.. `4 _, P, q/ a: a7 c
提示:如果分析得出第一阶频率接近72.059就可以了,因为CosmosWorks(2006)在频率分析时没有办法设置旋转刚度软化的影响,所以不会得到后面那个target值。9 _6 q D% ]- m* }& K+ s1 q# F
6 M9 \/ E5 i8 w3 O$ a. F
Title Vibration of a Rotating Cantilever Blade! q' ^% L8 [% [6 U: h* b# E
4 a' R' a% Z1 n8 v/ N3 R) z
Overview
% G, g5 ~+ ~1 k# Y" q+ {/ s
6 `2 A2 b. q+ \4 R) B| Reference: | W. Carnegie, “Vibrations of Rotating Cantilever Blading”, Journal Mechanical Engineering Science, Vol. 1 No. 3, 1959, pg. 239 | | Analysis Type(s): | Static Analysis
1 J6 N+ H% \" q: S: o3 kMode-frequency Analysis% J; X; T2 S2 G4 O6 B8 |; X
' x0 \4 H+ q: rTest Case4 u N" s! C) x6 ^( c
* N: E3 M4 h7 _& L( g8 {A blade is cantilevered from a rigid rotating cylinder. Determine the fundamental frequency of vibration of the blade, f, when the cylinder is spinning at a rate of Ω .
( f5 h0 b1 i0 ~6 f6 n
; l) _7 O6 T' ?7 r( O- ]2 rFigure 54.1 Rotating Cantilever Blade
. C1 }7 r- f# [+ T$ c0 _& g: G( p" H
0 b% w/ W' i5 h3 `
6 P; J' A4 q) X7 b+ k2 e/ q
7 f+ L# f& ^% }" y( e3 a, J; J| Material Properties | | E = 217 E9 Pa | | ρ = 7850 kg/m3 | | υ = 0.3 |
| | Geometric Properties | | r = 150 mm | | l= 328 mm | | b = 28 mm | | t = 3mm |
| | 8 _2 u: |9 b: F
Analysis Assumptions and Modeling NotesThe problem is solved in two different ways:
1 q, m: p+ X1 j' i: |1 d* U& a1 ~- Using Elastic Shell Elements (SHELL63)
- Using 3-D Solid Shell Elements (SOLSH190)
# N) O% d5 V* y4 }$ r& S/ ?5 {! x: e
Spin (centrifugal) softening is used. Since the cylinder is rigid, the base of the blade has its displacements constrained. A static prestress analysis is performed to include the inertial effects resulting from the rotation of the cylinder.
% Y, X" H; V, z: R* i# X ~3 _3 v' u( c
Results Comparison* ^$ Q4 h5 J, e6 h* C
! g2 J, @" {( P# [
| Target | ANSYS | Ratio | | SHELL63 | | f, Hz | 52.75 | 52.01 | 0.986 | | SOLSH190 | | f, Hz | 52.75 | 51.80 | 0.982 |
! \1 b4 K; K' ~( i. ~" d o/ \: e! P+ j9 j6 X3 {
[ 本帖最后由 tigerdak 于 2007-11-9 15:25 编辑 ] |
