。当然,成本还是一个关键的因素。有需要,我可以向我朋友要一些样品做一下。
3 `- Y4 \& G1 R4 O* L& I0 x你酸洗浓度有多高?我觉得回收难度比较大,不好弄! 放不上,等明天吧。至于酸液浓度,硫酸,硝酸等都可。案例中的浓度可以到30 wt.%
- H7 }3 Y3 I9 w4 A5 l一次投入要多少钱啊? 我上面提到了,只需要储液罐,在线过滤器和泵.主要的消耗是添加剂.一次性投入是不大的. * M/ a, L( Q& s& s( A4 m
没有具体一点的吗??如果真的可以回收,有很多厂家多是想要弄的!让我帮忙处理的就有两家. 楼上的,我不知你有什么具体要求.方便的话,留一个email(我的是neterli@hotmail.com)继续交流.另外,既然你手头有废酸,我建议做一下小试,药品我来联系.小试的程序大概如下:' f' B2 t8 Y U& O
/ t5 l: \5 t( D 1,按1:100的体积比,加药品到废酸中.$ e; P+ g9 x1 C. m7 E/ l
2,缓满搅拌2-3天.
1 j$ e) _" N5 g2 m 3,用5-25um的滤材过滤废酸,滤过液就可重复使用. - p% R: s9 X0 E" k2 D
结晶析出 ? 机理不是结晶析出.结晶析出需要在低温和高盐浓度下进行.而该添加剂可在常温,低盐条件下发挥作用.此外,该添加剂除了去除盐,还可去除其它污染物,如部分有机物,油份.到目前为止,我还没有看到国内有同类产品的报道.
: q, K8 F! L9 E: p
$ u+ ~- H$ h- q0 I" [1 p 下面的照片是循环处理多次的废酸液图片.
" }7 [ J0 G$ n& N& Y+ n4 u[url=http://www.h2o-china.com/center/readpic.asp?id=206107][/url] 这是图片的详细说明.不好意思,是英文的.
) @# l& O% ]/ ]
. p9 c4 L' v+ G6 z( I, _3 i Left Beaker: Nitric Acid (previously disposed of approximately every 1 months) ! X7 E" N) Z @- G
was first treated with the additive, 3/28/01, and used continuously since that date. 7 B8 J2 h% R: v1 {2 I* O; x
?" R; O/ E& N2 y" F4 o3 g
Right Beaker: Hydrochloric Acid (previously disposed of each 7 to 10 days) was * O6 R5 w( V2 G! r4 r
first treated with the additive, November 21, 2000, and used continuously since that date.0 s, o7 ^7 d9 |4 K% L) _0 {
(This acid is 2 years old as of November, 2002.)8 S8 F. z! N2 t! P9 I q
& P W, d0 k; ^" P The Nitric Acid is approximately 2 & 1/2 years old. The HCL will be 2 years old on November 21, 2002, and it has been used approximately 16 hours a day, five days a week since treating with the additive in November, 2000. The HCL acid bath perviously lasted 7 to 10 days before disposal was required and this acid was completely spent and ready for disposal before it was treated, restored and has been in continuos use since. |
