查看: 1359|回复: 0
[环境科学] 在用柴油机颗粒物和元素碳、有机碳排放因子研究[英]
发表于 2007-12-16 20:30:46 | 显示全部楼层 |阅读模式 来自: 中国天津
Title:Emission Rates of Particulate Matter and Elemental and Organic Carbon from In-Use Diesel Engines
( c! s1 |" W' V0 J5 [0 h5 v& w- ?Author:SANDIP D. SHAH等
% Y" D, b) r1 \7 g8 ~8 @Abstract:Elemental carbon (EC), organic carbon (OC), and particulate matter (PM) emission rates are reported for a number of heavy heavy-duty diesel trucks (HHDDTs) and back-up generators (BUGs) operating under real-world conditions. Emission rates were determined using a unique mobile! x2 w& s$ W* T+ U" d
emissions laboratory (MEL) equipped with a total capture fullscale dilution tunnel connected directly to the diesel engine via a snorkel. This paper shows that PM, EC, and OC emission rates are strongly dependent on the mode of vehicle operation; highway, arterial, congested, and idling conditions were simulated by following the speed trace from the California Air Resources Board HHDDT cycle. Emission rates for BUGs are reported as a function of. {6 V. P# G; M! `! g) L3 @
engine load at constant speed using the ISO 8178B Cycle D2. The EC, OC, and PM emission rates were determined to be highly variable for the HHDDTs. It was determined that the per mile emission rate of OC from a HHDDT in congested traffic is 8.1 times higher than that of an HHDDT in cruise or highway speed conditions and 1.9 times higher for EC. EC/OC ratios for BUGs (which generally operate at steady states) and HHDDTs show marked differences, indicating that the transient nature of engine operation dictates the EC/OC ratio. Overall, this research shows that the EC/OC ratio varies widely for diesel engines in trucks and BUGs and depends strongly on the operating cycle. The findings reported here have significant implications in the application of chemical mass balance modeling, diesel risk assessment, and control strategies such as the Diesel Risk Reduction Program.
Emission Rates of PM and Elemental and Organic Carbon from In-Use Diesel Engines.pdf
140.19 KB, 下载次数: 4
