查看: 4711|回复: 3
[求助] H62的机械性能在哪个标准里能查到?
发表于 2007-12-6 11:35:25 | 显示全部楼层 |阅读模式 来自: 中国江苏南京
请各位老大帮忙!
发表于 2007-12-6 13:22:31 | 显示全部楼层 来自: 中国安徽芜湖
材料: H62
9 ?: ?& I% c( R8 |4 D标准: GB
! u+ N) M: \3 [! z! M% Y! {国家与地区: China
. R- ?  g; l& N7 K4 I金属类别: Copper Alloy
# n; B; x7 ~. V次级类别: GB 13808 Wrought copper and copper alloys
# x9 u% b( h1 o2 @0 b+ Jhttp://www.3dportal.cn/discuz/viewthread.php?tid=186593&highlight=GB%2B13808
! F( O2 F( |% R# N& Q* C. I4 O(此标准已作废)见http://www.3dportal.cn/discuz/viewthread.php?tid=191164&highlight=GB%2B13808
$ @  W! p3 F1 a! n9 q2 k: W4 W0 x" ^
材料属性
* j4 r- r4 ?4 T! n2 ~# M5 u( E- x1 u1 [' j' i
5 z8 M% {% Z! ]4 T- G' E  f
        Min.      Max.    Approx.
8 |- y) d% h! H( nHeat treated ; Bars, rods; > 10 <= 160 mm
; X0 ]; t( h& ?% zTensile Stress, Rm (MPa):                                      295
: t! e# D* w3 DElongation, A (%):                                                     307 t# ^) w+ \/ a+ M" [8 u
/ y. q7 t5 U6 ]$ D; a1 @4 Q* f1 B
8 A; u  T% u0 P# a4 s7 {5 Z, ]# X. V% E( l$ F8 }
机械性能
http://www.key-to-nonferrous.com/cn/img/nav/content-bgh.gif
材料:H62
标准:GB
国家与地区:China
金属类别:Copper Alloy
次级类别:GB/T 2059 Strips of copper and copper alloys
5 J# f+ _& J. _/ J( ~1 F5 n
http://www.3dportal.cn/discuz/viewthread.php?tid=186850&highlight=GB%2FT%2B2059$ F( o0 t# v/ x: V" R, t
6 r) h. s7 ]" D
材料属性 7 Q- h0 f- L# C5 L& w
, q. h$ U) p2 ~  |
http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif
4 n, a( _" x1 A% E9 n: V( G6 Z+ o
  Min.Max.Approx.
Soft ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  290
Elongation, A (%):  35
Half hard (1/2H) ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  350470
Elongation, A (%):  20
Hardness:  > 85 <= 145 HB
Hard ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  410630
Elongation, A (%):  10
Hardness:  > 105 <= 175 HV
Heat treated ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  585
Elongation, A (%):  2.5
Hardness:  145 HV
8 ~! p5 q/ Y* ]0 X7 s3 V
8 n, g- B5 o4 P2 e+ O
, Q+ U2 l" ?2 i$ P7 T; I7 @, m& G
4 s# s4 G) a% O- v. c[ 本帖最后由 hourpp 于 2007-12-6 13:36 编辑 ]
tdragonfu + 2 应助
发表于 2007-12-6 13:30:19 | 显示全部楼层 来自: 中国陕西西安
Cu——60.5~63.5%
% `6 k" H7 ?6 K, T! p# j# q4 BFe——≤0.15%
6 b9 N$ e' \* u, l- v3 w/ UPb——≤0.08% 4 F3 k+ c& u- F7 X1 h* e0 d
Sb——≤0.005% 0 U+ F$ z+ v0 W
Bi——≤0.002%
# M& z/ k7 K: }6 _5 I, ]P——≤0.01% 8 e$ h; u8 B" a& {1 t; D
Zn——余量 . f6 i9 x6 W* W! q
杂质总和:≤0.5%
0 y' L: e0 y. {- V( b! v参考资料:GB/T5232-85
tdragonfu + 2 应助
发表于 2007-12-6 13:54:57 | 显示全部楼层 来自: 中国上海
看你的H62是什么形状的了,这些标准里都有H62,拉制棒<φ40时是370MPa,≥φ40是335MPa,板材软硬程度不一样相差蛮大的。
( E( Y- `0 i; D0 Y  x$ RGB-T1527-2006铜及铜合金拉制管' [. J- x' O$ H4 o. K* j
GB-T1528-1997铜及铜合金挤制管
. @& I5 O7 ?# QGB-T2040-2002铜及铜合金板材
* s) L2 S8 r' C  ~  i1 hGB-T2059-2000铜及铜合金带材$ T* E+ S' B) I; ~" z& }
GB-T4423-2007铜及铜合金拉制棒
, }- c- g( Y6 m! U# ]: s& ^* Q! }5 fGB-T13808-1992 铜及铜合金挤制棒
& _9 d- v7 F  w1 _GB-T13812-1992黄铜磨光棒
# U& S4 V! j. C% o" A1 \GB-T14954-1994黄铜线
tdragonfu + 3 应助
