查看: 1623|回复: 0
[分享] CosmosWorks算法验证文件 6 (Thermal Stress Analysis)
发表于 2007-11-6 15:12:01 | 显示全部楼层 |阅读模式 来自: 中国上海
.. E' @9 _& l! h1 z
提示:带温度载荷的静态结构分析。2 n7 y2 }: m0 j' H0 d! t
# I) T: Q) y! g7 }2 o  rTitle      Thermally Loaded Support Structure( k/ T$ K8 g! E
1 K, l: E3 q0 I6 n9 }
Overview
8 c  r, t% i# ~- p* H
% n8 r5 t% ?9 }# s$ m4 o5 g
Reference:S. Timoshenko, Strength of Material, Part I, Elementary Theory and Problems, 3rd Edition, D. Van Nostrand Co., Inc., New York, NY, 1955, pg. 30, problem 9.
Analysis Type(s):Static, Thermal Stress Analysis
" H3 R! W/ y! w7 b7 }5 f; [& {* OTest Case
4 z6 @4 H9 d, l4 z! ]( U8 ~% {
: S7 R8 z  j0 F  M5 Q
Find the stresses in the copper and steel wire structure shown below. The wires have a cross-sectional area of A. The structure is subjected to a load Q and a temperature rise of ΔT after assembly. / y  X# t# i9 _" V, d
$ i1 o/ l! }! r6 h3 D2 |0 `Figure 3.1  Support Structure Problem Sketch
% z  _3 d" u: K9 g# ^) U. v) j3 h: C' Y5 O9 b- [, _+ f  I- T
VM3.jpg 5 _  ]1 ^6 d6 X3 @. F& J
7 f( U' K' Z* A
Material Properties
Ec = 16 E6 psi
αc = 92 E-7 in/in-°F
Es = 30 E6 psi
αs = 70 E-7 in/in-°F
Geometric Properties
A = 0.1 in2
Loading
Q = 4000 lb
ΔT = 10°F
! W/ F+ v9 V/ F6 A6 J
3 p7 o/ g3 E$ OAnalysis Assumptions and Modeling NotesLength of wires (20 in.), spacing between wires (10 in.), and the reference temperature (70°F) are arbitrarily selected. The rigid lower beam is modeled by nodal coupling. ( {6 ]$ [/ n3 f- Z' @5 D( A" D6 R
- T; U* H1 S8 W; R- F$ z
Results Comparison
TargetANSYSRatio
Stress in steel, psi19,695.19,695.1.000
Stress in copper, psi10,152.10,152.1.000
0 a' f3 ^3 P2 z; B# K! i$ u
0 p: {6 a. G1 G* `) {$ k$ \[ 本帖最后由 tigerdak 于 2007-11-9 15:28 编辑 ]
