发表于 2007-12-20 09:22:13
来自: 中国安徽芜湖
http://www.key-to-steel.com/cn/img/nav/spacer.gif
' _4 Y, d/ l; ]化学成分 (%)
8 a2 h ?8 Z" c | http://www.key-to-steel.com/cn/img/nav/spacer.gif7 t1 u7 l2 D" |: R9 _
| 元素 | 最小 | 最大 | 近似的 | | C | 0.1800 | 0.2300 | ' d2 c& d, j0 f0 U0 \( _2 z1 ^( l! O
| | Si | / r% y8 V. H! g
| 0.3000 |
) y) a1 y- O7 h; I1 i2 O- | | | Mn | 0.9000 | 1.2000 | ' H# i% m- {; u8 P6 c
| | P |
$ k9 O& M3 Y& ?8 Q | 0.0250 | $ Q1 J) a3 A H4 o
| | S |
, D9 m i7 u5 J8 ]: M: z/ ` | 0.0250 | . w4 e5 m; ~% N, F1 F
| | Cr |
& `( T. a/ `) f# x0 S' {2 Y | 0.3000 | : d1 J& z. ?+ F: h& E4 M! m/ S
| | B | 0.0008 | 0.0050 | 8 Q: X- O+ Z& F; R# K1 G& G* s4 O
| | Cu | ) X: E: `& Z9 D/ r
| 0.2500 |
" } _: [+ _* R! Q9 }3 Z |
| 标准号: | DIN EN 10263-4-2002 | | 中文标题: | 冷镦和冷挤压的钢杆材、棒材和线材.第4部分:淬火和回火钢的交货技术条件 | | 英文标题: | (Steel rod, bars and wire for cold heading and cold extrusion - Part 4: Technical delivery conditions for steels for quenching and tempering; German version EN 10263-4:2001) |
f# l! ?- ?. P8 P& q1 Y2 z
. `& c" \& b/ j! B" x5 W4.
) m- w# W0 z2 u3 l* p& C6 i: H) S& a" R5 x( W2 t% \
5 ?6 u0 w6 d- b3 X; @* ehttp://www.key-to-steel.com/cn/img/nav/spacer.gif$ k9 @9 X) W" k, r
化学成分 (%)
# J. |- z6 M8 i( M5 P6 A5 ^) z | http://www.key-to-steel.com/cn/img/nav/spacer.gif
. k) `0 a; ~2 q| 元素 | 最小 | 最大 | 近似的 | | C | 0.0600 | 0.1000 | & `( ^' [2 y& Q0 P2 M$ f3 x# B
| | Si | ( q( @6 P- K# ~% m/ w2 H7 P6 C- J9 ]4 s
| 0.1000 | 9 X- n/ ^: u) D7 _' m8 Y
| | Mn | 0.2500 | 0.4500 | " M9 ?0 L( H9 v. X
| | P |
" |6 {. D6 i0 w5 c5 k8 b. g# P" a a | 0.0200 | % o m- c' T8 E# ~3 d
| | S | U! | q$ a5 m. Q: b+ y5 l3 s2 q% Q1 X
| 0.0250 | 7 f0 i1 R8 p( Q B: [
| | Al | 0.0200 | 0.0600 |
| " B5 V7 N6 M+ ^& b: Y8 P
| 标准号: | DIN EN 10263-2-2002 | | 中文标题: | 冷镦和冷挤压的钢杆材、棒材和线材.第2部分:冷处理后不用于热处理的钢的交货技术条件 | | 英文标题: | (Steel rod, bars and wire for cold heading and cold extrusion - Part 2: Technical delivery conditions for steels not intended for heat treatment after cold working; German version EN 10263-2:2001) |
* U' @% Q7 d2 }) Q4 f4 M1 N' ^/ j9 e9 e3 c, t' a7 g
3.
7 B. \3 U' K- H& E6 S7 B
/ O) u7 t3 m5 l5 a| 标准号: | DIN EN 754-1-1997 | | 中文标题: | 铝和铝合金.冷拉棒和管.第1部分:交货技术条件 | | 英文标题: | (Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 1: Technical conditions for inspection and delivery; German version EN 754-1:1997) | & l% m+ v5 a8 | g/ {1 b" L6 @. c
| 标准号: | DIN EN 754-2-1997 | | 中文标题: | 铝和铝合金.冷拉棒和管.第2部分:机械性能 | | 英文标题: | Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 2: Mechanical properties; German version EN 754-2:1997 | | 页码: | 24P;A4 | | 外文关键字: | ALUMINIUM ALLOYS;MECHANICAL PROPERTIES;PROPERTIES;TESTING;NON-FERROUS ALLOYS;NON-FERROUS METALS;DRAWN;ALUMINIUM;MALLEABLE MATERIALS;PIPES;WROUGHT ALLOYS;ALUMINIUM WROUGHT ALLOYS | | 中文关键字: | 有色金属合金;机械性能;拉拔;铝合金;铝锻造合金;可锻合金;铝;管;可锻材料;特性;有色金属;试验 |
| 标准号: | DIN EN 754-3-1996 | | 中文标题: | 铝和铝合金.冷拉棒和管.第3部分:圆棒材.极限尺寸和形状公差 | | 英文标题: | Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 3: Round bars, tolerances on dimensions and form; German version EN 754-3:1995 | | 页码: | 4P;A4 | | 外文关键字: | FORM TOLERANCES;ALUMINIUM ALLOYS;LIMIT DEVIATIONS;DRAWN;ROUND RODS;TOLERANCES (MEASUREMENT);DIMENSIONS;ALUMINIUM;ALUMINIUM PIPES;PIPES | | 中文关键字: | 铝管;拉拔;公差;尺寸;铝合金;圆棒材;极限偏差;形状公差;铝;管 | * V" X6 Q) R; H2 j- O: p9 ]
; ?; `% s( @- a2 A- ~ Y
1.
$ t$ V: }9 z3 a( _" E ? b+ I7 X/ p: f9 J+ Z! B, o
http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif9 W3 ~' M7 L# b) f5 ^) Z- l6 [
化学成分 (%)
) D- X5 {; s( Q" g; a- S/ _ | http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif) d- d$ J2 }4 b# z8 H+ G: E: ?
| 元素 | 最小 | 最大 | 近似的 | | Si | 0.6000 | 1.4000 |
: A6 _% P3 b3 o* h3 O. s | | Cu | 9 h/ t2 s2 H: e9 ~4 f
| 0.1000 |
, J8 X5 U. a" p% s( A | | Mn | 0.4000 | 1.0000 | 6 d/ t8 }& w1 e( F
| | Mg | 0.6000 | 1.2000 |
+ k3 H) Z+ n# i( A1 c3 t. p4 C | | Zn | $ s7 g+ b# _, `' ? |- l2 b
| 0.3000 |
" W% e" s u4 ]$ g2 M0 w | | Cr |
3 e: r/ U2 K$ ]' A2 S& A | 0.3000 | ' c+ z2 I/ q) W; s. h
| | Ti | ( ?# O1 U* { Y8 E
| 0.2000 | % ~7 o5 r% \& Q
| | Al (*) | ( O' U' a, S \4 ^
| 9 Z4 s9 d8 w& B: Y% ~8 G
3 k* X0 l3 `$ ^: `/ o: r4 s. | | | Fe | ( D5 \. g% h" l
| 0.5000 | - Z8 G- |$ J! Y4 j( J
| | Pb | 0.4000 | 2.0000 | - ?9 x( q5 |, h8 D5 F @
| | Bi | 3 l7 P8 H$ {& h8 L5 a1 o) R
| 0.7000 |
+ E, T5 M3 D- T$ o; F" O2 m } | | Total Each | " O8 d. L8 A: m$ f( S+ B7 X
| 0.0500 |
1 F' n0 j" _/ V6 G9 [7 T | | Total Others |
, V* w' R' D6 _! L | 0.1500 | + j- ]) ~6 }( |: D; Q
8 T2 F: c2 G) _* n H+ \http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif' K& M- s5 X8 X1 \* L0 V) F' b
, s9 a8 c d, ^5 p7 n+ G: b
| 标准号: | DIN EN 573-1-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第1部分:编号标识系统 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and forms of wrought products - Part 1: Numerical designation system; German version EN 573-1:1994) | 6 `. {; r8 D3 G( j( q# Z! [
| 标准号: | DIN EN 573-2-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第2部分:化学符号的标识系统 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 2: Chemical symbol based on designation system; German version EN 573-2:1994) | & Z6 T6 F& u. m9 y4 r# |
| 标准号: | DIN EN 573-3-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第3部分:化学成份 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 3: Chemical composition; German version EN 573-3:1994) |
| 标准号: | DIN EN 573-4-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第4部分:成品形式 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 4: Forms of products; German version EN 573-4:1994) |
| & P7 x6 r! x+ C& W- p( z
你是要我国相对应的材料吧?是要材料牌号还是标准号?
& k0 [* D! Z0 f" `: R而且这几种材料国内没有可替代的!
2 B' F; N, e$ |0 x" V5 r7 O& @7 ]: [' o. @ r/ d
[ 本帖最后由 hourpp 于 2007-12-20 09:46 编辑 ] |
