发表于 2012-5-22 08:45:17
来自: 中国山东烟台
0 BEGIN PGM 1 MM `6 {! Y( e6 p/ L. F
1 ;Program Name: 1 MM
* ?; y2 K( k, P3 d2 ;Create Time: Thu May 10 01:39:25 2012
7 z. a/ M% U' K" j, \% Z3 ;(Tool Name=D8)
" l) p/ y9 h R% ~4 n0 K) f% @4 ;(TD=8.00, TR=0.00)
0 `, ?+ t8 L4 O- O' u2 ?( d$ N) x/ `3 |5 TOOL CALL 0 Z S8500# u T8 F" |+ j. R; M0 B
6 TCH PROBE 584 TOOL SETTING L,R ~% Q$ b0 e, Y4 W1 l# h. P% Z3 H
Q350=+0 ;MEASURING TYPE ~
' @$ [9 }* E. W; z6 G7 b Q351=+0 ;APPLICATION ~& }+ ?" S( j. T5 z f9 |4 @& N' s1 v3 L& O
Q352=+0 ;CUTTING EDGE CONTROL ~
' v* ?: e/ p0 z r4 j' c3 C Q355=-1 ;MEASURING POSITION ~; ~% }; w* [ P6 N
Q361=+3 ;NUMBER OF MEASURINGS ~0 S- }) R0 P3 V1 a, Q/ q: M( ^
Q362=+0.01 ;SCATTER TOLERANCE ~
# o2 u$ G- M! E9 A1 N Q359=+0 ;ADD. LENGTH CORRECT. ~7 b0 S# c3 Q4 Q
Q360=+0 ;ADD. RADIUS CORRECT.
3 w7 u4 w! N/ x1 j* |6 j. C7 M140 MB MAX6 U' w1 c1 ?( Q ~7 A4 s
8 CYCL DEF 32.0 TOLERANCE# q0 y g& ^7 b* ?
9 CYCL DEF 32.1 T0.005+ O" H" ?6 z; B* s" T
10 CYCL DEF 32.2 HSC-MODE:02 ]2 r! ~2 e9 u: H
11 L X2.467 Y-16.5 Z9.94 F6000. M3 M8' ~; `1 Q5 s2 H+ R
12 L Z-.01$ Z! x* W. T: n( S" {
13 L Z-.31 F2000.
' Z I7 l+ o) N( Y% ^14 L Y-12.9! }; ~- Q6 g) [6 G
15 CC X-.533 Y-12.9+ h* d3 b3 t: {, v t5 u; X; o
16 C X-.533 Y-9.9 DR+
8 j% i6 R' D# P0 O( R$ K2 G17 L X-26.901 F4500.
! W' M" F) A! A( s18 CC X-26.899 Y-7.9& H, w7 r6 L w f: e' K
19 C X-28.899 Y-7.902 DR-$ T/ I6 s# v. t \! N7 f
20 L Y7.902, d; ?& r6 q6 a6 o' W9 P
21 CC X-26.899 Y7.9- [; u3 G' @0 c* h# j) R
22 C X-26.901 Y9.9 DR-
4 J6 Z$ P+ s$ R2 t1 ]( K23 L X-26.061
9 A, X! S: R, r8 I# `9 M24 CC X-26.061 Y7.9
/ `2 @1 b2 W! T8 V! M8 n0 Z. h25 C X-24.272 Y8.794 DR-
1 P1 J1 T! x' {& f* F* q7 z& P, K26 L X-23. Y6.25
5 {" V9 `" y; ? r" ]' D9 r2 O27 CC X-21.211 Y7.145
. X. C# }; m- o2 V2 d! v$ n9 F# D28 C X-22.155 Y5.382 DR+
. U k. j5 g. Q29 CC X-22.627 Y4.5
! s) u2 I, D7 @" D* U* m6 s, X30 C X-21.926 Y3.786 DR-4 m4 S5 g- O$ L H
: x0 j- i" k1 w% ~/ Z^^^1 A! g$ N$ J3 m" f
3 S) o4 R$ Z& }) f* _$ c8 r
& @" Z/ M: H5 d: J1 t1343 L X-1.
1 {9 e0 A( Q5 G3 W1344 L X-1.1
2 S# H: e( T2 d+ P( K) A8 E1345 CC X-1.1 Y-11.5
% {% e5 z6 Q* [: I3 Q+ ]1 P. C1346 C X-4.1 Y-11.5 DR+
# q% C% P Y; Z* H% @! h( [# J: b1347 L Z-5.61
; j( b# C. x; k5 ]) Q) J' r1348 L Z9.94 F6000.9 z9 G( E& e6 g, G& i
1349 M5" U4 x; N6 e/ u' ^- ]$ ?
1350 M92 h! @) v" G) V
1351 M140 MB MAX
1 q" G. t& h( ?) v; f1352 STOP M30* C/ V- q7 s' r4 G/ q
1353 ;MAXZ: -5.910 MM, L+ R7 d: W2 V( c$ _! h
1354 END PGM 1 MM
& Z7 g% e5 w1 p7 V9 t;Machine Time: 1.78 min" p: u: `" @# O
;MAXZ: -5.910 MM/ ^. a' u1 i4 R2 D
;Part Name: Administrator\F:\2011cnc\2yue\0219\A022_12205_1_E2_stp.prt
/ F+ w; x! Q$ b1 y" K0 z;Date: Thu May 10 01:39:25 2012, g% B- }, [3 E" G
;MCS error 请确认!!! !!! |
